Old 01-18-2013, 12:51 PM
Brian425 Brian425 is offline
Mein Auto: BMW X5 50i
Dinan Intercoolers
I currently have the Dinan stage 2 tune on my 12 X5 50i. I am considering adding their intercoolers. Has anyone installed the intercoolers? What were your real life experiences? Power gains, consistent power without heat soak issues, etc.
Old 01-18-2013, 01:07 PM
RockChips RockChips is offline
Mein Auto: 2008 X5 3.0si
I hope you are using quality fuel
Old 01-18-2013, 01:45 PM
BeamerandBimmer BeamerandBimmer is offline
Mein Auto: MG M4
I would make that assumption, but what do better intercoolers have to do with good fuel. As a matter of fact you could probably run a lower fuel quality with better intercoolers.
Current BMWs
2016 Azurite M5(Almost Here)
2015 Mineral Gray M4
2010 R1200GS Adventure 30th Anniversary Edition
2016 S1000XR
Past BMWs
2014 S1000R
2013 Carbon Black X5 50i M-Sport
2010 Alpine White 135i M-Sport
2010 Carbon Black M5
2007 Graphite K1200GT
2008 335ia
2005 545i
2004 R1150R
2003.5 M3 Cabrio
2000 540ia
1997 M3 sedan
1997 540ia
Old 01-18-2013, 01:51 PM
I was addressing the tune he already has.
Old 01-18-2013, 01:57 PM
Heat soak is always an issue with turbos and even more so when you try to make more power. By reducing the intake air temperature, you effectively add more oxygen allowing you to make more power. I am curious if people are seeing real power gains and more consistent power.
Old 01-18-2013, 03:59 PM
I alway buy the best fuel I can. In general, I buy Sunoco 93, or the highest octane I can find at the pump.
I also try to avoid stations that appear run down. If they let the outside look like crap, I do not trust them maintain high standards storing and pumping their fuel.
Old 04-15-2013, 08:56 PM
philooo philooo is offline
Mein Auto: 2011 X5 5.0
I'd be curious to hear if the car runs cooler with the intercooler.
My car has the fans on full blast all the time each time I stop to a light.
Phil
'11 X5 50i M-Sport
19" Black Saphire | Black | Alu | Lux Seat | Adaptive | Cold | Tech | Sound | Prem | Comf Acces | combox retrofit | Invisihitch oem harness
Old 04-15-2013, 09:27 PM
Intercoolers will not help engine tempature. They cool the intake charge allowing a more dense air/fuel mixture to be forced into the engine. The better intake charge will give you a little more hp. The big gain is more consistent hp.
It is a common issue for any forced induction vehicle to lose HP on very hot days or if in stop and go traffic or racing.
Back when I was racing, turbos and superchargers were just getting popular. It was common to leave the turbo guys on the line spooling up as long as possible. The idea was to have them build up as much heat as possible ("burn them down). (Better intercoolers and mutliple turbos has made this less beneficia; but, it is still real.)
If you want to drag race you X5 50i, the right way to stage you vehicle is to pull up until you light the first amber, build boost and bump in (edge forward) to light the second amber. The other racer will know what you are doing and will be able to stage his car properly.
