M52 328I Camshaft Timing Please Help ! - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 01-14-2013, 03:10 PM
BMWM52 BMWM52 is offline
Mein Auto: 98 328I
Exclamation M52 328I Camshaft Timing Please Help !
Hello I recently replaced a head gasket and now im having issues with the timing of the camshafts. I see that there is these 2 dots on the back of both of these cams. But I am wondering how to time them correctly? I recently read on another forum that it has to be at a 45 degree angle and on one of my manuals it says I need a special tool because they need to be facing upwards.. someone help, I would really appreciate it. Also if you need me to take photo's I can upload them and show you what I mean.. but anyways thanks
Old 01-14-2013, 03:39 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
you need the timing tool as the cams are machined to spec. these are not easily timed without the tool, and the tool saves a lot of time.
df
Old 01-14-2013, 05:50 PM
Mein Auto: 98 328I
Yeah thanks for the info, really appreciate it! But as I was torquing down the bearings to the camshaft A3 bearing that holds the camshaft snapped, what i mean is that the the screw where the nut is suppose to go just snapped! I was really sad and about to cry.. is there anyway I can take out that screw to where the bolt goes to hold down the camshafts..? Or am i going to have to go to the junk yard and find a new/used head, let me know! thanks
Old 01-14-2013, 06:15 PM
how in the world did you manage to do *that*??
are you using a torque wrench??
df
Old 01-14-2013, 06:31 PM
Mein Auto: 98 328I
Yes I was using a torque wrench, I set it to 9ft/lb and as i was waiting for the click to tell me its torqued, it just suddenly snapped
Old 01-17-2013, 07:58 AM
durtyMD durtyMD is offline
Mein Auto: '98 328is
Dude I'm sorry to hear that.
This is the place most people start for headgasket replacement and everything that goes along with it (including camshaft removal and replacement).
http://www.pelicanparts.com/bmw/tech...ead-Gasket.htm
I hope you can use an drill extractor to get the snapped bolt out of the hole. Otherwise you're looking at a new head
Old 01-17-2013, 09:19 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
7 - 9 lbs is hand tight. Don't use a torque wrench, especially when doing valve cover gasket replacements.
