Old 01-04-2013, 11:03 PM
nycmashimaro nycmashimaro is offline
Mein Auto: 2005 745Li
Coolant Leak, Weeping Hole, Coolant Pipe issue/repair - BMW NA needs to recall/fix
New here to bimmerfest.
I have search the web and read several threads on this and just wanted to make a thread to get word out there and try to rally owners and make BMW NA aware of this major issue and get BMW NA to do a recall/repair.
Different names used for this issue: Weeping hole, coolant leak, coolant pipe
BMW part# for seal and water pipe: 11141439975
I am having the issue for my 05 745li. Im trying to fight it with my warranty company to pay for the repair and i just opened a case with BMW NA.
Not sure has anyone that has open a case with BMW NA hear any updates on this issue?
-by the way, i spoke to the rep at BMW NA and the rep told me if enough owners call up BMW NA it might start a recall/fix.-
so owners please call up BMW NA and open a case and complain to the "resolution reps/supervisors."
BMW NA - 1800-831-1117
just call up and give them your information and open a case and state that you have the issue with the leak / damage water pipe. you can give them the part # also.
Last edited by nycmashimaro; 01-05-2013 at 07:21 PM. Reason: added more information
Old 01-04-2013, 11:34 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
Why is your extended warranty company not covering it?
Old 01-04-2013, 11:45 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Tell me what to do, who to call where to sign and I'm game.
Old 01-05-2013, 12:15 PM
@csmeance - they are not counting that part as part of the engine or engine cooling in their listed cover parts, even though i have seal and gasket coverage. the seal is damage on the water pipe. i have compass / american guardian.
Old 01-05-2013, 12:24 PM
Mein Auto: Nothing
Will do!
Old 01-05-2013, 01:53 PM
First_745Li's Avatar
First_745Li First_745Li is online now
Mein Auto: 2007 Audi A8
What if you don't have the issue yet or don't know you have it yet.. I think we should all call
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 01-05-2013, 02:00 PM
Mein Auto: Nothing
I am sure we all have the issue to an extent, obviously everyone is running above 105 here.. I am betting 80% of E65's are running above 105c.. so we all have the issue, and we can all call in and complain..
Old 01-05-2013, 06:15 PM
Kickback6 Kickback6 is offline
Mein Auto: 745i
I'm down. Give me more info
Old 01-05-2013, 07:22 PM
just call up and give them your information and open a case and state that you have the issue with the leak / damage water pipe. you can give them the part # 11141439975
Old 01-05-2013, 08:19 PM
First thing Monday morning!
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 01-05-2013, 09:30 PM
Mein Auto: 745i
We should re post this up as a new thread
Old 01-05-2013, 09:44 PM
csmeance's Avatar
Mein Auto: 760Li
it's def. part of engine cooling at COOLANT FLOWS THOUGH IT and it's WITHIN THE ENGINE! I'd escalate your claim because it's not a hose that's leaking, but a seal that's on a COOLING PORTION of the engine that connects to the motors. It's not a leaking pipe, but a leaking seal on the PIPE!
Old 01-05-2013, 11:11 PM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
Some seals and gaskets are not covered on extended warentee, I know that the one I was offer and bought thru carchex was not covered and why I went ahead and dropped them and got my money back.
I strongly agree that this item should be recalled by in my case I replaced the tube and gasket with the more advanced AGA pipe, and I am sure that this repair even I'd recalled will not be covered. My repair cost about 2300.00 and the way BMW has to repair the car will cost way over 8k because they have to remove the heads to install a new pipe into the block.
This is a huge problem with all n62 engines including the x5 and some range rovers that used this BMW design.
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 01-05-2013, 11:55 PM
@sirstopher and any other owners that did the repair -
even though you did the repair, you can still call to complain, maybe they will reimburse or if it does recall you can swap out the aftermarket. just takes 1 call to ask for a supervisor and start the case/complaint.
thanks to all
Old 01-06-2013, 12:01 AM
Mein Auto: Nothing
thanks to all
Personally I think I would rather have the AGA then the original.. originals are failing at 75k+, that AGA looks pretty nice, I am hoping they have a strong design..
Old 01-08-2013, 08:21 PM
how long does AGA last for? What is the warranty on AGA? is it more than 60k-75k miles?
Old 01-08-2013, 09:14 PM
DriftGirl DriftGirl is offline
SideShow activist
Mein Auto: 745Li
http://www.change.org/petitions/bmw-...eep-hole-issue
Lets see how many siggies we can collect to forward to BMW as "One LOUD Voice"
When / IF mine goes south, I'll be using the aftermarket unit for sure!
Current Lineup:
BMW E31: Air suspension,19x10 / 19x11 Trafficstar
BMWE38:Air suspension,20x10 / 20x12 Forgiato (SOLD)
BMWE65: 22x10 / 22x11 Asanti ELT (SOLD)
Lexus SC400: Single turbo, 19" SRR wheels
Lexus GS300: VIP , Air Suspension,19" WORK wheels
S13 Silvia: WideBody, JDM conversion,SR20det,15" WORK wheels
Lexus LS430 UL:Air Suspension, 20"MAYA DLS
Old 01-09-2013, 08:14 AM
I called and spoke with a rep named Kyle, gave him the information and said that this would be a design complaint which would be documented and reviewed internally. Not sure what that means at this point.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 01-09-2013, 09:02 AM
BMW7_CEO's Avatar
BMW7_CEO BMW7_CEO is offline
BMW7_CEO
Mein Auto: 05 745LI 06 650i 06 330xi
All we have to do is call BMW NA and give them what kind of info or will the Representative ask you the info required ?
Old 01-18-2013, 10:06 PM
just give them your vin and stating that you have problems with your water pipe and give BMW NA the part number also
Old 01-19-2013, 06:40 AM
Emeer18's Avatar
Emeer18 Emeer18 is offline
Mein Auto: BMW 745Li
Originally Posted by cmpcpro View Post
tell me what to do, who to call where to sign and i'm game.
+1
Old 01-20-2013, 12:23 AM
BMW7_CEO's Avatar
BMW7_CEO
Alright bro ima definitely do it and do you know the part number exactly ?
Old 01-20-2013, 06:06 AM
M4XBMW7's Avatar
M4XBMW7 M4XBMW7 is offline
TTurboFest
Mein Auto: F02 (750Li)
Weeping Hole, Coolant Pipe issue/repair. This recall should have been made years ago as owners suffer from an internal engine leak (from damaged water pipe seals), Commonly known as the "weep hole" coolant leak. BMW part# 11141439975
on the 5-series, 6-series, 7-series, X5 and some Range Rover
Old 01-20-2013, 02:47 PM
BMW7_CEO's Avatar
BMW7_CEO
Alright I got it thanks bro ima call them soon
Old 01-20-2013, 03:13 PM
Ultimate745i Ultimate745i is offline
Ultimate745i
Mein Auto: 2004 745i
I'm new here, but wanted to say that if you end up having to pay for repairs, that they have some sort of kit now that reduces the repair costs by thousands. I have a mechanic that use to work for BMW for 14 yrs and now has his own shop that did mine for $1200 (including kit). I'll text him and find out what/where the kit can be obtained.
Fun Doesnt Come Cheap!
bmw na, coolant leak, coolant pipe, recall, weeping hole
