X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here. |
#676
Good question. I have no idea... so I did a quick search... seems quite nice.
The engine is made by VM Motori, an Italian engine manufacturer owned by Fiat. DISPLACEMENT: 3.0L (182 ci) CONFIGURATION: 60-degree, even-fire V-6 ENGINE WEIGHT: 498 pounds BORE AND STROKE: 83 mm x 92 mm (3.26 in. x 3.62 in.) COMPRESSION RATIO: 16.5:1 ENGINE BLOCK: Compacted-graphite iron (CGI) casting that weighs 159 pounds, featuring four 14mm head bolts per cylinder BEDPLATE: A one-piece, 35-pound assembly retains the crankshaft and ties the bottom of the block together with six 12mm bolts per main bearing CRANKSHAFT: Forged 4140 steel with 74mm (2.91 in.) main bearing journals and 67.5mm (2.66 in.) connecting rod journals, externally balanced CYLINDER HEAD: Aluminum castings with four valves per cylinder VALVETRAIN: Dual overhead camshafts (DOHC) with roller finger followers and hydraulic lash adjustment VALVE SIZE: 28.5mm (1.12 in.) intake, 25.4mm (1.00 in.) exhaust BASE POWER RATING: 221 to 268 hp at 4,000 rpm BASE TORQUE OUTPUT: 369 to 421 lb-ft at 2,000 rpm MAXIMUM ENGINE SPEED: 4,800 rpm FUEL SYSTEM: Bosch common-rail injection with a CP4.2 pump and CRIN 3.4 solenoid injectors capable of running up to 29,000 psi (2,000 bar) and seven injection events TURBOCHARGER: Electronically controlled variable geometry with water-cooled ball-bearing cartridge in high-power applications
My new Porsche site Flat6News http://flat6news.com/ I am fortunate to have unique press cars delivered weekly, but I own: '13 Audi Q5 2.0T Quattro 8AT '86 Porsche 911 Turbo 4MT Gone, but never forgotten... E70 X5 35d, E90 335i, E46 330i, E36 328i, E70 X5 3.0si, E53 X5 3.0i. ~~~~~~~~~~~~~~~~~~~~~~~~~ Find my work on Autoblog or on my new Porsche site Flat6News! |
#678
I'm not sure how much exposure motori has had to top level emissions regulations, and we all know it caused issues with early BMW, Ford, etc.
Motori has been making diesels for a long time, even the Jeep Liberty came with a 2.8L motori for a while and although the vehicle is nothing special, diesel enthusiasts (bargain hunters) snatch them up regularly. The diesel world is very excited about this engine, I haven't heard a peep about reliability concerns if that gives you a sense of their dna. Jay
Herbert - '12 X5 35d / Sapphire Black / Black Perf Nevada / Aluminum trim / ZPP / ZPS / ZCW / ZAV / Apps / 3rd row Betty - '04 CTS-V / Black Raven / Black Leather & Suede / 6 speed LS6 combo 400 hp & 400 tq Sterling - '06 Silverado HD / White / Grey Leather / LBZ Duramax - Allison 6 speed combo / Crew Cab Short Bed LT3 |
#679
Fix It Again Tony. Fiat has crap quality. Always has
2011 BMW X5 xDrive 35d Vermillion Red Metallic/Black Nevada Leather Options: ZCW, ZPP, ZRC, ZTP, 300, 386, 496, 4AB, 6FL, Combox, LED Coronas. 04/11 Production |
#680
Not bad. First diesel SUV out there with the coveted 30 mpg. BMW needs to step it up for the next gen. If the diesel JGC gains traction, people will start to realize that the BMW/Audi/Porsche/MB are poor value
#681
I'll jump in here, may regret it but here goes! Chrysler has had build quality problems since the sixties, most of the time it was something other than the power plants - it was the rest of the vehicle. The rub on the BMW as I read these threads have nothing to do with drive train problems other than electronics, but at least they don't fall apart around you as you drive it! This is not a (I hate Chrysler products) reply as I have foolishly owned three at various times of my life, each time I spent a lot of time dealing with many niggling issues. JMO By the way, I don't think they faired so well when they were part of DB.
#682
The VM Motori is owned jointly by Fiat and GM(!) it is a well respected diesel engine manufacturer with a large line of products. I had a beautiful VM inline turbo 6 in a boat that was outstanding and a quantum leap over the Ford Bedford diesel it replaced. Fiat may be "crap" here in the US but they seem to be doing nicely in the rest of the world. Remember after all who owns Ferrari, Maserati, and Alfa!
I would love to see the review on the new US spec JGC diesel (Mike?).
#683
I'm already one step ahead of you... I'm asking to drive one. - Mike
#684
which part of the world you have in your mind? definitely not in Europe
WTB: spare tire kit |
#685
Overall they seem to be doing as well as others, but no doubt there is a slowdown over there especially in Italy. Certainly F.I.A.T. is a major player there and not so much here.
Mike, will look forward to your review! |
#686
I was considering a Jeep until I wathced ""
#687
"Grand Cherokee Statement for Teknikens Varld Test Chrysler Group engineers are investigating a Swedish magazine's evaluation of the 2012 Grand Cherokee. During the evaluation, the publication was able to capture images of a Grand Cherokee on two wheels as it performed an extreme maneuver in an overloaded condition. Advised of this event by the magazine, Chrysler Group engineers made numerous attempts to reproduce the wheel-lift in a properly loaded vehicle. Extensive testing produced no such result. A subsequent evaluation was conducted by the magazine July 8 in Sweden and witnessed by Chrysler Group engineers. Three vehicles performed 11 runs on a course prepared by the magazine. None reproduced the original event. The uncharacteristic result was obtained using a vehicle loaded beyond its weight specifications. The Grand Cherokee's weight limitations are clearly stated on the vehicle and in the owner's manual. Also, the extreme maneuver performed by the magazine is not certified by any regulatory agency, nor is it used to establish any sanctioned safety ratings. Chrysler Group takes seriously any safety concerns and engineers are examining the event to better understand the magazine's claims. A "Top Safety Pick" of the U.S. Insurance Institute for Highway Safety, the 2012 Grand Cherokee is an award-winning SUV that features Electronic Stability Control and Electronic Roll Mitigation as standard equipment. It meets or exceeds all government safety mandates and its outstanding performance has made it the most awarded SUV in history."
#688
It is interesting to note that Jeep GC got a 3 star for roll over on the RWD vs. 4 stars in AWD. I guess AWD does make a difference in keeping the wheels on roll over test case.
Anyways, I am not worry about roll over in Jeep especially after it was stated to be an overloaded condition. Yeah, that is going to throw off the electronic stabilizer on any SUV or car. After all, momentum is what you are fighting against along with your chasis/suspension design. Take a look at this video. The Fiesta ST lifted its wheel as it turn very hard. (skip to 2:30 to see it in a few seconds.) Although, this is apple to orange comparisons. It does show clearly why Ford Fiesta lifted its wheel. Its suspension reached its limitation of anti-roll and resulted in lifting actions due to all the weight thrown out wards as you turn. The same occurs with Jeep. To be fair, in this case, it does look like a fun thing to do on the track. ![]() |
#689
- Mike
#690
There was a follow up video where they invited jeep engineers and they still had same problem. Also front tire blew 7 times. Not trying to pick on Jeep, I really do like this car.
Yet another advantage to AWD!
The VW GTI's were also notable for lifting a rear wheel in "spirited" mode as well. Probably still are for that matter. I did find the video of the Ford ST to be very interesting -- I doubt we will be seeing that one in the Rental Car ranks however. I wonder how one would do against a 328????
#692
Unless you do a fair amount of off road stuff I really don't see what all this Jeep love fest is all about really. Have you ever had one because I have had the pleasure twice and both were bad memories and I am really not bias to any badge but I would not touch one if they attached wings or pontoons for flying or fishing. they will fall apart well before you're financing has ended. Really....Jeep?
2012 X5 35d AW/Black Dark Burl ZAP ZAV ZCW ZPP ZPS ZRC ZTP HUD AD BMW Apps Spare Tire-Comfort Access-Running Boards-Roof Rails-335 Wheels-Auto High Beams-Smart Phone Int. Mods : Clear Bra-Radar Hard-wired So far so good-made on Wednesday |
#693
I too will stay away from Jeep. The one I had ( brand new 1999 V8 limited ) had a nice muscular engine and rather good looks and nice ground clearence, that's where the good things ended. It came with crappy leaky tires, the differentials whined and the tranny slammed since day one, all electrical windows packed up, it rolled like a baby cradle and you could see the gas needle moving. I could only stand it for 2 two years when I dumped it. I'm sure it's way better now but once burnt like that and never again. There are better choices.
#694
Chrysler
If possible, I try not to give my hard earned money to a company that requires a government bailout to survive.
#695
--Aaron |
#696
#697
I am not going to defend Jeep -- but a lot has changed since 1999. If anyone told me that Hyundai/Kia would be serious players in the US market then I would have laughed at them. VW was one step up from Junque back then, Audi was almost ruined and the two BMW's I had (3 & 7 series) seemed to spend more time in the shop than on the road. In the automotive world things do change. According to what I have been able to read and observe (admittedly anecdotal) the new Jeep GC is light years better than the preceeding versions. Some of this has to do with Mercedes brief stewardship of the brand during which the new version (and the Durango) were developed alongside the ML and GL class, and the rest due to serious QC efforts. I am a bit of a MoPar guy -- my first 'rod was a '28 DeSoto Roadster with a '53 Dodge baby hemi shoehorned in -- so I have a fondness for the line. I am also a pragmatic sort and like to check everything out before i commit the coin. I am going to look carefully at the new Jeep diesel because it might be just the answer for me.
#698
- Mike
#700
Thought I should bump this thread. lots of new stuff
![]() http://www.freep.com/article/2013022...sey=nav%7Chead This green is gorgeous! Quote:
| Tags |
| diesel, porsche, x5 |
