Old 01-20-2013, 12:36 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Fuel filter replacement
Hey guys, I am trying to replace my fuel filter.. it's original, and I have 132k on the clock.. The problem is the hose clamps don't have regular ends on them, they are a weird, almost broken looking end.. how do I remove these? Do I need a special tool? Thanks
Old 01-20-2013, 12:45 PM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
I suggest getting them off by any means and immediately having replacements with a standard bolt or screw before you put the new one on. Mines were practically rotted beyond recognition when i did mine a little while back.
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround
.. more updates to come
PREVIOUS 2002 745i
Old 01-20-2013, 01:57 PM
Mein Auto: Nothing
Thanks, I'm done now, orig filter shows date of 07 07 2003 so it's def. original.. I realized the orig hose clamps will allow you to remove them with a flat head but they are shaped to where you can't tighten them again.. unless you use pliars.. I had some BMW clamps that would have fit but theyre designed for a double layer coolant hose (all our coolant hoses are hoses in another hose) and they have some spikes that clamp into the outer layer so I didn't trust them and had to reuse the orig. clamps but I was able to tighten them nicely so they are fine.. I am anxious to see if the car runs any better.
I also bought all new O-rings uppers and lowers for all of the fuel injectors, I figure I will replace those too, and now if I have to remove the intake to replace the secondary air hoses I will probably do the coolant pipe and o-rings while I am at it.
Old 01-20-2013, 02:51 PM
rideme2's Avatar
rideme2 rideme2 is offline
rideme2
Mein Auto: 2006li bmw
Where the fuel filter located?
2006 750li K&N Filters Giovanna Kilis on 265/30/22 305/25/22 HID fogs 6000k Mtec angel eyes all lights 6000k ACS front lip,ACS rear wing,ACS rear window wing.dual exhaust working qual tips, rear camera, upgrade DVD to front watch jl13.5t sub with jl500/1v2 amp power cap.PassPort 9500ci,CrossDrilled&Slotted Rotors with EBC Brake Pads.Rear comfort seats, Fully loaded from dealer. Next mod iPhone hookup, .
Old 01-20-2013, 03:44 PM
dannyb1027 dannyb1027 is online now
Mein Auto: White 2002 745I
drivers side undercarriage. if you use the D/S mirror as a gage.
Old 01-20-2013, 03:46 PM
rideme2's Avatar
rideme2
Kool THX
