E36 (1991 - 1999)
Old 01-17-2013, 04:46 AM
3B2M8WI 3B2M8WI is offline
Mein Auto: 1998 BMW 328i - Avus blue
Tools for head gasket job
Anyone know a good place to rent the timing tools needed to do a head gasket job.
Also do I have to worry about anything involving timing when taking the head off? Or just when putting everything back together?
Thanks guys
Old 01-17-2013, 05:50 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
Thanks guys
If you go over to BF.c there are guys that rent them out all the time. Usually so something like $50 bucks.
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 01-17-2013, 07:19 PM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Thanks guys
Yes!! Timing is critical when removing the cams. Check out Pelican Parts writeup about how to properly remove the cams without breaking them. Once the cams are out I think you shouldn't have any problems regarding the timing. Make sure you take the head to a good machine shop and have them deck it and check your valves. I would ask a local independent BMW mechanic who they would recommend to do your machine work. If the head is not flat, you will be doing the HG again soon. Also, check out the DIY over on bf.c and use the pelican parts articles for the different stages of tear down. Make sure you label and bag every electrical connection and all your hardware. Feel free to PM me with any questions and I'll see if I remember how I did the HG on my car. Good luck
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 01-18-2013, 01:07 PM
Alright thanks guys yeah I have the pelican book with the procedure in it so I should be good but I'm sure ill have questions so ill pm you thanks again guys.
