E34 (1989 - 1995)
Old 05-13-2005, 02:08 PM
andrew@harryjay andrew@harryjay is offline
Mein Auto: 1990 e34 535i sport
Angry uk spec e34 535i sport/overheat problem
hope somebody may be able to help.my car has been parked up outside the house for approx 18mths,due to having company vehicle.in this time whilst not being used it has developed an overheating problem.have renewed thermostat,all heating and ventilation working fine.there is no sign of oil emulsification,has any body had asimilar problem or does anybody have any suggestions.
Old 05-14-2005, 03:06 AM
markusamigos markusamigos is offline
Mein Auto: 1995 540i SE&1993 325ci
rad cap
try changing the radiator cap........there was a recall on this model. are all your belts fine ?
ps or your water pump might be kaput !
Old 01-16-2013, 08:23 PM
cookies5 cookies5 is offline
Mein Auto: 535 i bmw
Ihad same problem it was the thermostat
Old 01-17-2013, 06:39 AM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
When does it overheat?
If it overheats at idle, or stopped in traffic you most likely have an airflow problem. Fan clutch is likely and possibly aux electric fans though less likely in the winter.
If overheating at road speed, there is plenty of airflow, you have a coolant pumping issue. Water pump is likely, some sort of blockage is possible.
I wouldn't always assume a headgasket on a 535, the big six is wonderfully durable, just don't overheat it badly, or often.
So if the coolant level is good, the thermostat is new, the system is filled and giving cabin heat, and the cooling system has been drained and filled, I think it is one of the above suggestions depending on symptoms.
Good Luck
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 01-17-2013, 07:06 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
Good Luck
We doing archaeological digs now?
#superoldthread
Sent from Joe's Galaxy SIII via BimmerApp
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Similar Threads
7 Series Sport Package is coming... Jon Shafer General BMW Questions 6 03-03-2003 06:29 AM
Sport seats without the sport package for ED? dlloyd1975 Regional Forums 12 01-16-2003 06:04 AM
BMW Sport Compact a Mercedes-killer? ChrisTO General BMW Questions 2 10-14-2002 11:04 AM
Toying with the idea of an E34 M5... Mr Paddle.Shift General BMW Questions 12 05-13-2002 01:24 PM
Wow! The G35 Coupe looks good! (link inside) Sean Off-Topic 12 03-29-2002 12:48 PM
