Old 12-11-2010, 09:34 AM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
The truly beautiful part is the simplicity of this car.
By far the least amount of electronic crap to break on this car.
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
Old 12-22-2010, 01:55 PM
mark_m5's Avatar
mark_m5 mark_m5 is offline
Overly Intellectual
Mein Auto: 2002 M5, 1999 M Roadster
Update:
Body Shop:
  • Went over the car to make sure frame was straight from the accident history on Carfax and it looks perfect.
  • Alignment is correct
  • remounted the front bumper so it was lined up better
  • Scraped down the hood to bare metal, smoothed and repainted.
Subtotal, body shop: $1075
Full outer detail $85
At my favorite mechanic:
  • Oil service (engine, transmission - previous owner used the wrong viscosity!!!)
  • New Battery (the one in it was toast)
  • OEM Locking gas cap (it had a non-locking aftermarket one)
  • New wiper blades
  • Replaced sway bar links
  • Replaced a few tail light & brake light bulbs and a socket
  • Clutch switches (cruise control)
  • Rear view mirror (it was missing that tab to control day/night)
  • Tightened oil pan drain plug that was loose
  • fixed power steering leak
  • checked seals and other leak points
Still to do:
  • Seat heater (on order from Germany STILL)
  • Dash light out behind the vent position knob
Subtotal, mechanic: about $900
Last thing, it could use a new rear plastic window and maybe a new top-down-windscreen.
What do people typically pay for a new rear window? I'm hearing it's a several hundred $ to sew a new one in.
Any glass options out there?
Anyone out there using a zip-in window?
Mark
Old 12-22-2010, 05:36 PM
Mpire's Avatar
The Anti-Rice
Originally Posted by mark_m5 View Post
[*]Rear view mirror (it was missing that tab to control day/night)
Are you sure the mirror wasn't the auto-dimming mirror?
Rear windows are 250 bucks delivered.
You just zip out the old one and zip in the new one, then you seal it with rubber cement. New window comes with the necessary tools.
54318401027 $292.81 $0.00 $234.25
Cant use glass because window has to fold in half to fit in the well. No where for a glass one to go. However, one person can replace the window on a Saturday morning.
Old 12-27-2010, 07:08 AM
mark_m5's Avatar
Overly Intellectual
I've seen a lot cheaper, but what if my top doesn't have a zip-in window? It looks like it's sewn in.
Mark
Old 12-27-2010, 06:00 PM
ZZZING ZZZING is offline
Mein Auto: Z3 2.3
If it is sewn in you have an aftermarket top
Original BMW top had the zipped in window, replacement tops have the window sewn in. A shop that does convertible tops should be able to advise you on replacing your sewn in window.
_________________________________________________
2000 2.3 Oxford Green / Black Top / Beige Interior
Koni Sport Shocks, M front Shock mounts reversed, Sharked, Strong Strut, Oxford Green II hardtop
Old 12-29-2010, 08:26 PM
Mike Clark Mike Clark is offline
Mike
Send a message via ICQ to Mike Clark Send a message via AIM to Mike Clark Send a message via Yahoo to Mike Clark
Mein Auto: 2006 BMW M Roadster
Rear view mirror should be auto dimming thus no lever to dim it.
Mike
2006 M Roadster Imola Red
2000 M Roadster Imola Red (gone but not forgotten)
1997 Z3 2.8 Roadster Red (gone but not forgotten)
2008 328i Sedan Gold
Old 01-06-2011, 03:49 PM
mark_m5's Avatar
Overly Intellectual
Turns out I was mistaken... the window was a zip in. I got a factory replacement since my mechanic said that the aftermarket ones can't use the patented locking mechanism for the zipper or something like that and apparently they're difficult to get to fit correctly sometimes.
Not on the Z3 M.
Mark
Old 01-06-2011, 06:14 PM
Mpire's Avatar
The Anti-Rice
Not on the Z3 M.
Huh? Thats a typo right? You meant to say that the M cars have the auto dimmer and the non-m Cars have the regular mirror. However, all the cars have the harness apparently to install the auto dimming mirror. I put one in Tiff's car.
Old 01-06-2011, 08:09 PM
mark_m5's Avatar
Overly Intellectual
Mine doesn't have the auto dimmer, and didn't have it before. So are you telling me that I need to find a harness and install a different part?
Mark
Old 01-06-2011, 09:40 PM
Pants Pants is offline
Road Rager
Mein Auto: '06 Z4 SI
Yes YOU HAVE TO DO THIS! Otherwise the guy next to you at a stop light will recognize this flaw and interpret it as a weakness.
Old 01-06-2011, 09:50 PM
Mike
What is the production date of your car?
Mike
Old 01-07-2011, 07:26 AM
mark_m5's Avatar
Overly Intellectual
I'll check the plaque when I get it back from the shop. The seat heater finally came in so it's almost done. It's a 1999.
Mark
Old 01-07-2011, 08:15 PM
Mike
Do you have the VIN handy. I can get production date from that.
Mike
Old 01-30-2011, 03:40 PM
mark_m5's Avatar
Overly Intellectual
Pics!!!
Our baby.
Build date 12/98
Yes, I photoshopped them a little to add the lens blur.
Fixed a leaky set of heater hoses to the firewall, and replaced the fan belts to the tune af another $600
We have the seat rocking issue BAD in the passenger side. Mechanic was saying $1200 for a new seat rail, so I decided to check out Bimmerfest DIY sticky threads. Jackpot! Got the fix from a link to Esmerelda's Fixit Page:
http://www.waycoolinc.com/z3/essenti...xit/index.html
Which led me to a writeup:
http://www.waycoolinc.com/z3/02/100602/shish01.html#SIB
And the official BMW service Bulletin:
http://www.waycoolinc.com/z3/02/1006...rockingfix.pdf
And the replacement bushing:
http://www.whalenshiftmachine.com/in...&products_id=8
So...
What does everyone think about the Diablo wheels?
ID:	264484   Click image for larger version
Mark
Old 01-31-2011, 12:15 AM
alijonny alijonny is offline
Mein Auto: e39 M5, Z3 2.8
on the Diablo wheels. Source some OEM roadstArs (at least) NOW. Looks cool otherwise.
Last edited by alijonny; 01-31-2011 at 02:10 PM. Reason: spelled roadstars wrong...
Old 01-31-2011, 02:32 AM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2008 Z4MR
+1 on the wheels
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 01-31-2011, 08:58 PM
Mike
Nice pictures. Glad to see you are properly restoring the car to what it should be! From what I can tell, the rear view mirror on 12/98 build date was not the automatic adjusting kind. That came later around 3/99 and subsequent.
Mike
Old 02-01-2011, 11:07 AM
BlackjackM BlackjackM is offline
Mein Auto: '01 Z3.0 R; '10 MB C300
The car looks great! But why oh why would anyone (the previous owner) take the beautiful Roadstars off and replace them with those wheels??
Old 02-01-2011, 03:38 PM
I bet it has the wheels for the same reason it has a $4,000 stereo that renders the trunk useless.
Old 02-03-2011, 03:12 PM
ghpup ghpup is offline
Glfbggy
Mein Auto: 07 X3si, 00 528, 00 MZ3
When I was doing my research, ALL, Z3Ms had the auto-dim mirror. It is actually one of the items that has received negative comments because it dims too much in early morning hours and late evening hours..... I know that some of the early 98/99 builds didn't have what the '00s and later had, but sheesh you would think the mirror would be consistant...
GLFBGGY
'00 MRoadster, '00 528, '07X3si
Old 02-04-2011, 06:29 PM
mark_m5's Avatar
Overly Intellectual
Our thoughts exactly!!! I looked at a lot of styles of aftermarket wheels, and I think the stock ones are probably the classiest.
We have to dump the stereo.
Mark
Old 01-08-2013, 04:29 PM
mark_m5's Avatar
Overly Intellectual
Update!
Fixed the seat bushing on the passenger side and replaced the seat heater back in 2011, forgot to post about that. Tightened the radiator hose to eliminate a tiny leak. I think I did an oil change last year... I'd have to look at receipts. Some miscellaneous plastic bit broke loose under the car due to impact from freeway debris; my mechanic bolted it back and it's good to go. The motor for the top seems not to want to engage now on the first attempt to lower it; so I may have him check that out and do a maintenance service for the heck of it.
The tires are finally wearing out, so just ordered a fresh set of Michelin Pilot Super Sports, and figured that as long as I was on Tire Rack's site, I'd order new wheels too.
So, O.Z. Alleggerita HLT wheels in Anthricite are on the way. I'll need to offload those Diablo wheels. Anyone know someone that might want them?
Mark
Old 01-15-2013, 09:00 AM
mark_m5's Avatar
Overly Intellectual
Noticed a little rattle in the passenger side window when all the way up. Gonna have to tighten something probably. Good news is the convertible motor seems to be working consistently in several tests since...
Mark
Old 01-16-2013, 08:08 PM
Blimey Blimey is offline
Mein Auto: Z3
performance
Hello ! Mark, I delved into this performance "gizmo" and found out that the ones costing less than about $200.00 are purely a scam. To improve performance you need to spend upwards of $800.00 but the return just isn't worth it. If it's a 2.8 - surely thats quick enough. Ease up on the pedal power will increase gas mileage to around 26 to 28. Blimey
Old 01-17-2013, 05:52 AM
Post some new pictures when you get it all done. Sounds like you got everything well in hand.
Regards
2008 Z4M Roadster
BMWCCA/ZSCCA Member
