My car misfires
When I turn on my car, it idles rough and I try to give it a little gas but when I step on the gas pedal the motor does not respond. When the car is finally warmed up the idel goes up to normal which is right under 1 RPM. A frined of my told me to idel the car at 4000 RPM to check the cats but I could not get it up to 3000 RPM. The idel kept going up and down up and down while I was pressing on the gas, then the car misfired a couple of times. I did notice when I was driving, I could not get it to move more than 20 mph and my check engin light was flashing. I have looked for vacuum leaks and I have found nothing. Could it be the AMF or the throttle body. Anybody got any ideas? Thank You for your help.
Sounds like a vacuum leak. Vac leaks are hard to find without smoke test. You can take apart the intake boots and look for a tear. If you find nothing, take the car to an indie who is a BMW expert and get a smoke test.
I myself have never encountered a flashing check-engine light - but I would take it seriously if I were in your shoes. At the very least, I'd invest $25 in a scanner. - Cheapest CAN OBDII scanner on the net that reads DTCs, pending codes, & clears codes In addition, the OP needs to read this thread: - How to diagnose a BMW E39 engine misfire (1) & a cold-engine intermittent misfire (1)
