Old 01-17-2013, 05:21 PM
rb25det rb25det is offline
Mein Auto: bmw 323ci
Electrical malfunction has this ever happen to anyone
I have a video to show what's going on. Its on YouTube under "vid_20130117_183344" 1st I have the key in between off and accessories, then I turned it to the off position, the I turn it back to accessories where it should be, then prime, then start, but as you can see I turn it back to prime and the car is still running I can even take the key out and the car will stay on. "BTW the bleep was a text". Does anyone have any idea what's going on?
Old 01-17-2013, 05:22 PM
MMME30W MMME30W is offline
Mein Auto: Bimmer
How old is your battery?
Old 01-17-2013, 05:26 PM
Not old at all
Old 01-17-2013, 05:29 PM
Mein Auto: Bimmer
Well, if the battery is ok it might be worth checking the ground and positive connections are clean and tight.
Or it may be something within the key cylinder/actuator. Hard to say.
I honestly dont recall seeing many issues like this.
Old 01-17-2013, 05:36 PM
Actuator? Well to have the car completely off I have to either disconnect the battery or leave the key in the half way position but then I can't take the key out. If I take the key out eventually everything turns on as if I'm about to start the car, even the a/c turns on too. I've had to jump start the car 3 times since this issues because I forgot to disconnect the battery.
Old 01-17-2013, 06:56 PM
scottjoh scottjoh is offline
Mein Auto: 1999 323i
Ignition switch assembly is bad.
