Old 01-17-2013, 10:27 AM
verbals verbals is offline
Verbals
Mein Auto: 2002 BMW 745i
@sardoc ... Hahaha!!!
Old 01-19-2013, 12:27 AM
KingSilverback KingSilverback is online now
The Silverback
Mein Auto: 2006 750Li
I've always wondered how you would go about coding an L7 AMP to a car, what software do you need?
Sent from my SPH-L710 using Bimmer App
Old 01-19-2013, 02:52 PM
SFbay SFbay is offline
Mein Auto: BMW 745i
That's why this forum sucks...
You help ppl and you get nice "hahaha" response. Prob if you spent 1-2k at the stealer ship to resolve this problem you would think very different. And believe me some ppl did spent this amount to resolve simple issues.
Old 01-19-2013, 03:03 PM
The Silverback
What pisses me off the most is people who don't bother searching before asking a question, when 9 times outta 10 that question has already been answered or it's a sticky. I don't know why some of you people buy these cars without doing proper research on them.
Old 01-19-2013, 03:38 PM
First_745Li's Avatar
Mein Auto: 2003 745Li
+1 - Repetitive threads should be answered " use search function" then mods should close it. It's so annoying to see new threads regarding the same topic.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 01-19-2013, 03:53 PM
The Silverback
Yeah every damn day someone posts a thread about their speakers crackling when a search could answer all that
Old 01-19-2013, 07:23 PM
resistro resistro is offline
Mein Auto: 740
http://www.bimmerfest.com/forums/showthread.php?t=671068
Got a similar problem trying to diagnose MOST bus.
http://www.bimmerfest.com/forums/sho...d.php?t=671068
Here's my problem:
"BMW" is only displayed (PIC#1)on the navigation screen (unless I break the MOST fiber loop-more info later). Wont do anything! No radio, chime, voice control, ect.
I tried that trick to bypass modules (ASK CD player, Voice Controller, CD changer, L7 Amp, Tuner) to exclude them from the MOST bus but not seem to be gaining any ground. I took that factory fiber loop from the glove box to bypass these modules.....
FYI: I did not have to purchase a spare, I just took the loop connector apart and connected the two end together (the fiber ends in the glove PIC #3)-this seemed to do the trick. It seems if ring bus is broke the red LED does flash, when connected red LED stays light. I took the actual fiber optic line out of the connector housing and used it for bypassing.
......1) when I used the 'fiber loop' to bypass any the modules in the trunk and including the ASK or CD changer in the dash (PIC #5), nothing happens. 'BMW' logo will still be displayed on the screen.
2) when i take any of the modules out of the network ring (unplugging ANY of the modules-not 'bypassing' anything) I DO GET the 'accept' prompt on the nav display (PIC#7) and can navigate through some functions but can operate only the climate functions. No Nav(PIC#8) or radio (PIC#9), chime, ect. I can only scroll through.
3) I also tried that trick to go into the MOST diagnostic screen (PIC#10), but nothing comes up under the 'MOST' menu. Again, the only way can control anything on the Nav display is when the MOST fiber ring is broke. If I try to connect the fiber ring back together at that point, it will just freeze on whatever is display I have up.
4) Nav disk DVD does seem to spin and eject fine. Although I have noticed it will still spin when the ignition is off.
5) Dash CD player seems to a spin the CD, but no sound of course.
6) CD changer tries to eject a the cartridge. But it never worked anyway.
7) All the modules seem to be transmitting light via the fiber.
Basically, the 'BMW' logo stays on when everything is connected and I cant do anything.
I got my whole car torn apart and need some advise on what to do next?
Do I need some software to reset the ghost errors after bypassing each module?
Old 01-20-2013, 06:50 AM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
Here's my problem:
You took the fiber optic loop from the glove box to bypass the modules? By taking the loop out of the glovebox you just broke the fiber optic ring and nothing will work...that's why you have to get a separate loop to bypass the modules and leave the one in the glove box in place.
Old 01-20-2013, 09:23 AM
Verbals
Wow. I guess I really pissed the gods off. I did do several searches ... on the forum & google. My issue at the time was I didn't even know what I was searching for. Once again, thank you all for the replies that helped me resolve my problem. And for those who think I am ruining the forum for one reason or another, I apologize.
Old 05-04-2013, 12:53 PM
Mein Auto: 740
Porblem solved
http://www.bimmerfest.com/forums/sho...t=#post7324530
