BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#51
Anyway Shawn, from another thread i saw that you did change the sport auto shifter. Does changing the shifter alone affect the way how the transmission shifts? Or is it just the s1 - s7 coding that affect the gear changes?
I am really interested on doing the paddle shift retrofit as well. And do you have any idea on how doable it is to do that? Is it as simple as running cables from the shifter to the paddles on the steering or is it something much more complicated involved? Ps: Sat shifters and sport steering wih paddles are not my concern anymore. |
#52
Your posts on Bimmerfest.com and Bwmcoding.com are always very helpfule to me.. For example, http://www.bmwcoding.com/showthread....h-to-icm/page2 I'm the member of BMW F serise club in Korea and I firstly introduced e-sys coding to F club. I found this this value for S1~8 display on 20. July, 2011 http://cafe.naver.com/5series/67991 (Sorry, You need registration to read the posting in Korea) I think, 'mongsiri' is one of F club member. ![]() Thank you again!! Last edited by Donghoi, Kim; 02-18-2013 at 06:46 AM. |
#53
And if you get to Okku-Silver Town, give all the girls my best.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® |
#54
Only Sportschalter_alt needed on my 520d 4/2011 to make it work. I don't have sports trans nor M options..cool find.
F10 520d born 11.04.2011 Deep Sea Blue 205, 230, 322, 403, 415, 423, 428, 430, 431, 459, 464, 465, 494, 502, 508, 522, 524, 534, 548, 609, 614, 615, 620, 644, 654, 676, 698, 851, 879, 962, 1CA, 1CB, 1CD, 2K1, 2PA, 3AG, 4AT, 4UR, 5AC, 6AA, 6AB, 6FL, 6NF, 6NR, 6VC, 8KA, 8TF, 8TL, 8TN, 8V1 |
#55
I have only automatic 205 in gearbox. EGS / 3000 Applikation Sportschalter_alt = nicht_aktiv Sportschalter = aktiv Now it (S1-S7) works, but I do not know whether it's right or not? |
#56
If it is working, it is right. Some have to change only one, and other have to change both.
#57
code an 2013 535i today, had to change both Sportschalter_alt and Sportschalter to aktiv / Werte=01
#59
I checked my '12 M sport and both of these are enabled by default. I do have the SAT option w/ the paddle shifters. Not sure if that helps w/ whether to activate both or not.
#60
To anyone who is interested in coding this on a F30 (I have a sport line non M), the result sort of changes how sports mode is entered and how it behaves; I have modified as
Sportschalter_alt = nicht_aktiv Sportschalter = aktiv or both active and I could not tell any difference, with just sportschalter active you will be able to see S1-7. Before the modification, with both not active, DS is displayed in sports mode and if you tab the control lever left or return it to normal position, sports mode or comfortable mode is selected automatically. After the coding, with either with just Sportschalter active or both active, taping the lever to the left or normal position does not automatically select sport mode or comfort mode, instead, it will active the S1-7 display and put transmission (and transmission only) in sports mode. And after you manually select the mode through buttons to the left of the lever, the rest of the car goes into sport mode. (steering, accelerator etc. ) Please correct me if I am wrong. |
