Old 10-23-2012, 12:46 PM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW E65 745i
Surely you have TV option in the USA? Your saying even with the TV option you can't code video in motion?
Trying to code video in motion with no actual video source..... That would be rather pointless.
Old 10-23-2012, 12:51 PM
Originally Posted by cn555ic View Post
He clearly stated he inserted the DVD into his DVD navigation slot. Maybe you are correct in saying the navi player might be different than US models but I still don't think so. The module he speaks of is the MMI and not the MMC
All he comfirmed was that he does not have a DVD changer or CD changer but he does have a DVD navigation system.
He didn't say he put a DVD in the NAV drive, (unless I missed it!) he just said he has coded video in motion, which means he must have a video/TV module.
Which is the same as me, I have a digital video module which is now enabled to work while I'm driving. I don't have a DVD changer. (But I do have a DVD NAV! Lol)
Stuart
Old 10-23-2012, 12:52 PM
cn555ic cn555ic is offline
The Coder guy in N.Y
Mein Auto: bmw
Well there might be some confusion then as I don't know the location of the person who posted. Correct there needs to be a source to play the DVD and he stated he used the navi player And it worked. I tried on two cars with no RES and put DVD into navi player And nothing. In fAct it wouldn't even read it as a readable source. US models don't have DVD navi in which it can read and play DVD movies. Maybe there needs to be module installed, I don't know. Need to find out where he lives to confirm its a Euro spec vehicle
If it was my coding that was the problem, I wouldn't have been Able to code 2 cars that had RES and allow video to show in the front Navi screen, so that confirms my files are correct
Old 10-23-2012, 01:01 PM
I think you have just misunderstood what he was saying, there is no way on earth that the NAV drive will play a DVD video disc, that's not what it's intended for.
I bet he has just the video module like myself.
This is mine, fitted it yesterday!
Have you been trying to code a car with no DVD or video module to play DVDs from the NAV drive?
All this coding does is removes the warning message on the MMI when you engage drive or reverse.
Basically saves you the hassle of installing that cheap Chinese crap to the MMI CAN bus interface to alter the CAN messages. And is free of course!
Stuart
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Mein Auto: 2007 760Li
He said he has DVD navigation, but never said he put a disc in and played it. I think that was just extraneous information.
And, no, there is no TV option in the USA. The digital broadcast signal is different and no module is available to support it in a car.
Old 10-23-2012, 01:07 PM
Mein Auto: bmw
Stuart
Stuart. There probably is some misunderstanding for sure, but its clear there needs to be a video module added to car for this to happen and the US spec cars do not come with it.
Old 10-23-2012, 01:09 PM
Mein Auto: bmw
Thank you. Got my answer so I can put this to sleep! Lol
Sucks that US based cars doesn't come with this feature.
Old 10-23-2012, 01:17 PM
That's right, I didn't realise the US spec models didn't have TV, I recall someone saying you could get analogue at some point? We have loads of analogue tuners over here in the UK, they are 100% useless now as the transmitters have been switched off.
Hence why I got the hybrid module, they are scarce and expensive!
How does the DVD video interface connect to the MMI? I'm sure it has to route through the video module?
With no rear entertainment it's a CVBS signal to the video module, then switched to the NAV, with rear entertainment it's CVBS to the video module then RGB to the MMI, also NAV now outputs CVBS signal to video module instead of RGB to MMI.
Anyway, glad we got that cleared up!
Old 10-23-2012, 01:29 PM
SuperSnoop's Avatar
You can code TV_VIDEO_ABSCHALTUNG from aktiv to nicht_aktiv to enable video on the front screen while parked. I'd test that before bothering to disassemble and edit the module code for video-in-motion.
Old 10-23-2012, 01:42 PM
Mein Auto: bmw
Already tried that. US based models do not work
Old 10-23-2012, 04:33 PM
***CCCP***'s Avatar
***CCCP*** ***CCCP*** is online now
Major
Mein Auto: 745 li
Do u have RES?
Old 10-23-2012, 04:55 PM
Mein Auto: bmw
Originally Posted by ***CCCP*** View Post
Do u have RES?
No he does not, hence this is what this discussion was all about...I was able to code in Video in Motion with cars that have RES...I was mistakenly told that it would work without RES so I tried to code a car yesterday without RES.. It doesnt work and was told it can but now we realize the person that told me had Euro specs and not US specs which does not have video module.
Old 10-23-2012, 05:56 PM
***CCCP***'s Avatar
Major
Mein Auto: 745 li
Ok got it
Old 11-04-2012, 09:30 AM
rippjd rippjd is offline
Mein Auto: '05 745i / '00 740i
Based on my research, 2002 - 2005 North American spec E65/E66 with RES were built with an analog TV tuner built into the video module. Hence the owners manuals list TV as a source for the rear seat passengers. For 2006 - 2008 the TV tuner was removed and RES cars were built with a video switch.
I do not have RES, but I retrofitted a Euro analog TV tuner / video module and can watch video in motion... though it's mostly static as analog signals are rare in NA.
Later I added the DVD changer and now video in motion has more purpose.
2005 745i Individual
Old 11-22-2012, 11:38 AM
styles83 styles83 is offline
Mein Auto: bmw x3
Help me Exx coding
cn555ic hello my name is angel on the advice of shawnsheridan I decided to contact you for help how to install upward upward pc (Exx) coding I've also downloaded the latest version of sp daten. can you give me directions ... thanks
Old 12-20-2012, 12:24 PM
bluecrab bluecrab is offline
Mein Auto: 2011 328i xDrive
Where did you grab the latest daten files? I'd like to code some stuff on my E90 LCI but all of my files are dated 2010 (my car is a 2011).
Old 01-20-2013, 06:40 PM
07jace750li 07jace750li is offline
Mein Auto: 750li
Yes I can but you have to have the cable and the programs working on your laptop...If you dont have the programs, I do offer services to configure the laptop for people which takes about an hour or so, but I dont like doing because its a PITA to configure it.
I'm interested on your service to configure my laptop I'm in NYC area thank you and let me know if your around NYC!
