Old 12-19-2012, 07:17 PM
stairwayto7 stairwayto7 is offline
Pittsburgh Steelers Fan
Mein Auto: 325i & 528i & 33ci
e46 studdering on acceleration
My 2001 330ci runs fine when idling but shoot her the gas, and she acts as if its starving for fuel and the transmission does not shift right.
It was running fine, but then the fuel pump went out. So I change it and the filter. Its been running like crap ever since. It thru a crankshaft position code and camshaft position code.
Ive checked all the vacuum lines and can't find a leak.
Ive changed the following: Crankshaft PS / Camshaft PS / Fuel pump & Filter / Upper & lower / Spark plugs / boots from the throttle body to the MA flow sensor (they were cracked). and cleaned the throttle body.
Please Help!!
Old 12-19-2012, 07:35 PM
scarede46er scarede46er is offline
Mein Auto: 2001 BMW 325i ZSP
Were the sensors OEM or aftermarket? Also, how old are the O2 sensors? Does it throw any code?
Old 12-19-2012, 08:11 PM
No O2 codes and Im not sure the last time they were changed.
All sensors are OEM.
Old 12-20-2012, 05:31 PM
Just pulled my secondary air pump and it is bad. I did a cold start test and it didn't come on. So I pulled it and stright wired it but didn't work.
Can this be my problem?
Old 12-20-2012, 07:14 PM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
Did you connect the fuel filter hoses in the proper places?
Old 01-17-2013, 11:09 AM
sorry so late responding but yes.
Old 01-19-2013, 12:31 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
get the error codes read. the secondary air pump only runs the first couple of minutes on cold start to get the cats going quicker so it's purely for emissions purposes. shouldn't affect performance but you will need it to be working next time you get an inspection.
