F30 / F31 / F32 / F33 (2012 - current)
The sixth generation 3 series, chassis code F30. 2013 model year 328i and 335i sedans now in production. Read the F30 frequently asked question thread for all your basic question and dive into all the details in the ultimate F30 information thread. |
#26
+1
Taking a look at the UK 320i engine specs, this is what I would expect: Engine Cylinders/valves 4/4 Capacity (cc) 1997 Stroke/Bore (mm) 90.1/84.0 Stroke/Bore (inch) 3.50/3.30 Max output (kW/hp/rpm) 135 (184)/5000 Max torque (Nm/rpm) 270/1250-4500 (270Nm = ~200lb-ft) Compression ratio : 11.0:1
2003 BMW M3 Vert | 2005 Volvo S60 2.5T | 2006 Scion xB | Past: 1986 MB 190E 2.3-16 |
#28
What is unclear now is how to get the 120-lb weight reduction. Does the factory take out all the noise-insulation material to save weight and 320i is noisy as hell?
#29
electric seats rear fold-downs Different: Exhaust Drive and axle shafts Tranny Here and there you could probably pick away 120-lb
#30
2011 535i Alpine White, Oyster on black interior, Premium 1 & 2 Package, Magnaflow Full Cat-back Exhaust, JB4 Stage 2
#31
its a different transmission?
F30 335 Estoril Blue Msport with performance exhasut and black grilles
#33
So far the best ecu tunes for the n20 are below $500.
#34
From realoem the AT/MT replacement part numbers are different, can it be just different fitment into the engine bays, or different HP ratings do require reinforced components on the high HP engines?
(copy-paste data disclaimer )rear axle output shafts -- 320i: 28mm; 328i: 31mm; 335i: 35mm drive shafts for AT -- 320i: 1563mm; 328i: 1539mm; 335i:1508.5mm 335i AT: Rmfd automatic transmission EH GA8HP45Z 1 09/2012 24008601194 328i AT: Rmfd automatic transmission EH GA8HP45Z 1 09/2012 24008609706 320i AT: Rmfd automatic transmission EH GA8HP45Z 1 09/2012 24008609707 335i MT: Rmfd-6 speed gearbox GS6-45BZ - THY8 1 23007617492 328i MT: Rmfd-6 speed gearbox GS6-17BG - TAU0 1 23007633990 328i MT: Rmfd-6 speed gearbox GS6-17BG - TAY9 1 23007633989 |
#35
#36
I talked with one of the piggyback vendors about the impact of 11:1. Response was there will be lower boost with "similar" power compared to the 10:1's. Pretty much as expected.
#38
Some discussions on other forums mentioned that 320i in other countries can come with a low compression option S858A and 10:1 and same 7079 part# as above, or without option S8585A and 11:1(and a different engine part #). One possibility is that the bmwusa data sheets are correct, and US spec 320i N20 is with S8585A option.
#39
So does it mean piggyback solutions can do 240HP-ish, but not 300HP? I wonder how well the piggyback ones "compliment" the factory ECU, if the ECU does not like the modified readings, would it throw a fault code or CEL?
#40
Anyone have the 0-60 time on the 320?
Sorry just saw the answer in the other thread.
2011 328xi. Space Grey, Beige Dakota Leather, Premium pkg., Value pkg., NAV, SAT, Heated SW, Steptronic,
#41
I can't speak to CEL's, etc. That's probably better asked in a separate thread. I will say if the 2013+ 328's do have a different CR, the vendors will probably have to start asking customers the MY of their 328's. |
#42
I can 100% confirm that the compression ratio on the F30 320i is 10:1. That is the same 10:1 that the 328i has.
Tim |
#43
Compression measured?
#44
#45
Sweet!
Steve 2012 E70 X5d (IT'S HERE!) Deep Sea Blue / Sand Beige, Premium, 3rd Row, Multi-Contour 2011 E93 335i Deep Sea Blue / Oyster, Step, Premium, Convenience (PDC & CA), and that's it more pics here |
#46
#47
Any updates on the engine comparisons?
#48
What other info are you looking for?
Tim |
#49
N20 Stage2 tune development is underway now.
#50
Tim |
| Tags |
| 2013 3 series, 2013 320i, 320 vs 328, bmw, bmw f30 320i, bmw news, bmw part numbers, bmw parts, f30 328, f30 news, f30post |
