Tranny fluid leak at bottom of the pan - Bimmerfest - BMW Forums
Old 01-20-2013, 05:31 PM
Fingrassia Fingrassia is offline
Mein Auto: 535i sport package, 325CI
Just bought a 2004 325CI convertible. 100K miles
As a long time BMW owner I'm very pleased with this car, but when I changed the engine oil I noticed the bottom of the tranny pan was wet and blowing back on the exhaust.
I'm fairly confident it is tranny fluid.
When I purchased the car I reached underneath the car to check for any leaks after a test drive and there were no noticeable leaks. Unbelievably it is not hitting the driveway or garage floor.
The car was sitting on the BMW dealers lot for around 45-50 days.
Does anyone have any thoughts as to where to start looking for the source of the leak.
Old 01-20-2013, 06:02 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
Make sure it is tranny fluid. Do you have an automatic? If so, I would not drive it long without fixing that- once you confirm. Your description is typically an engine oil leak spreading back across tranny pan.
Old 01-20-2013, 06:07 PM
Yes, it is an automatic transmission. I will put it back on the jack stands and verify the fluid.
Old 01-20-2013, 06:18 PM
Oil Filter Housing Gasket (OFHG) or Oil Pan Gasket are two typical suspects.
Old 01-20-2013, 06:34 PM
Thanks, I will pull the bottom cover off and check the (OFHG).
