E46 (1999 - 2006)
Old 05-21-2008, 04:26 PM
henry_desmond's Avatar
henry_desmond henry_desmond is offline
Mein Auto: 08 BMW 335i cabrio
Brake, ABS, and DSC lights come on randomly
I have a 2000 323i and from time to time the Brake, ABS, and DSC lights come on but, then when I cut the car off and get back in the DSC and ABS light will be on but they disappear after about 20 seconds. This has been happening since I bought the car in april. I haven't had any problems with stopping the car but if I slam on brakes really hard all 3 lights will come on. I looked in the owners manual and it says if the ABS, DSC, and brake light come on then the car has a brake system failure. I have noticed that the car does need brake pads, and the steering wheel shakes when slowing down(which may mean it needs new rotors also). What do you think?
Old 05-21-2008, 05:29 PM
nabhan007 nabhan007 is offline
Mein Auto: '99 323i
I'm not sure what you expect to hear. If your oil light was on and there was a low level on the dipstick, would you ask if you needed something other than replacing the oil? Your car is telling you that something is wrong with the braking system, and shot pads/rotors would definitely account for that. You'll still be able to stop the car as long as the rotors and what's left of your pads can make contact, but if you put off replacing them then soon it'll be metal on metal and you'll warp your calipers as well, which will significantly increase your repair costs. Keep ignoring it and you'll lose your brakes altogether. Since you need properly functioning brakes to safely drive the car, get it done asap. The wiki has a few links for mail order parts (~$300 for four sets of rotors/pads/sensors), or you can try your local indy or stealership.
Old 05-21-2008, 05:50 PM
toddkageals toddkageals is offline
Mein Auto: 2012 335i Sport
This could be something as simple as a wheel speed sensor causing the problem. The problem is determining which one. If one of the wheel speed sensors quits reading the stability control system and anti-lock system can't function. That's why you get the warning lights. The shaking steering wheel COULD be rotors but it could as be an issue with a tire or worn suspension bushings or loose wheel bearings, etc. Do you feel pulsation in the brake pedal? Sometimes warped rotors will cause the pedal to pulsate as the brake pads are pushed back and forth. The question is somewhat irrelevant since BMW recommends replacing the rotors every time you replace the pads. However, I don't always do that. You just need see how bad the rotors are worn before you decide. I doubt the lights are being triggered by the pads and even the rotors are not likely. It's much more likely to be an electronics problem (wheel speed sensor, abs computer/pump, etc.). I think BMW dealers can check to see what triggered the lights but I am not sure if the independent repair shops have access to the necessary equipment. I'd pull each wheel and check the sensors to make sure there is nothing obvious (gunk on the sensors, loosely mounted sensor, etc.). You DO need to find out why it's vibrating too. None of the conditions that could cause it to vibrate are good in terms of safety. Good luck.
Todd
Todd
2008 335i
Old 07-23-2008, 11:34 AM
DWeiske DWeiske is offline
Mein Auto: 323CI
Brake, ABS and DSC lights randomly come on
Mine have randomly turned on and as described by H. Desmond, turn off when I shut the car off, or they will turn off about 20 sec. after operation. It seems worse after rainstorms, but I could be mistaken. My mechanic had changed my brakes and rotors about a year ago, and checked them recently to find nothing wrong with them. Did you find out what caused this?
Thanks,
DW
Old 07-23-2008, 12:42 PM
jsonli jsonli is offline
Mein Auto: 330ci
has either of you disconnected the battery lately? i put my terminal back on snug-ish, but not tight, and it caused weird electrical issues.
Old 07-23-2008, 04:17 PM
Mein Auto: 323CI
Brake, ABS and DSC lights randomly come on - battery
No I have not touched the battery since it was replaced ~ 3 years ago.
Old 07-23-2008, 04:30 PM
la528it's Avatar
la528it la528it is offline
Mein Auto: 2000 528it
Yup this is classic. You may have a faulty speed sensor, but the trifecta usually means your abs module is shot. Unless you are under warranty, DO NOT go to the stealer for this. There are many places online where you can buy a repaired unit with core exchange. This happens somewhat frequently on the aging e39 which seems to use a similar abs module.
Old 07-23-2008, 04:35 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
It's much more common for it to be a wheel speed sensor than the ABS module on the E46.
Old 07-23-2008, 04:36 PM
la528it's Avatar
Does that result in all three lights firing up christmas style though?
I have heard nothing but good about these authorized bosche repair facility with lifetime warranty:
http://www.bba-reman.com/
or you can repair them yourself, some guidance for a similar module is here:
http://www.volvoforums.org.uk/showthread.php?t=7414
basically the solder cracks and needs touching up
Old 07-23-2008, 04:53 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Yes.
Old 07-23-2008, 05:08 PM
la528it's Avatar
Yes.
Fair enough. If you have a code reader, you could figure out which one it is, or you can follow the bare knuckle DIY path:
http://forums.bimmerforums.com/forum...d.php?t=600452
For us it is typically the front right that fails. Often you can see the small unit busted open with debris inside.
hope this all helps!
Old 07-23-2008, 06:38 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
All of that info is in the E46 Wiki, by the way .
http://www.bimmerfest.com/wiki/index.php?title=BMW_E46
Old 10-21-2008, 05:05 PM
323ivabeach 323ivabeach is offline
Mein Auto: 2000 323i
This has happened to me before, and I used some some electrical connector spray to clean a wheel speed sensor. That worked that time. While I have not got around to checking anything yet[ will do that when I get home from work], I am bothered that the brake light is red like when I have the e-brake on. I think, but am not sure, that this was the case last time. I have read that when all three lights come on that they are all yellow. Am I in trouble here?
Old 01-06-2013, 12:35 PM
Unfortunately, the wiki doesn't give the pinout for the E46 (which is slightly different than the E39 apparently), so to flesh out the solution for the E46 owners, I just opened this thread today:
E46 ABS control module harness wheel sensor pinout for the ABS/BRAKE/DSC bi trifecta
Old 01-18-2013, 07:23 AM
rawbspear rawbspear is offline
Mein Auto: 2004 325XI WAGON
I bought a 04 325 xi with 121.500 on it last week. I test dove it for an hour around san francisco and had no problems. I then take it skiing last sunday and got a horrible vibration during acceleration under load. I also got a hard pull to right when i hit the brakes at speed. This pull was hardly noticeable during test ride yet i practically jumped laned when i hit hard at 75mph. I took the rig to my local Performance car shop Wednesday and they aligned the wheels and balanced the tires. Vibration gone and pull gone. Then last night, i get the ABS System fail light. I had noticed something weird a couple times with the right front. It seems to lock up and let go a couple times in the snow. Crossing fingers its that sensor. ps i am new here to this forum guys. Love it thank you!
Old 01-18-2013, 09:17 AM
The quick test for the hall effect sensors takes only about five or ten minutes, and you don't even have to lift the car or unbolt anything.
All you do is disconnect the harness and test the four sets of holes, one set for each connector.
For the E46 pinout, look here:
The test procedure is here:
- How to diagnose the BMW ABS BRAKE DSC/ASC trifecta (1)
Old 09-09-2013, 04:25 PM
E46_2000_323i E46_2000_323i is offline
Mein Auto: 323i
Hi, I'm new to this forum and I am having the same problem as henry_desmond. My 2000 BMW 323i (E46) has the trifecta lights on for nearly 8 months now. The car only has 58k miles on it. It started intermittently and now the lights are on every time I start the car and stays on while I am driving. I've read alot of comments posted by bluebee in the E39 thread. Unfortunately, the pin outs for the E46 ABS/DSC module is still unknown and I still can't find it. Since, I have the car up on front 2 wheel for changing oil I've decided to look at the front wheel sensors. I know this will bypass testing the wire leading from the connector at the wheel to the ABS/DSC module. I have the sensor disconnected under the wheel well. Unlike the E39 the wheel sensors on the E46 has 3 male pins. So, how does one do a DMM diode check with 3 pins? Typical a diode only has a positive and a negative terminal for forward and reverse bias. Here is a picture of my wheel sensor connector and pins. Sorry, the 2nd image is not focus but you can see the 3 male pins.
ID:	396059   Click image for larger version
Old 09-09-2013, 04:50 PM
personally, i would pull all the sensors out of the hubs and clean them really well. thats where i would start; They can get gummed up and not work properly. MY right fron waw really bad and causeing problems though i never got the light tree you are describing.
