F30 / F31 / F32 / F33 (2012 - current)
The sixth generation 3 series, chassis code F30. 2013 model year 328i and 335i sedans now in production. Read the F30 frequently asked question thread for all your basic question and dive into all the details in the ultimate F30 information thread. |
F30 320i vs 328i engines - Part number comparison
BMW has just announced a new entry level F30 3 series, the 320i. The 320i shares the same N20; TwinPower single turbo, twin scroll, 2.0 liter inline 4 cylinder engine as the 328i. The 320i is factory rated at 180 hp at 5,000 RPMs and 200 lb-ft of torque from 1,250 RPMs. Stacked next to the 328i with 240hp at 5000 RPMs and 255 lb-ft of torque from 1250 RPMs and the obvious question is what is the difference in the two engines. The first obvious answer is there is something in BMW's DME control software that limits the power, most likely by limiting boost pressure, on the 320i. That appears to be true as both the 320 and the 328 use the same DME hardware (PN - 12148604210) and the same engine control system MEVD 17.2.9. With a software tweak the likely difference between the 320i and the 328i we go in search of other changes that might limit the 320is ability to make the same power the 328i N20 puts down. Read more about the 2013 BMW 320i entry level 3 series The next easy target is the intake, exhaust manifold and turbo. Surprisingly they turned out to be the same part number. In fact the 320i and the 328i share the exact same part numbers for a majority of the engine components. Shared engine components between F30 320i and 328i
See what is missing in the above list? The difference in the 320i and the 328i is the pistons. While both have a 10:1 compression ratio the 320i has a different part numbers for the pistons then the 328i. What that exactly means in terms of the ability to boost the turbo pressure and get 328 horsepower from your 320 is not yet known. Stay tuned as we continue to sift through BMW's technical documents searching for an answer. Last edited by tim330i; 01-18-2013 at 11:12 AM. |
WOW! So there's some serious potential to turn things back up in this car then!
If you could get to 210-220hp with a similar boost in torque with a Stage 1 upgrade, this car just got a whole lot more interesting to me.
Steve 2012 E70 X5d (IT'S HERE!) Deep Sea Blue / Sand Beige, Premium, 3rd Row, Multi-Contour 2011 E93 335i Deep Sea Blue / Oyster, Step, Premium, Convenience (PDC & CA), and that's it more pics here |
What's the bore & stroke between the engines?
From your list there are lots of areas for lost power & response from these: -smaller diameter throttle body -smaller or non straight intake manifold runners -smaller diameter airbox -lower flow CFM air filter -smaller intercooler -non dished pistons -crankshaft with a lower stroke -smaller exhaust manifold/turbo -non polished or ported cylinder head Seems like they are limiting power via less air & a controlled less powerful combustion. Plus the turbo recovery and cooling are more crippled. Last edited by av98; 01-17-2013 at 05:36 PM. |
Are we sure it's 10:1. Here's the difference in the short block description
328i Short Engine N20B20A 1 11002297079 only in conjunction with 320i For vehicles with Low compression engine S858A=Yes <== what is this? 01 Short Engine N20B20A 1 11002297079 |
isn't starting w/a lower compression engine better for swapping in a big honk'n turbo?
![]() (of course that would only be coupled with greatly increasing for the airflow both in and out ; just wanted to frame it with that) Last edited by m8o; 01-17-2013 at 08:21 PM. |
Basically we'll have to rely on a vendor to engineer an exhaust manifold and plumbing, or swap in from another engine/year like they do on the Audi's A4's, which have a similar setup. I checked the 745Li (IIRC), which is a turbo'd v8, but the header flanges are different and it may not even be an "upgrade". Intra-make part upgrade/swapping is not a new concept, but in the case of turbo's it requires knowing the subtle differences between the parts. Back on-topic, I think the OP was incorrect, but I'm open to be proven wrong. I hope I'm right though cuz I'll be pretty pissed if it's just a tune
So I'm really curious about the pistons. That could either be no big deal or big freaking deal when it comes to turning the power up. Why swap them? The biggest reason I can think of is cost-savings OR greater rotating mass efficiency through a different crown design or ring pack design. But it's not like the regular n20 is some inefficient beast - so neither of those really makes sense to me except perhaps cost-savings achievable by using a lower quality piston because you are running so much less dynamic compression against them with the detuned engine.
If I'm totally off base then the 320i is going to be the entry-euro-tuner's delight. No forced "lines", cheaper, and an engine ready to play in the ~260whp range on pump gas. |
There is defnitely a difference in compression ratio. The 328 is 10:1 and the 320 is 11:1. Thus, the higher compression 320 will knock a lot sooner than the 328, so less tunable. I've also heard that the 320 has thinner drive shafts.
http://www.bmwusa.com/Standard/Conte...fications.aspx The 320i gets different part numbers for the rear half shafts, but it doesn't look like the 328 shares half shafts with the 335i either. So you could say the 328i shafts are thinner then the 335i. I have no idea if that is true or not, but you see my point. Tim |
Tim |
![]() Tim Last edited by tim330i; 01-18-2013 at 08:28 AM. |
Check post #6 here: No official quote from BMW, but rather a BMW tuning company in SA.
http://www.bmwfanatics.co.za/showthread.php?tid=39504 |
Makes sense I guess. That means that you'd need a thicker head gasket or something to decrease the compression ratio to really be able to turn up the boost. Not the end of the world but not as simple as a software flash.
Tim |
According to RealOEM the 328i N20 piston (11257618811) is no longer manufactured http://www.realoem.com/bmw/showparts...70&hg=11&fg=20
The bmwusa configurator says the 320i base weight is 3295lb, so with the same N20 engine as 328i(3410lb, 8AT), where is the weight reduction coming from? Also, detuned N26 is not available on 320i, which is odd since N26 should benefit BMWNA on the PZEV footprint. This may mean N26 is either too expensive, or, N26 cannot be tuned(disappointing!).
Yep I did your statement wasn't very clear. Which still makes the important specs on the engine valid- bore, stroke, compression- what are they?
328i: Engine Type/cylinders/valves per cylinder TwinPower Turbo/Inline 4/4 Displacement 1997 cc Bore/stroke 3.3/3.5 inch Nominal output hp/rpm 240/5000-6000 Max. torque lb-ft/rpm 255/1250-4800 Compression ratio 10 :1 320i: Engine Type/cylinders/valves per cylinder TwinPower Turbo/Inline 4/4 Displacement 1997 cc Bore/stroke 3.3/3.5 inch Nominal output hp/rpm 181/5000 Max. torque lb-ft/rpm 184(250) / 1250-4500 Compression ratio 10 :1 Last edited by namelessman; 01-18-2013 at 11:20 AM. Reason: fixed copy-and-paste error |
I have feeling the data on BMWUSA.com is wrong.
Fixed copy-paste error in previous post, thxs. Bore/stroke/compression ratio still the same on both data sheets.
The datasheet also says 320i 8AT has 250 lb-ft, which is almost the same as the 328i. So it seems the only difference is really 60+HP.
Footnote Figures in ( ) apply to vehicles with 8-speed automatic transmission. Nominal output hp/rpm 181/5000 Max. torque lb-ft/rpm 184(250) / 1250-4500 |
Unfortunately, here's what I *think* happened. I have an email out to BMW to comment.
2012 MY 328's have 10:1 N20's tuned low 2013 MY 320's have 11:1 N20's boosted low ~2013 MY 328's have 11:1 N20's boosted high (see my post about piston being discontinued) This would mean that BMW would put the same engine with the same CR in both 320 and 328. Makes sense for simplicity sake. The bad thing (for 328 owners) is they will already be tuned high (most likely more boost from factory). So, from BMW's perspective 328 owners can no longer piggy back to ~335i power, but 320 owners can piggy back to 328 power. This is oversimplified, but hopefully you get the idea. If a "legacy" 328 needs a new piston all 4 will be replaced with the 11:1 CR ones and a software update. This whole setup means that BMW has to only maintain 1 set of pistons and two tunes. Not 2 sets of pistons and two tunes. One way to confirm without digging into the engine is to check new vs old 328 boost pressures, which is probably where they would make the adjustment (like a piggyback). This is all speculation, but might be worth looking into deeper. EDIT: This jives with namelessman's post. Power increase from boost would primarily be seen in the HP range. Last edited by Ronin951; 01-18-2013 at 12:04 PM. |
#25
Is HP = torque x rpm? Since the torque specs on both are similar(at least for 8AT), so maybe the difference is to taper the engine rev on 320i N20 at 5000rpm to throttle at 181hp, but allows 328i N20 to keep pushing to 6000rpm and 240hp. I guess we would see dyno charts soon enough on this. For now, 328i does appear to be a $2k-3k(expensive) factory tune versus 320i.
As tim330i noted, the bmwusa data can be incorrect too, or else it would really be odd that 320i N20 MT only get 184 lb-ft@1250-4500rpm .... |
| Tags |
| 2013 3 series, 2013 320i, 320 vs 328, bmw, bmw f30 320i, bmw news, bmw part numbers, bmw parts, f30 328, f30 news, f30post |
