Old 11-20-2010, 03:58 PM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
Replaced the guibo today
and man I'm impressed with the undercarriage. I love the plastic and aluminum shielding....keeps the unibody looking like new under there. I never thought it would be so easy to do. Between the TIS and Keif's photos it was a 2.5 hour breeze...although I did cheat and use my trans jack to lower the exhaust and hold it up with ratcheting straps to save time. Test drove the car and wow what a difference....guess that part isn't designed to last more then 50k or so. Next week will be the coolant hose and sensor.
Old 11-20-2010, 03:59 PM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64/5, Maserati GT
Nice work
650i sport hud ac schnitzer eibach resognator delete m6 quads akebonos
Old 11-21-2010, 03:59 PM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
Good job... Nice ZX14....Although my next bike will be a Busa. Did you have downshift problem with jerking from 2-1?...is that why you replaced the guibo?
Old 11-21-2010, 04:07 PM
MOPAULY's Avatar
Thanks. No down-shift issue really, just a clunking letting off the accelerator and going into gear sometimes. The old guibo had a ton of visible slop in it, you could move the driveshaft back and forth and visibly see it. Not sure why the dealer charges so much for this...I'd do it all day long for $400 plus the guibo.
Old 11-22-2010, 03:39 PM
wilson009's Avatar
wilson009 wilson009 is offline
Mein Auto: 2002 745i 116k
Is that your home garage with a lift? I love something like that!
Black 2002 BMW E65 / 745i 114K
My DIY's - New alternator, battery, CCVs, idler/tensioner pulleys belts, NGK Iridium spark plugs, , sway bar bushings, Front rear brakes, Valve Block, Head Gasket, Exhaust Gasket, Upper and lower Timing Gaskets, Valve Covers, exhaust valves, Timing Chain slide rails, Fuel Injector o-rings, pulled radiator, Intake Manifold Gaskets, water pump, Coolant Pipe/weep hole, oil pan gasket, vacuum pump, fan shroud, Vanos solenoid o-rings, and timed it with a timing kit.
Old 11-22-2010, 05:35 PM
MOPAULY's Avatar
Indeed sir. I have a 2 post lift for maintenance services and a 4 post lift I use for storage.
Old 11-23-2010, 08:41 AM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
+1!!!!! Did you do the trans adaptation reset thing as well? Mine was like butter after guibo, fluid, and the trans adaptation reset.
So very jealous right now.
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 11-23-2010, 09:19 AM
MOPAULY's Avatar
Yep I did the adaption as well, she used to shift waaaay early. I didn't change the trans fluid but had been contemplating it, I used to do it every 15k or so on my Dodge, and she still has her original trans at 194k.
Old 11-23-2010, 11:22 AM
Master Tinkerer
If it shifts well now, I vote not to mess with a good thing. Just my $0.02.
Old 11-23-2010, 07:50 PM
racerock racerock is offline
Mein Auto: 745Li 330i K1200LT TL ...
Not to jack the thread (though I am about to do my guibo and just did a trans fluid change)
Is your 2 post Asymmetric? Could you do me a favor and let me know where the posts end up on your 7? maybe a measurement from the front to the post and the back to the post.
I'm about to install a Rotary 10K Asymmetric in my garage and want to get it close to right on the money.
Old 11-23-2010, 09:17 PM
sebi750's Avatar
sebi750 sebi750 is offline
Mein Auto: bmw 750 li
whats the part number for the guibo? thanks!
Old 11-24-2010, 05:11 AM
Country's Avatar
Country Country is offline
Mein Auto: '03 745Li
Just got my car back after my Indy replaced the guibo. MAN!!! What a difference. Smooth as hell.
03 745 Li//Black Kidney Grilles//MTECH V2 Lights//MTECH HID fogs
Old 11-24-2010, 05:49 AM
MOPAULY's Avatar
Asymmetric - the car sits about dead center of the lift...I may have it up in the air again this weekend for the lower coolant hose so I'll try to remember to measure then.
seb - sorry I already threw out the bag with the part number on it...
Old 11-24-2010, 06:55 AM
OK, thanks, that would be greatly appreciated. I'm surprised you said dead center - was expecting something towards the front of the front door (A pillar area) and not between the doors (the B pillar). Nice garage by the way. What bike do you have?
Old 11-24-2010, 07:01 AM
MOPAULY's Avatar
you know, I think it is actually closer towards the a pillar, I thought I had a photo on my phone but do not; i'll def take a pic this weekend if I put in the air again.
Old 11-24-2010, 07:19 AM
part number for the Universal Joint/Guido for 745LI 2004 is:
26117572664
It also fits a bunch of other years including the 750's
Old 11-24-2010, 05:23 PM
Darbyva Darbyva is offline
Mein Auto: 2005 745Li
Got mine replaced this week (2005, 66k miles). Ran about $750, not covered by CPO warr. (ouch). But, made a nice difference.
Old 11-25-2010, 01:56 PM
sebi750's Avatar
found the part number. thanks!
Old 12-29-2010, 04:59 PM
DFEL750I's Avatar
Mein Auto: 750I
26117572664
Can anyone confirm that the guibo partnumber here is for the 750s as well. The guibo for a 750 is showing up on realoem as a different part number. See below
745 Guibo
http://www.realoem.com/bmw/showparts...89&hg=26&fg=10
750 Guibo
Old 12-29-2010, 09:06 PM
My suggestion would be to ask the guys at getbmwparts.com to confirm using your vin.
By the way, I have not replaced my guibo yet... Still running well after resetting the trans tables to zeros to relearn after replacing the trans fluid and filter... Knock on wood, it is running well.
Old 01-16-2013, 07:22 PM
joju58's Avatar
joju58 joju58 is offline
Mein Auto: 2007 750Li
Sorry guys if I'm supposed to post here and not meaning to highjak this thread. I alo posted a few days ago at sell/buy threads but got no responces even though price is cheap, well at least i think it cheap because i paid much more. This is how my post looks there; BMW e65/66 Driveshaft Flex Disc universal joint OEM guibo coupler
Hi, selling this OEM part because traded in my car and no longer need it. I paid $150.00 plus shipping cost, but willing to sell it for $110 including shipping cost. New Yorkers welcome for in person transaction.
As a bonus i will include also set of two cabin charcoal filters, its a good brand, sorry its in the box in my car in parking lot can't go to see a brand. Sorry again guys.
"Love people, not things; use things, not people." Spencer W. Kimball
Old 01-16-2013, 08:38 PM
sanhonda22's Avatar
sanhonda22 sanhonda22 is offline
Sleek Sam
Mein Auto: AC Schnitzer 745Li
Beautiful home garage setup and car/bike collection.
Old 09-11-2013, 07:33 AM
BoostdR BoostdR is offline
Mein Auto: 04 735i
This is my Guibo after 140,000km.
When your replacing it you may find it easier the utilise the emergency transmission release under the dash to place the trans in neutral. This enables rotation of the shaft for easier access and removal.
Matt
Old 09-12-2013, 06:55 AM
kmatthews kmatthews is offline
Mein Auto: 750li
I have a quick question when replacing guibo, do I need to replace the center mount #8
Old 09-12-2013, 07:11 AM
First_745Li's Avatar
Mein Auto: 2007 Audi A8
I'm about to get this done soon, and I'm going to replace the center mount. You're already there, might as well. Just my two cents.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
