Old 01-19-2013, 08:46 PM
Jeff Kirkley Jeff Kirkley is offline
Mein Auto: 330i
Satnav Radio issue
Hi, my radio/satnav cuts in and out after about 1/2 an hour. And yesterday it shutdown the
whole screen display, when we came back after a while it was working again.Is this a common unit problem?
Is it possible to upgrade with a later version unit?
Old 01-19-2013, 09:02 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Before you even think about the expensive pieces: How old is your battery?
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 01-20-2013, 03:08 AM
Banned
Mein Auto: 2007-335 HTC
unless things have changed, When the car is running, all the accessories are running off of the alternator, and to check to see if the alternator is working, when the car is running, with a Digital Volt Ohm meter, put the red lead on the batt positive terminal and the black on a ground and you should read 14.7 volts, or what ever the output of the alternator is. This should have nothing to do with the battery
Hondo
Old 01-20-2013, 07:23 AM
Zeichen311's Avatar
Aging batteries are well-known to trigger all sorts of electronic mayhem on late-model BMWs. Ruling out a tired battery is a worthwhile first step when diagnosing any bizarre behavior of this sort.
