Old 01-16-2013, 06:35 PM
BlackMax540 BlackMax540 is offline
I am a rookie again
Send a message via AIM to BlackMax540
Mein Auto: 1999 BMW 540i
Cooling System Advice Needed for 99' 540iA!!!
I have a 1999 540iA and have been trying to figure out what manufacturer makes the best and most reliable water pumps? Also which impeller is better to have, metal or composite? What is the opinions on Zionsville Radiators? Any advice will be greatly appreciated..I am getting prepared to put a newer engine and transmission in my 540i and just want to have the best and most reliable parts i can use.
Thanks everyone,
Alex
Old 01-16-2013, 07:03 PM
AlexandruE39 AlexandruE39 is offline
Mein Auto: 97 E39 540i 6Speed
Hey Alex,
I've researched the all aluminum radiator and its a must for a better cooling system in the 540i. I don't have it on mines yet but will do the conversion once I get the money together. There is a guy on YouTube that shows how he did it on his 530 I believe and u can see his electric fan setup too on his channel. Il post it once I find it. If I were u go with a manual trans if I can get ur hands on one but if u prefer auto that's cool too. I just think the manual trany is more reliable.
Old 01-16-2013, 07:06 PM
I hope the link works, from here u can see all the mods he has done to it on his channel
Old 01-16-2013, 07:17 PM
I am a rookie again
Thanks for the info and the video was good. Now i just need to figure out the water pump questions
Sent from my DROID RAZR using Bimmer App
Old 01-17-2013, 03:31 AM
I am a rookie again
What would be the best water pump and thermostat to get and should it have a metal or composite impeller?
Old 01-17-2013, 06:29 AM
Fudman's Avatar
Fudman Fudman is offline
Go with metal impeller. Some composite impellers have been known to fracture. Graf is OK. Stewart makes the best (& most expensive) WP but I think it is only available for the I6. Search. Stay with the OEM (Behr) thermostat.
Old 01-17-2013, 07:55 AM
Since the question has been asked umpteen times before, many members are jaded, so you will not get the full response you would have liked.
However, you can start with the existing response and improve it from there, and, BTW, your payforward is for you to snap pictures of the old and new waterpump you decide upon and add value.
Typing /waterpump in the bestlinks nets this, which I'd recommend, for starters:
- What is the best brand of waterpump to buy for the bimmer (1)
