Old 01-18-2013, 10:25 AM
SP4RT4N SP4RT4N is online now
Mein Auto: 01 E39
New guy needs help with a headlight problem.
Hey every one. I have an 01 BMW that I just bought. And I need new headlight so I can pass a lamp inspection. Lol, to my surprise each headlight is about 700 for aftermarket ones. I was wondering if:
A.. I can borrow some ones for about an hour.
Or b.. Any one can point me to the right direction of headlights for really cheap.
Or even c.. Is there a retrofit to put halogen headlights on and take out the factory hid.
I have the factory hid headlights with amber turn signal is that means anything. Thanks everyone for your help!!
Sent from my SCH-I535 using Tapatalk 2
Old 01-18-2013, 11:22 AM
gonzilla's Avatar
gonzilla gonzilla is offline
Mein Auto: 02 540iT, 96 Carrera
These are cheaper:
http://www.umnitza.com/projector39-h...03-p-5659.html
Mike
'02 Titanium Silver 540iT Sport - Birch Anthracite trim, retrofitted window shades, DJ Auto Euro clear corner lenses, BSW t110 subwoofer, Dice Silverline w/DSP, lowering links. Lots of upgrades waiting in the garage for time to install
'96 Polar Silver Porsche Carrera - MY02 5 spokes, Bilstein PSS9s, Euro TT Sways, KLA Strut bar, Big Red TT Brakes, RS Motor Mounts, RS Shift kit, Recaro A8s, FVD 360mm wheel, HIDs, Big Oval tips.
Old 01-18-2013, 11:51 AM
I like the idea of the borrowed headlight - but - for a real solution - I would suggest a repair.
The stock BMW headlights were pretty good at the factory - but like many things BMW - they deteriorate at an alarming rate - due to the materials used.
If I assume your headlight is working - but not aimed properly ... I suggest:
a) Polish the headlight lens (optional)
b) Replace the broken PBT plastic adjuster (mandatory)
To get you started, I typed /headlight F3 in the besltinks which came up with this, among others:
- Headlight plastic polishing & refinishing DIY (1) (2) (3) (4) (5) & polishing yellowed taillights (1) & replacing the lens in toto (1) and all known options for replacing broken E39 late-model headlight adjusters (1)
