E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
Electrical Nightmare
Hi All, i have a BMW 323i 1999 auto with tiptronic recently the electronics started playing up first it was my wipers that worked only when they wanted to, then my passenger airbag light started appearing, then my radio went dead and i have a telltale light saying there is a problem with my transmission how can all these faults be possible or could their be another explanation, any help will be so much valued.
How old is your battery and what shape is it in?
your Guess is as good as mine, i think it came with the car
can n battery really cause those problems. i just had a look the battery seems to be and old one i do think it was the original it came with from the factory
Yes batteries can make our E46s work in funny ways. Get a load test done at Autozone or something. I would just replace it as PM. It is time!
x2! malfunctioning batteries make these cars schizo.
Thanks! lol I will replace it ASAP and keep you up to date on what happend
I have replaced the battery. And all went well for about 2 days. There where no lights, then exactly they same happened again can it be the alternator?
Yes, continuing to drive a car on a failing battery can damage the alternator as well. Get it tested ASAP.
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
I'm slowly loosing patients. I tested the alternator. And it charges perfectly. I don't know this car is driving me mad any ideas?
Full details (as always) here: - One user's experience debugging a half-dead instrument cluster (1) which, after testing the fuses (1) battery & alternator (1) thankfully turned into an alternative battery search (1) and a simple battery replacement DIY (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
Battery question
Fast Bob do you think it is necessary to get the expensive BMW batterys over something else?
Hey guys thanks for your advice. But I replaced the battery had the altenater checked but still doing the same thing I did find how ever when I put all the electronics on and fiddle wit the lights it seems to reset itself for a while so everything goes dead but after a while the same happens again
Edit: Here's the link http://forum.e46fanatics.com/showthr...469&highlight= See post 5 in the link
2008 335i 2001 325i retired 2000 M Roadster Imola Red retired ![]() 1998 Z3 2.8L retired Last edited by The Other Tom; 01-18-2013 at 12:34 PM. |
No need to pay dealer prices !
Does anyone know where I can get a wiring diagram for my car??
Ok I have established I have a earth fault I think as when I put hi beam on the lights go dead but I'm lost with out a diagram. How do I trace all the earth points and how do I test them
What do you mean earth fault? Explain further and maybe I can tell you how to approach this.
There are diagrams in the Bentley manual. |
Earth fault means ground. He thinks he has a bad ground.
2008 335i 2001 325i retired 2000 M Roadster Imola Red retired ![]() 1998 Z3 2.8L retired |
Fault also refers to a short circuit. I'd want to know what he meant with more details.
| Tags |
| 323i, electrical faults |
