E36 (1991 - 1999)
Old 01-11-2013, 03:27 PM
Marine Guy Marine Guy is offline
Mein Auto: E36 1995 325i
Wht type of coolant does a 95 BMW 325i need?
Sent from my VS910 4G using Bimmer App
Old 01-11-2013, 04:34 PM
SCJon SCJon is offline
Poet of Signature Quotes
Mein Auto: 1997 BMW 328is
G-05 Zerex or BMW brand coolant. Only ones I would consider.
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
Originally Posted by petriej View Post
So let it be written, so let it be done.
Old 01-11-2013, 04:44 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
And distilled water. If theres green in it now, flush it with distilled water before you put the G05 in
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 01-11-2013, 06:55 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Mercedes coolant is also perfectly acceptable, and the same price, just depends which is closer to you.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 01-18-2013, 05:32 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
Mercedes stuff in a BMW?
Now I remember why we pick on you...
Old 01-18-2013, 06:19 PM
Jakobie1086's Avatar
Jakobie1086 Jakobie1086 is offline
Just a kid with a toolbox
Mein Auto: 330ti
Yo just saying pretty much all modern coolant is safe for aluminum, regardless of the color. Ace hardware brand coolant says safe for aluminum, and the the peak anti freeze I'm using now is also safe for aluminum. Both are green. I suggest doing a coolant flushes, and I also REALLY suggest using distilled water to mix 50/50 but the color of the anti freeze means nothing.
Old 01-18-2013, 07:13 PM
jonesin's Avatar
The Canadian Prick.
9 times in 10 the green stuff is Prestone or other non-aluminum safe coolant. Hence saying if you go with the right stuff, it'll likely be blue or pink.
Chadling, my roommate has 3 Merc's. If I need some coolant and he has some kicking around no point in heading over to our $tealership or spend my money...
Old 01-18-2013, 08:40 PM
dc_wright's Avatar
bimmerfest Supporting Member
Many of the "aluminum safe" claims depend totally on mineral free distilled water being the other part of the 50/50 mix so that there is no reaction between the phosphate/silicate additives and the minerals in the water with the aluminum. You may be able to use regular phosphate infused green coolant mixed with distilled water without any issues, but if you get in a jam out on the road and need to add some water and don't happen to have a jug of distilled water handy, now you've got a problem. If you are running a phosphate free coolant (G-05, BMW or Merc brand) and you have to add some tap water in a jam you're OK.
Old 01-18-2013, 09:50 PM
Woodacre tom Woodacre tom is offline
Mein Auto: 330 rag 328i
Flush it out with clean water, pour in 1 gal of BMW coolant and a bottle of red line water wetter, top it off with water and you are good to go.
Make sure you bleed the system!!
Old 01-18-2013, 10:04 PM
jonesin's Avatar
The Canadian Prick.
Originally Posted by Woodacre tom View Post
Flush it out with clean water, pour in 1 gal of BMW coolant and a bottle of red line water wetter, top it off with DISTILLED water and you are good to go.
ftfy.
Old 01-19-2013, 11:22 AM
john kaminski john kaminski is offline
Mein Auto: 1994 325i
If you have a dehumidifier, you have a source of distilled water as long there is no metal that rusts to contaminate the water -- I am Cheap
Cheap Trick
Old 01-19-2013, 11:49 AM
southpark11235's Avatar
southpark11235 southpark11235 is offline
Mein Auto: 1999 BMW 323is
^Wow, you just saved a whole dollar with only a few hours work.
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
//1992 Mazda Miata - cat delete, power windows, oil filter relocation
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 01-19-2013, 02:33 PM
drive by72's Avatar
I feed trolls
Mein Auto: 3 series
hey now, he has a point! If you have a dehumidifier running anyway, why not use that water? Think, if you're flushing the system, assume 5-6 gallons for a good thorough flush, and to add to the coolant. That's 6 bucks, plus gas to get to Walmart to get it. I'll take my 6 bucks and get subway instead
Old 01-19-2013, 03:47 PM
dc_wright's Avatar
Not quite. Unless the dehumidifier has a HEPA rated filter it pulls in dust in the air which gets trapped with the condensate and winds up in the water trap. Unless you're filtering the water you're adding microgrit into whatever you're putting your "distilled" water in....
