The latest X3 brings some added style and some new features to the BMW SUV family. Talk about the new F25 now!
Old 06-18-2012, 04:53 AM
fb88 fb88 is offline
Mein Auto: 2006 330xi
Low engine coolant warning after 15k miles
2011
anyone has this happen?
Old 06-18-2012, 06:56 AM
UncleJ UncleJ is online now
Mein Auto: '06 X3
Don't fool around with it -- take it to the dealer and have them fix it. The car is under warranty.
Old 06-18-2012, 08:21 AM
gfeiner's Avatar
gfeiner gfeiner is offline
Mein Auto: 2012 X3 xDrive35i
Add more coolant and watch for leaks over the next few days. If no leaks and your oil is not a milky color, problem solved.
Old 06-18-2012, 08:27 AM
NYX335i NYX335i is offline
Mein Auto: 2009 X3
Known issue...
Checkout this writeup from Motortrend:
http://www.motortrend.com/roadtests/...e28i_update_9/
If there's no leak under the vehicle, just add some coolant.
Old 06-18-2012, 09:22 PM
x3brian x3brian is offline
Mein Auto: X3
I have a 2009 and had this call with my wife in early 2010...
"Brian...why do I have this coolant light on??? I just want to get to work and car is new...why didn't you check it?"
I felt like an ass, bought a gallon of BMW coolant and distilled water on my way home with tail between legs. Mixed 50:50 when I got home and filled 3 qts in expansion tank...
2 years later never lost coolant since. It is what it is and don't worry it is normal.
Old 06-19-2012, 12:18 PM
Coder Coder is offline
Mein Auto: 2011 X3 xDrive35i
Had the same thing happen to me at 19,000 miles. No leaks evident. Added coolant and no problem since in 800 miles.
Note that when adding coolant, there are min/max marks on the inside of the reservoir.
Old 06-21-2012, 07:47 PM
Dealer topped it off, but was surprised the light came on only after 15k miles.
What happens if you use straight coolant fluid without mixing it with distill water?
Old 06-22-2012, 08:12 AM
Mein Auto: '06 X3
py, keep an eye on the coolant and if the light goes on again -- be sure to get it back to the dealer. There is a reason that liquid is disappearing somewhere. An air block in the heater core can only account for so much -- then the core is filled and no more coolant should be "lost".
Old 06-22-2012, 08:57 AM
Me530's Avatar
Me530 Me530 is offline
Happily Driving
Mein Auto: 2011 550i M Sport
I love how at the bottom it says "Unresolved problem: throttle delay."
2013 X3 35i, Dealer Delivery
2011 550i M Sport, European Delivery
Gone, but not forgotten:
2006 530i
, European Delivery
2008 335i Coupe 6MT, PCD
BMWCCA #350568
Old 06-27-2012, 12:47 PM
usaret's Avatar
usaret usaret is offline
Retired
Mein Auto: '09 X3 (MT)
Originally Posted by pyao88 View Post
2011
Happened a couple of times on my 2009 right after I picked it up. I just topped it off with distilled water (took maybe a cup total) and never had another issue. I'm getting ready to roll 93,000 miles so there was definitely no leak.
I'm pretty sure it's just from working all of the air out of the system from assembly.
Old 07-05-2012, 02:04 PM
steined steined is offline
Mein Auto: ML320, X3 35i M, G8 GT
Just to add to this, this happened to mine as well at 9K miles.
Old 12-30-2012, 03:18 PM
After another 10k at 25k, low coolant light came on again after parking on the snow for a week. This time I am hundreds of miles away from home. I added a bottle of spring water (17 oz) to fill up around the min line.
I backed the car out I can see some greenish liquid on the snow. I assume that's BMW coolant?
Old 12-30-2012, 03:33 PM
noka noka is offline
Mein Auto: 2013 x35i M-Sport
Probably.
2013 x35i (Space Gray, MSport, CW/CWII, DHP, Premium, Premium Sound, Technology, BMW-Apps)
Retired:'09 C300 4Matic, '09 GTI, '06 750i, '05 C55, '04 R32, '03 M5, '02 GTI, 01 M5, '00 M-Coupe, '00 540i/6, '99 M3 Coupe, '98 M3 Coupe, '96 328i, ..., '86 4000CS Quattro, ... too many to list
Old 01-02-2013, 07:01 AM
Jen4BMW Jen4BMW is offline
Jen4BMW
Mein Auto: 2013 X3 35i M Sport
My low coolant light came on at 8500 miles. Drove to the dealer and they topped me off no charge. Dealer said that this is a common issue due to the temp these engines run at and given the coolant is 50% water. Evaporation was their explanation. I accepted that. Seems logical.
2013 X3 35i M Sport / PREMIUM / DHP / TECH / COLD 1 & 11 / AW / OYSTER
Old 01-02-2013, 09:30 AM
gfeiner's Avatar
Just to clarify, the coolant/antifreeze itself is not 50% water. What you buy at the dealer or parts store is 100% coolant. You are supposed to mix in distilled water yourself at a 50% ratio whenever you add more coolant to the vehicle.
Old 01-02-2013, 01:55 PM
I would not believe what they told you. Of all the vehicles I have owned (dozens) there were only a few that needed topped-up coolant and they either: a) had a leak, or b) had the coolant system serviced (e.g. flushed) and some trapped air made its way to the tank. The system is closed and there should be no reason to have to add coolant/H20 mixture (there should zero evaporation).
Old 01-02-2013, 02:16 PM
lbjgh's Avatar
lbjgh lbjgh is offline
Mein Auto: 2013 X3 M-Sport
Interesting my car had a antifreeze odour that came through the ventilation system periodically... My car also got a low coolant warning too.
Perhaps this is a design fault causing the antifreeze to "boil" over on hot days leaving insufficient volumes on cold days. My car got the low coolant warning late fall.
Old 01-02-2013, 02:22 PM
Hmmm,... I guess I might be picking up some coolant when I pick up the new vehicle .
Old 01-02-2013, 02:37 PM
lbjgh's Avatar
Screw that... at $50-60K let the manufacturer pay for it. I reset the warning for about three weeks until I could get in to the dealership... It is a manufacturer's fault after all. BMW is lucky the 10 cents worth of antifreeze (they saved) didn't cost them an engine repair.
Old 01-02-2013, 02:51 PM
02420X3 02420X3 is offline
Mein Auto: 2011 X3 35i
Noka,
My warning came up after 20K miles, on a few cold mornings, and went away as soon as my X3 warmed up. I would have dropped by the dealer on the (long) way to work, but I had an oil change scheduled soon. Instead, I splashed a few ounces of bottled water into the reservoir, no more than 2-3 ounces, and added "top up the coolant" to my service list.
Don't waste money on coolant, which the dealer will top up for free. Instead, spend the money on brake dust cleaner for your wheels. You'll need two.
Old 01-02-2013, 03:00 PM
Originally Posted by 02420X3 View Post
Noka,
OK, I might have over-reacted, especially if it was only a couple of ounces (and assuming you could easily see the reservoir to be able to determine that it wasn't down that much). I'd be more concerned if it needed more than that and possibly diluting the mixture too much. I wonder if there is a sensor design problem (e.g. bad placement, over-sensitive, etc). One thing for certain, in a well-designed system you should not need to add coolant.
Old 01-05-2013, 06:35 AM
Update: Dealer said they did 4 hour pressurize test and found no coolant leak. They said BMW coolant is blue (the leak I found on the snow is greenish like this color http://forums.bimmerforums.com/forum....php?t=1815445 ) although I did not check the actual coolant color that's in my 2011 X3 28i.
I will manually check coolant level after another 5k miles to see if it's draining or evaporating since I added 17 oz of bottled water to it.
http://forums.bimmerforums.com/forum....php?t=1698895
Old 01-05-2013, 08:07 AM
c3uo c3uo is offline
Mein Auto: Audi
Just so everyone knows, I have read a few articles (see Motor Trend long term test) where the capacity increases due to expansion in the hoses, etc. Seems completely normal (but unique to BMW).
http://www.edmunds.com/bmw/x3/2012/l...behind-us.html
So in summary, watch your coolant level and expect to add 1 litre between 15,000 and 20,000 miles.
Old 01-05-2013, 08:22 AM
It's difficult to believe that hoses could expand enough to accomodate about 15% more coolant. I'm curious, when people had the low coolant message, was there any coolant visible in the reservoir? If some was visible, I wouldn't have a problem driving it to the dealer for a top-up. If not visible, then you really have no clue how low it is and I would be hesitant to risk driving it.
Old 01-16-2013, 02:28 PM
X3emist's Avatar
X3emist X3emist is offline
Mein Auto: 06 X3 Sport
Light came on around 8500
We to got the low coolant light on our 2013 with the 4cyl. Dealer pressured tested, no problems. They said it is inherent in the 4 cyl twin turbo. Makes no sense to me in a sealed system but we'll see I guess.
2006 X3 Silver Grey/Black Lthr/Alum Trim/Sport Prem Pkg/Xenons/Servotronic/Prem Sound/Satellite Radio/Heated Seats/Carbon Fiber Pillars/Blue Tooth/Aux In/Cargo Net/Aluminum Pedals/V1 Hardwired
[SIGPIC]
