Old 12-11-2012, 06:21 PM
tankren tankren is offline
Mein Auto: 116i
the text display color works but the tacho backlight remains orange
Old 12-11-2012, 06:26 PM
JEG23 JEG23 is offline
Mein Auto: 550i
Not quite sure what you mean. At least in the F10, F01 and the F30 it works.
JEG23
2011 550i
Space Gray /Black Nappa, Dark Wood
ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR
Old 12-11-2012, 07:01 PM
marsb007 marsb007 is offline
Mein Auto: 2013 535i
Ok, so let me get this straight..
We can get the display to stay in day mode (white) but as a result, you lose the auto toggle of the iDrive screen between day/night.
Is there a way to toggle the iDrive screen between night/day mode via button assigned to presets 1-8? (sorry, my car is still in the middle of the ocean so I can't test...)
Old 12-11-2012, 07:14 PM
Mein Auto: 550i
The toggle does not change the iDrive from day to night mode, it just changes its brightness when the car is in night mode. You do loose that, but you can still adjust the brightness via the iDrive itself. As far as I am concerned, a minor inconvenience in exchange of getting rid of the ugly orange night mode in the cluster.
JEG23
2011 550i
Old 12-11-2012, 10:29 PM
ilhan1103 ilhan1103 is offline
Mein Auto: f30 318d
I think I might have some insight into what the problem is.
You Jeg23 (and possibly all f10s?) have the extended instrument cluster.
If you don't have that one, only the little bc part showing date/cons. etc will move from white to orange at night. The backlight of the gauges (ie tacho) will always be orange.
As for the 'iDrive nightmode' marsb007 probably means the navigation day/night switch.
As memory serves, I think you can assign a preset button to this. Alternatively, leave it in daymode it doesn't bother me that much personally.
Old 12-12-2012, 12:32 PM
That's exactly what I meant... I guess I'll wait until I get my car. Seems I had the wrong ship, but when I touched base with my CA, he gave me all relevant info (I'm on KLine and not WW).
Old 12-12-2012, 02:15 PM
Mein Auto: f30 318d
Btw I tried this for you and both the modes (day/night) as well as the menu where to change them can be assigned to a button.
Old 12-12-2012, 07:40 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
@JEG23 - While you were testing this, did you come across the opposite whereas the Night Mode is always on? Maybe Werte=00?
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 12-12-2012, 08:37 PM
Mein Auto: 550i
Shawn,
I did:
KOMBI->3007 KI_Dimmung, 24->DIM_NACHT_AUS->werte=FF
Orange all the time.
JEG23
2011 550i
Old 12-12-2012, 08:42 PM
Originally Posted by JEG23 View Post
Shawn,
I did:
JEG23
Thanks!
So I wonder which one wins if both DIM_NACHT_AUS and DIM_NACHT_EIN are set to Werte=FF.
- BMWCCA #446923
- flick
Old 12-12-2012, 08:45 PM
Mein Auto: 550i
Thanks!
It probably will flash a message urging you stop messing with it
2011 550i
Old 12-12-2012, 08:47 PM
...or maybe some new weird color...
- BMWCCA #446923
- flick
Old 12-13-2012, 08:50 AM
Mein Auto: f30 318d
It will activate the secret disco lights for sure.
Old 12-18-2012, 11:47 PM
al7oot al7oot is offline
BiMMER4EVER
Mein Auto: 750Li F02
I am sure this is not for everyone, but I personally like the bright daytime instrument display a lot better than the nighttime orange display. To me it is sharper looking and easier to read, with more contrast.
You can easily change a simple code so that it remains in daytime mode all the time:
KOMBI-->3007 KI_Dimmung, 24-->DIM_NACHT_EIN-->Werte=FF
The default value is Werte=0A. This hexadecimal value relates to the sensitivity of the sensor that determines the threshold at which the display changes into its nighttime mode. When set to “FF” it stays on the daytime mode constantly.
Attachment 352316Attachment 352317
At least for the F10, you can still select the color of the decorative lines in the extended display (orange or gray), depending on your preference, using the code in my earlier post.
KOMBI-->3000 Anzeige_Konfiguration-->HINTERGRUND_FARBE_TAG-->Grau or Orange
JEG23
Hi.. I'm a new owner for F01 and can any one help me where and how I can use this code ?
Old 12-18-2012, 11:54 PM
Mein Auto: f30 318d
Do you mean you can't find it in the ecu?
Or possibly you don't yet know about Esys and coding, in that case you will find this thread interesting:
http://www.bimmerfest.com/forums/sho...d.php?t=631884
Old 12-19-2012, 01:08 AM
BiMMER4EVER
Thumbs up
Thanks man appreciate your help
Old 12-19-2012, 05:24 AM
Here too:
http://www.bimmerfest.com/forums/sho...d.php?t=654990
- BMWCCA #446923
- flick
Old 01-17-2013, 06:39 AM
Alan L. Alan L. is offline
Mein Auto: Msport 335i
Is this still working for everyone for the F10? Someone posted that after changing this it reverted back to amber after 10mins.
Alan
Current - 2013 N55 535xi Msport SAT
Retired - 2009 N54 335i Msport 6MT
Retired - 2000 M52TU 323i ASA Supercharged 5MT
More photos of my car here
Old 01-17-2013, 06:45 AM
Alan
What was originally posted in the other thread was using an entirely different HUD FDL Code, not these KOMBI FDL codes.
- BMWCCA #446923
- flick
Old 05-21-2013, 03:04 PM
andreo andreo is offline
Mein Auto: F13 650i Coupé
Daytime Instrument Cluster at Night
Shawn, do these codes still work with the 6WB cluster?
Old 05-21-2013, 03:25 PM
Sorry, I do not. I haven't bothered testing it as I am fond of 6WB the way it is.
- BMWCCA #446923
- flick
Old 05-21-2013, 03:33 PM
Ok noted. Thanks.
Old 05-21-2013, 06:11 PM
Mein Auto: 550i
Ok noted. Thanks.
If somebody sends me a 6WB I am willing to test it extensively
JEG23
2011 550i
Old 05-21-2013, 06:22 PM
JEG23
Lol. Very tempting.
Your NV background pedestrian detection codes worked flawlessly btw. Excellent write-up. Will try to post a video of the results soon. People here need to know how good a job you and others have done for cars with NV, which until this point has remained turned off most of the time for my case.
Thanks a bunch. :thumbsup:
Old 05-21-2013, 11:09 PM
TurboBusa TurboBusa is offline
Mein Auto: Lexus LS400
If coded correctly will this daytime instrument cluster work on the E70 (X5)?
