Old 09-02-2012, 11:25 AM
7Figurez's Avatar
7Figurez 7Figurez is offline
Mein Auto: 2005 745I
Seat occupancy sensor disable Using NCS
If anyone is having the issue with the seat occupancy sensor, you can code this option out using NCS. Once you code the seat occupancy sensor out of the SSFA module you can clear the errors and the airbag light will remain off.
Change this in the SSFA or SSBF depending on the seat sensor that is failing:
FOR SSFA
BELEGUNGSERKENNEUNG_FA
sbe1
TO:
keine_sbe
FOR SSBF
BELEGUNGSERKENNEUNG_BF
oc3
To:
keine_sbe
Old 09-02-2012, 01:42 PM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
Is one driver side and one passanger? Will restraint system have any issues in an accident or any other problems? I have a light for driver side on.
Sent from my Motorola Electrify using Bimmer App
Old 09-02-2012, 03:48 PM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64/5, Maserati GT
Nice job!
650i sport hud ac schnitzer eibach resognator delete m6 quads akebonos
Old 09-02-2012, 03:57 PM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
Great post!!! Move it to DIY section!
Old 12-02-2012, 10:44 PM
mjquake mjquake is offline
Mein Auto: 02 745i
i don't see any of these lines in either the SSBF or SSBA modules, do i have to add those lines or what. having this problem and would like to code it off
Old 12-03-2012, 06:07 PM
samadkins29's Avatar
samadkins29 samadkins29 is offline
Mein Auto: '03 745Li
Will this work for a short? My rear seat headrest go up and down whenever they feel like it. Usually when its hot out.
2011 535i
2003 745li (Sold)
HID Guide
LED Guide
ABS/DTC Guide
Old 01-18-2013, 03:26 PM
badziewo badziewo is offline
Mein Auto: BMW 750i
Angry
Hi
Would you please help me with the seat occupancy sensor?
I did use NCSXEPERT to upload the SSBF module file.
Then I modify the file FROM: BELEGUNGSERKENNEUNG_BF oc3 To: BELEGUNGSERKENNEUNG_BF keine_sbe, Load the file back to SSBF module.
After that the light for Passenger Airbag went off for 20 sec and then the light come back. So then I reset the SSBF module with INPA. Went back to NCSEXPERT upload the SSBF module again and notice that the file is back to original, the keine_sbe is missing and the OC3 is back. I did it 2 more times with the same effect.
Can somebody help me with this?
2006 BMW 750i
GURTSTRAFFER_BF
aktiv
ZK_MIN_GURTSTRAFFER_BF
wert_01
ZK_MAX_GURTSTRAFFER_BF
wert_01
HALLSCH_EIN_GURT_SSBF
hall_ein_gurt_an
STROMGR_KS_HSCH_ZU_SSBF
wert_01
INDEXTAB_FC_SSBF
wert_01
STROMGR_AUF_HSCH_UB_SSBF
wert_01
CHECKCTRLTAB_SSBF
wert_01
ZK_MIN_AKTIVEKOPFST_BF
wert_01
ZK_MAX_AKTIVEKOPFST_BF
wert_01
TIMEOUT_ID_UEBERW_SSBF
wert_01
VERZOEGERUNG_SBE_SSBF
wert_01
LINKS_LENKER
linkslenker
PDC3_ERR_LIMIT_SAT
wert_01
GURTSCHLOSS_BF
aktiv
ALGOPARAM_SSBF_EAM
wert_10
AKTIVE_KOPFSTUETZE_BF
aktiv
oc3
ZK1_ZF_SSBF
vom_ss_nicht_beeinflusst
ZK2_ZF_SSBF
vom_ss_beeinflusst
Old 01-18-2013, 04:19 PM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
Originally Posted by badziewo View Post
Hi
2006 BMW 750i
GURTSTRAFFER_BF
aktiv
wert_01
wert_01
hall_ein_gurt_an
wert_01
INDEXTAB_FC_SSBF
wert_01
wert_01
CHECKCTRLTAB_SSBF
wert_01
wert_01
wert_01
wert_01
wert_01
LINKS_LENKER
linkslenker
PDC3_ERR_LIMIT_SAT
wert_01
GURTSCHLOSS_BF
aktiv
ALGOPARAM_SSBF_EAM
wert_10
aktiv
oc3
ZK1_ZF_SSBF
ZK2_ZF_SSBF
vom_ss_beeinflusst
Did you read the file again right after you wrote it to make sure it took the value?
Old 01-18-2013, 08:45 PM
Mein Auto: BMW 750i
Yes I did read it and was not there. But something did go in because the passenger light was off for 20 sec before I cleared errors with INPA. What I'm doing wrong?
Old 01-18-2013, 11:23 PM
DFEL750I's Avatar
Mein Auto: 750I
What you are saying does not make much sense. Maybe then module is reset when you are reading it or something. If you are writing to the module successfully there is no way for it to revert these options. Where in Toronto are you? Probably I can help you out and code it for you.
Old 01-18-2013, 11:34 PM
7Rage 7Rage is offline
Mein Auto: 2007 750Li
WTF?!?!
Old 06-07-2013, 04:26 PM
utkg utkg is offline
Mein Auto: 325i
DFEL750I
If you're in Toronto, you think I could get you to fix the srs light in my 325i (2006)? I'd pay you for your efforts. I'm in Vaughan. Let me know, thanks.
Old 06-10-2013, 12:56 PM
magicautocenter magicautocenter is offline
Mein Auto: 2003 745il
is there a way to reset air bag light and seatbelt message on by 745li without having to buy models.... both front airbag are deployed and passanger side seatbealt is locked. the rest of the airbags are good.. thanks
Old 07-11-2013, 08:52 PM
m3hk1 m3hk1 is offline
IbraCadabra
Mein Auto: Bmw 735
Quick question guys. Has anybody that's done the procedure checked if their seats are constantly occupied or not. Wondering cause if not, there's a chance airbags won't deploy properly. Or I'm a wrong?
Had the same issue with mine backseats and chose to buy bypass plugin instead.
Old 08-29-2013, 01:20 AM
moj0 moj0 is offline
Mein Auto: 530i
anyone in toronto that could code this out for me? i can pay of course for it!
Old 03-06-2015, 10:06 AM
whytry's Avatar
whytry whytry is offline
Mein Auto: '07 750Li, 68 Camaro
FOR SSFA
sbe1
TO:
keine_sbe
FOR SSBF
oc3
To:
keine_sbe
I can't seem to find those in either SSFA or SSBF... Is there something I am doing wrong here? Please advise..
06 750i - Blk/Blk, Sport pkg, premium pkg, comfort access, ent pkg, convience pkg, 21's, sold
07 750LI - Blk/Blk, Sport, Premium, comfort access, rear DVD, convenience, 21's
68 Camaro - Procharged and injected LS2 in progress
Old 03-07-2015, 06:02 AM
tmeis745 tmeis745 is offline
Mein Auto: 745
Please help me, I'm in toronto and both my passenger and driver restraint systems have restraint faults. Every time they are reset at Indy they come back several 100kms later.
Old 04-03-2015, 12:29 PM
TerraPhantm TerraPhantm is offline
Mein Auto: 2005 M3 Coupe
Anyone know if this will cause issues with airbag deployment? I disabled the driver side sensor and as expected the code isn't coming back. Would hate for the airbags not to go off properly though
Old 08-31-2015, 08:04 AM
crazyrobbery crazyrobbery is offline
Mein Auto: 95 e34 530/5
FOR SSFA
sbe1
TO:
keine_sbe
FOR SSBF
oc3
To:
keine_sbe
Worked like a charm... Thanks !
Old 09-21-2015, 07:40 AM
Adam_E65 Adam_E65 is offline
Mein Auto: 2002 E65 735i
I had the restraint system fault on my 2002 E65 735i, and I bought a bypass sensor, as a lot of people seemed to think it was a quick,cheap fix. But it didn't work for me.
Mine seats have heating, ventilation, massage and lumbar support and after some diagnostics with INPA/DIS57, it appears that the passenger seat module is faulty.
The fault was...
"SMBF -9EC6 SMBF:Active Seat, pressure switch - no signal of value ---
-Active seat B5210_60034 / Supply 02 The power supply to the seat module is not OK."
All the seat functions worked OK - movement, heating, ventilation etc - but the message would not clear even after a complete reset.
With my MOT looming fast, I was desperate to get it sorted.
After a bit more searching, and advice on seat units from various forums, I bought a second hand seat module from Ebay for 60 with the part no. 61.35-6 920 451.9 01 (61356927319)
This unit seems to have all the options available on it, including adjustable head restraint functions that mine doesn't have.
My unit old module details as appears on the unit are:
61.35 - 6 924 875.9 01
0000 0056 A9. SerNo. 000017164
Hardware C 09
Diagnosis 1105
Codier - Ind 03
MCV 0.5.17
Aend. - Ind. 01
OSV 2.3.0
Datum 37/02
FSV 6.12.0
I replaced the unit by lifting the seat to it's highest position and tilted the seat right back (not the backrest, just the seat) as you need to get as much space under the seat as possible, then I disconnected the battery.
I unplugged all the connectors (about 8 or 9) and then unclipped the old unit. Its held in with two clips at the back left and right that are released by inserting a stubby flat-blade screwdriver in between the old unit and the casing, and pulling the screwdriver head back gently to the front of the car while lifting the edge of the old unit up. It should just lift up when released. Next slide the module rearwards by 5mm or so and the whole things just comes out.
The new one goes back in easier than getting the old one out. Plug everything back in and reconnect the battery.
There is no coding required but I had to go back into DIS57 to carry out a reset. (It didn't reset on it's own for me).
Now the message has gone and seatbelt/airbag lights have gone off.
MOT passed this morning with a couple of suspension bushes being replaced :-)
And a quick note for those people that bypass the seat occupancy sensor - it may be OK for the passengers side as all the airbags will go off in the event of an accident.
However, I believe the drivers side sensor is used for other things - like locking the gearbox into park when unoccupied to stop the car driving off if you happened to get out/fall out without putting it into park first. So just keep this in mind.
Thanks to all those people that have helped me (and countless others no doubt) by taking the time to share their experiences with others, we do appreciate it.
Old 09-21-2015, 09:33 AM
dant9422 dant9422 is offline
Mein Auto: 2006 Bmw 750i
I have a passenger side mat sensor with cushion and fan assembly for sale.
Old 09-21-2015, 01:24 PM
H F H F is offline
Mein Auto: 2005 545i
The fault was...
Hardware C 09
Diagnosis 1105
Codier - Ind 03
MCV 0.5.17
Aend. - Ind. 01
OSV 2.3.0
Datum 37/02
FSV 6.12.0
Nice job,, well done ..
Old 05-26-2016, 03:27 PM
Gdoggt Gdoggt is offline
Mein Auto: 2004 BMW 730i
Help Me Please - Seatbelt fault
FOR SSFA
sbe1
TO:
keine_sbe
FOR SSBF
oc3
To:
keine_sbe
Are you saying that doing this will cause the vehicle to not see the rear seat sensors as though the rear does not even exist to the vehicle or it will trick it to believe the seats are always occupied? I am having a constant fault saying the rear right and left seatbelts are stuffed as well as the drivers however there is nothing wrong with them. I just want the damn lights to go away. Can I simply tell all of the sensors to shut up somehow?
Old 05-26-2016, 03:29 PM
What was your issue exactly and how did this fix it? I am wondering if I can address my seatbelt fault issue in the same manner.
Old 05-26-2016, 05:27 PM
05_745li 05_745li is offline
Mein Auto: 05 745li
Could you possibly tell me a step by step on how to do this. I'm new with ncs and I need this to go away
