Old 01-08-2013, 12:01 AM
Chico 6series Chico 6series is offline
Mein Auto: 645Ci
bmw 6 series- 22's are rubbing in the back
Can anybody with 22 inch staggered offsets tell me did they have to get any adjustments on there 6 series for the rims not to rub in the back? If so, what was done to get them to stop rubbing?
I have 235 front and 295 back
Old 01-08-2013, 12:07 AM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
I have never had rims that large, but maybe rolling in your fenders might help?
Once a 6'er, always a 6'er.
Old 01-08-2013, 12:11 AM
Mein Auto: 645Ci
what???
Old 01-08-2013, 12:55 AM
Yorgi's Avatar
Yorgi Yorgi is offline
Google "rolling fenders". Any decent body shop can do it for $50-$100. They use a device that connects to the hub on one end and has a large rollerskate-like poly wheel on the other which will roll under the lip of the rear wheel well.
Rolling is your only option, other than going for a narrower tire. This is assuming you are hitting the fender, not the shock or spring perch. Look at the rub/wear pattern on the tire to see where it's rubbing.
FYI 235 is way too skinny in the front. The car is going to understeer like crazy if you push it in a corner.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 01-08-2013, 08:17 AM
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
Any benefit to wheels that big? Seems to me anything over 20 on the e63/4 would be detrimental in a lot of ways (weight, cost, poor ride, fear of pot holes, limited quality tire choice, questionable looks.)
For those with wheels that big, what are the benefits and what tires did you get for those wheels?
Reason I'm asking is I'm on the fence between getting a couple of my stock 19 inch wheels refurbished and getting new ones.
Old 01-08-2013, 10:58 AM
Mein Auto: 645Ci
Thanks, I appreciate that info... I was thinking about changing my fronts to 245-30-22
Old 01-09-2013, 07:31 PM
BrooklynsFinest BrooklynsFinest is offline
Mein Auto: BMW 645ci
I have 22`s (22x9 front, 22x10.5 rear) I rarely have rubbing issues, occasionally when bottoming out on dips at high speeds or the angled entry into a shopping center If i have a passenger I get a slight rub but nothing that would warrant any modifications.
As Yorgi stated, getting your fenders rolled may be an option, I will do mine once I lower it. what size tire are you running? I have 255/30/22 front and 295/25/22 in the rear if that helps.
Present:
2011 MB C300: CF Roof and trunk wing, 3M matte aluminum grey/matte black USAF theme wrap.
08 Chrysler 300c stock
2005 BMW 645ci: DINAN Stage 2 software, Magnaflow Custom cat back race exhaust, AFE stage 2 pro dry CAI, GFG custom painted/CF Hydro dipped Medellin wheels (22x9 front, 22x10.5 rear) AC SChnitzer dash kit, Matte Aluminum Red with Carbon Fiber BMW performace stripe wrap, custom roundels, Yellow fogs, custom painted brake duct rings.
Old 01-19-2013, 06:52 PM
metronwk metronwk is offline
Mein Auto: 2008 bmw 650i
i switch from 295-25-22 to 285-25-22 in the rear and problem solved or if you wanna go the cheap way out then getting your fenders rolled is the way to go, but make sure you take it to someone experience bacause they can chip your paint or even buckle your quarter panel
Old 05-05-2013, 07:23 PM
TheMRSFLAGG TheMRSFLAGG is offline
Mein Auto: 650i
Hi, I'm having same problem, did you ever find a solution?
Old 05-06-2013, 04:54 AM
amennrahh's Avatar
amennrahh amennrahh is offline
BM6er
Mein Auto: 2005 BMW 645ci
I have 22s 245/30/22 up front and 295/25/22 rears. The vehicle is lowered with Eibach Sport springs and the solve all for the rubbing issue was to roll the rear fenders. Worked like a charm and havent had any issues since.
SEMPER FIDELIS
Old 05-06-2013, 06:45 AM
Mein Auto: 650i
Thank you so much!
Old 05-06-2013, 05:12 PM
bigscore bigscore is offline
Mein Auto: 06 650i
+1
when i had 22's i had a rub over dips etc...
fender roll at local indy solved the problem
$80 total
No car is quite like a BMW....
Old 05-06-2013, 07:02 PM
Originally Posted by bigscore View Post
+1
$80 total
I just changed my 22's and did a custom offset, at this point they do not rub at all unlike the occasional rub with the last set. I will now drop it an inch with confidence.
Present:
Old 05-06-2013, 09:32 PM
Mein Auto: 650i
Thank you!
Old 05-17-2013, 02:19 PM
babyboss babyboss is offline
Mein Auto: F80 M3
got the same issue with my F13 ..
cant roll rear fenders cos nothing 2 roll in - comes from factory already in !!
got 235 in front & 295 rear .. Gona try 285's @ rear & see if it works , will post once done >>
Old 05-17-2013, 02:25 PM
MELLOWYELLOW06 MELLOWYELLOW06 is offline
Mein Auto: 2012 750Li & 650i
You could have a specialized machine shop take up to 3mm off the backspacing
Old 05-17-2013, 02:28 PM
If you are going to change tires, try a brand with a rounded edge and not so square...also what are the offset of the rear wheels? Since you cannot roll them you may want to grind them down and flare them...that worked with my Mercedes with no lip to roll even though my rear wheels ran a aggressive offset.
Present:
Old 06-25-2013, 10:22 PM
thehitshop thehitshop is offline
Mein Auto: 650i
I did 22by 9 front with a 18mm offset and a 22by 11 rear with a 33 mm. and ended using a 12mm hubcentricspacer so tbe perfect fit is a 21mm in the rear by 11
Old 10-14-2013, 12:17 AM
Mein Auto: 645Ci
Got my fenders rolled and that solved the problem. Thanks for the info ^^^
Old 10-14-2013, 11:24 AM
Mein Auto: 06 650i
Great news!
Old 10-14-2013, 10:43 PM
MKLCV MKLCV is offline
Mein Auto: 6 Series Convertible
22x9.5 245/30/22 up front 22x11 285/25/20 in the rear no rubbing at all. Gonna lower soon. I'm sure rolling fenders will solve.
6 series- 645ci, 650i
