Old 01-15-2013, 03:24 AM
civicrtype1 civicrtype1 is offline
Mein Auto: X5
One fog light working
I didn't know if the issue is intentional, but running the lights automated runs only one fog light on my Xd. Once I switch it manually and activate the fog lights, both turn on. Anyone else notice this or experienced the same situation?
Old 01-15-2013, 03:39 AM
matzaman matzaman is offline
Mein Auto: 2012 BMW X5 35d
I have the same thing. Usually its my driver side light. Occasionally its the opposite. I have my first service coming up, was going to ask about it then. BTW, I have a '12 X535d
Old 01-15-2013, 03:49 AM
sparrky sparrky is offline
Mein Auto: X5
It could be the adaptive lighting. It turns on the fog in the direction you are turning in and the off. It's annoying, but normal. And many people will tell you that you have a light out, which you'll get sick of explaining.
Old 01-15-2013, 01:16 PM
GoHawks63 GoHawks63 is offline
Mein Auto: 2011 X5 Premium
I thought the same thing when I first bought our X5.
2011 Premium X5 Alpine White/Oyster - Convenience, Technology, and Cold weather package. Premium Audio
2012 Cadillac CTS Coupe AWD Premium Collection - Black Diamond Tricoat/Ebony interior
Old 01-15-2013, 05:30 PM
alphaod alphaod is offline
Mmmmmm…
Mein Auto: '13 Range Rover S/C
Like how some cars have dedicated cornering bulbs, the BMW illuminates the fog lamp for the direction you're turning. I think I've seen the same on Nissan/Infiniti cars.
2013 Range Rover S/C
2009 X5 48i - Sold
Old 01-15-2013, 05:53 PM
Decboy's Avatar
Decboy Decboy is offline
Mein Auto: 2013 BMW 550i
Our X5 is the same. One fog light turns on when backing out of the driveway. Dealer said it is the parking light assists feature. I read it's the cornering feature for better visibility. Whatever it is, it's strange to activate it on the fog lights.
Read more on this here.
http://www.bimmerfest.com/forums/sho...d.php?t=501444
2013 BMW X5 35i
Alpine White | Cinnamon Brown | M Sport
2013 BMW 550i
Titanium Silver | Black | M Sport
Old 01-15-2013, 06:34 PM
boostedX5SAV boostedX5SAV is offline
Mein Auto: 2012 X5
One fog light lights up when you have your signal blinkers on as well. As others mentioned, the fog light turns on also in the direction you are turning to provide more illumination at night.
Old 01-15-2013, 08:36 PM
Mmmmmm…
Interesting as both my fogs will illuminate when I put the vehicle into reverse.
2009 X5 48i - Sold
Old 01-15-2013, 10:51 PM
tlim66 tlim66 is offline
Mein Auto: BMW X5 35d
I noticed that both fog lights comes on when in reverse at night as well. And each side individually when signalling or if the steering wheel is turned when not moving or moving slowly.
Old 01-15-2013, 11:15 PM
NoI4plz NoI4plz is offline
Mein Auto: A box with 4 circles
What your describing is not considered normal, as per the below posts.
If You are backing out straight, both fogs should activate
If you are changing the angle of the steering wheel the fogs should activate
If you have the turn signal on, the individual fogs will turn on indicated direction.
However if you are simply turn the switch to auto, and one fog illuminates, then thats an issue you should bring up at your next service appointment.
BMW and Mercedes Build Beta Products!
Lexus build Release Candidate Products!
Why does this matter?
CAUSE EVERY TIME someone says Lexus has better build quality, one should consider what Toyota their Lexus Engine and chassis platform comes out of and how long that part has been tested in the real world!
Old 01-16-2013, 02:16 AM
Mein Auto: X5
(Scratches head).......what?
Old 01-16-2013, 10:06 AM
The ifs are the situations where ur fogs should activate. Are you describing in ur op any one of the situations?
If yes then normal, but if ur talking about, the vehicle sitting, in park, steering wheel centered, turn signal off, and headlights in auto and only one fog illuminates that's not normal lol
Old 01-16-2013, 10:31 AM
Mmmmmm…
If~
Your wheels are pointed straight
AND your switch is set to Auto
AND you don't have a turn signal one (not caution blinkers)
AND you don't have the wheel turned
AND you're not in reverse
AND you do not have fog lights manually turned on
If all of the above is true, the fog lights should not come on.
2009 X5 48i - Sold
Old 01-18-2013, 11:57 AM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 535iX M Sport; X5 35D
Did they stop shipping owners manuals with X5's? This is all explained on page 112 of my 2011's manual.
Current BMW's:
2011 535xi M Sport TiAg / Black, ZPP, ZP2, ZCV, ZCW, ZDA, 2TB, 6NR, 465, 5DL, and a Partridge in a Pear Tree
2011 X5 35D Deep Sea Blue / Oyster, PP, SP, PSP, CWP, Tech, 20" 214's
Prior BMW's
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Sport
Old 01-18-2013, 01:41 PM
BMW Power's Avatar
BMW Power BMW Power is offline
Mein Auto: 2012 X5 35d
And so it is:
Adaptive light control*
The concept
Adaptive light control is a variable headlamp
control system that enables dynamic illumination
of the road surface.
Depending on the steering angle and other parameters,
the light from the headlamp follows
the course of the road.
In sharp curves, e.g. serpentines, or during turning,
up to a certain speed one of the two front
fog lamps* is switched on as a turning lamp. This
provides improved illumination of the area inside
the curve.
Controls
Activating
Switch position with the ignition switched
on.
The turning lamps are automatically switched
on depending on the steering angle or the use
of turn signals.
Standstill function*: to avoid blinding oncoming
traffic, the Adaptive Light Control directs light
towards the front passenger side when the vehicle
is at a standstill.
When driving in reverse, both turning lamps are
active.
I also remember reading this feature can be turned off by coding the vehicle.
2012 X5 35d DSB - Prem, SAV, Cold, Sound, Tech packages, Apps Delivered 6/6/12
Retired 2011 335d AW, M Sport, Premium and Convenience pkg, Heated Seats, Nav, HK, iPod/USB, smart phone. ED 8/31/10
Retired 2008 335i Coupe 6-speed Manual, Montego Blue, Sport, Premium, CW, Nav, PDC, AS, Shade, HD, Sat, Ipod/USB, Logic 7, CA
PCD 11/07
Retired 2004 545i Sapphire Black/Black 6-speed Manual, Sport.
