E36 (1991 - 1999)
Old 01-12-2013, 03:57 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Get 4 springs, 2 shocks, and 2 struts.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 01-19-2013, 09:39 PM
bmw_novice bmw_novice is offline
Mein Auto: E36 328is
Hello again all,
Just got the valve cover gasket and starter done. Now for the suspension. Was wondering - I use the 328i as a daily driver, but since I am TOTALLY confused about the spring issue (one is broken in the back and I don't know if I have the M tech suspension and therefore would need an mtech spring or 4 new springs altogether), what if I do something like the raceland coilovers?
Seems like a nice inexepensive deal for a vehicle that rarely goes above the 3.5-4k rpm mark?
What does one need to install these? Is it any more difficult than say the installation of 4 shocks/springs?
Thoughts?
Old 02-13-2013, 07:05 PM
Well, the time for a suspension fix is close:
The car tends to now slowly move to the right on a straight road, thought I might as well get everything done now. Can anyone tell me if used springs for the rear are a good idea:
http://www.ebay.com/itm/271146649656...84.m1438.l2649
Since the above are just OEM springs would I need sport shocks or would touring/normal ones do?
or how about these?
http://www.ebay.com/itm/181072091607...84.m1438.l2649
Would these need sport shocks since they will lower the rear by 35mm?
Btw, any feedback on Vogtland springs? If I do front and rear shocks I was thinking of using these.
Plus:
front control arm bushings and ball joints (outer)
swaybar links + bushings (rear too).
Rear shock mounts, bump stops etc..
Anything else I need to replace while the above is being done?
