Discussion pertaining to the flagship BMW here. |
key fob
niether of my key fobs are not working can anyone help?
Have opened them up and changed the battery's ?
its sealed and cant open it without breaking it
What model of BMW, does the key fob plug into the dash? As they should recharge when plugged in.
It would be a bit strange for them not to come apart to allow battery change? |
2003 745i
http://www.ehow.com/how_6245682_open...6-key-fob.html
Try this link |
ok thanks i will
try tapping(finger flick) on the fob itself while holding it in hand...sometimes that helps and it works...your batt is recharging everytime your car is running so thats why they dont come apart
on mine the unlock wasn't functioning...opened it up and microswitch was broken off...had to re-soldered it back on the board and voi'la ![]() and there is microswitch that broken off
I have an 06 750i. the key fob was working fine. now sometimes it does and others it doesn't. Could it be the battery and if so, can it be replaced ?!
It's probably the button, do you get a low battery warning when you plug the key into the car?
Entamean
If you search on google how to fix BMW 7 keyfob it will show you what you need to solder to repair the fob |
Thank you. I will try that. Actually, now when it does it, I tap it with my finger hard and it works. ?!?!
