E36 (1991 - 1999)
Old 01-15-2013, 10:32 PM
motorthrill motorthrill is offline
Mein Auto: 325i
crank crank crank no start helppp!
whats up. so it drove well forever, an lately(for a week) its been taking a while to start. an now it just wont start.
i replaced fuel filter an nothing an it has proper fuel presure.
replaced valve cover since the oil well were full of oil. could that of hurt something?
what sld i do next?
please help!
Old 01-15-2013, 10:39 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
When you turn the key what sound(s) do you hear?
Fuel pump?
Engine turning over?
Starter engaging?
Starter clicking repeatedly?
Starter just clicking once?
No sound at all?
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 01-15-2013, 10:41 PM
Mein Auto: 325i
the engine will turn over buhb wont start. an yeah the fuel pumps coming on i replaced the relay just to be shure
Old 01-15-2013, 10:53 PM
jonesin's Avatar
The Canadian Prick.
First off, check your battery terminals for corrosion and tightness.
Then I'd test your battery, fuel pressure (you can by a fuel pressure gauge from Harbor Freight for ~$20), then we'll get into testing for spark.
Old 01-15-2013, 10:57 PM
Mein Auto: 325i
ive tryed two different batterys (stole the battery frm my jeep)an cleaned terminals, allready tested fuel pressure an replaced fuel filter :/
Old 01-16-2013, 01:05 AM
hornhospital's Avatar
D'oh, You Kids!
Crank or cam position sensor. It's not firing the plugs or the injectors or both.
Quotes to live by:
Old 01-16-2013, 04:58 PM
Mein Auto: 325i
Do u think it could be the mass air sensor?
Old 01-16-2013, 05:01 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Unplug it and find out.
GGC BMW CCA #443004
Join the BMW CCA!
Old 01-16-2013, 11:44 PM
Mein Auto: 325i
unplugged it anstill didnt wanna start just turning over an not firing how do i read the check engine light ?
Old 01-17-2013, 05:08 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
OBD1 cars, get a PEAK Sensor for OBD1 cars
OBD2 cars, go to Advanced Auto and rent the scanner. Bring it home, plug it in, turn key into the on (don't start) position, scan.
Sounds like a Crank Position Sensor or Crankshaft Position Sensor. But I am just a keyboard mechanic.
Old 01-17-2013, 09:20 AM
Mein Auto: 325i
i have an obd1 reader that ived used in my jeep an mustang, buh i cant figure out where to plug it in at. i saw a round plug in spot under the hood is that it? where can i get the adapter
an again thanks for all ur help guys!
Old 01-17-2013, 10:07 AM
hnaz's Avatar
BMW CCA Member
I don't know if all OBD1 scanners are universal.
Old 01-18-2013, 12:44 AM
Mein Auto: 325i
where is the crank or crankshaft sensor located how do i replace it?
Old 01-18-2013, 07:17 AM
hnaz's Avatar
BMW CCA Member
Well, might wanna check the camshaft position sensor as well. Here are vids:
Camshaft position Sensor
Crankshaft Position Sensor (If you have a lift, it will make life easier).
Old 01-18-2013, 11:59 PM
Mein Auto: 325i
so i replaced the crankshaft sensor an now it runs!! yay!!! buh it will idle normal then it will start to die then rev up an start to die an rev up
what could cause that
Old 01-19-2013, 12:13 AM
D'oh, You Kids!
Vacuum leaks. Dirty MAF, Dirty ICV.
Quotes to live by:
Old 01-19-2013, 01:10 AM
Mein Auto: 325i
How do i clean those? Like will carb cleaner work
Old 01-19-2013, 06:43 AM
jonesin's Avatar
The Canadian Prick.
Absolutely NOT for the MAF!!!!!
Use an electrical contact cleaner for the MAF, (Or specific MAF cleaner). aYnd you can use Carb cleaner on the ICV.
