Noisy Alternator when idling - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 01-17-2013, 06:30 PM
CraigBMW CraigBMW is offline
Mein Auto: 1995 525 E34
Hi,
my alternator makes a loud rattling, almost grinding noise when the motor is idling. It is silent when the rpm increases and functions well. Can anyone suggest a remedy? Thank-you.
Old 01-17-2013, 06:32 PM
BMWFatherFigure's Avatar
Old School
Bearings worn out. Hope for your sake you fix it B 4 the internals touch and spread steel dust through the works. REBUILD OR REPLACE NOW.
Current:
E38 Parts Car
Previous:
Old 01-17-2013, 06:38 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Originally Posted by bmwfatherfigure View Post
bearings worn out. Hope for your sake you fix it b 4 the internals touch and spread steel dust through the works. Rebuild or replace now.
+1
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-17-2013, 07:40 PM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: Sig
+1,000,000
Replace or rebuild
Sent from Joe's Galaxy SIII via BimmerApp
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 01-17-2013, 07:49 PM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
Sent from my Desire HD using Bimmer App
Old 01-17-2013, 08:31 PM
Thanks.
BTW - is replacement an easy DIY job ?
Old 01-17-2013, 08:42 PM
BMR_LVR's Avatar
Humble E34 lover
Originally Posted by CraigBMW View Post
Thanks.
Yes. I would suggest you either purchase a hard copy of the Bentley manual, or you can search this website for a link to a site where you can download it.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-17-2013, 09:37 PM
Thanks.
Old 01-18-2013, 05:24 AM
Monsignor's Avatar
Mein Auto: Sig
Thanks.
Remove fan (reverse thread) and shroud
Remove belts (allen key tensioner)
Unplug/Unbolt
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-19-2013, 10:24 PM
Old School
You guys have covered it all...
Current:
E38 Parts Car
Previous:
Old 01-19-2013, 10:34 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Make sure its not just the nearby inexpensive idler pulley thats near there ,that tends to get loud when its bearings fail. Just spay the affected part with Wd 40 to identify what part goes silent , instantly after spraying.
Old 01-20-2013, 02:35 PM
Luckydog, you are spot on, the idler pulley is the problem. Thanks a million.
Old 01-20-2013, 02:47 PM
Monsignor's Avatar
Mein Auto: Sig
Do the hydraulic tensioner conversion.
I strongly recommend it
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-20-2013, 02:57 PM
Replacement of the idler pulley would appear to be a simple job. Any traps to be aware of ?
Old 01-20-2013, 03:06 PM
Monsignor's Avatar
Mein Auto: Sig
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-20-2013, 03:08 PM
Monsignor, what is the hydraulic tensioner conversion ?
Old 01-20-2013, 04:44 PM
Monsignor's Avatar
Mein Auto: Sig
Our m50 machines came with a spring tensior that wears over time. M60 cars (540 and 530 (v8) cars) and m52 (e39 525, 528, amd 530) cars came with little hydraulics for tensioners. They are much more reliable, resiliant, and easily serviceable. They make bolt-on kits for the conversion. I got mine from ECS after my spring tensioner blew, ate both belts, shattered my water pump pulley and busted my water pump. Drivig down the highway at 70 and losing power steering sucks on top of the waterpump.
Busted tensioner thread
Preventative maintenance.
ECS Hydraulic conversion kit
Sent from Joe's Galaxy Tab 2 via BimmerApp
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-20-2013, 04:54 PM
Thanks Monsignor, will look into it.
Old 01-20-2013, 05:01 PM
Monsignor's Avatar
Mein Auto: Sig
Updated previous post with coversion kit link
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-20-2013, 06:36 PM
Cheers, Thanks.
Old 01-20-2013, 07:55 PM
BMR_LVR's Avatar
Humble E34 lover
I recommend that you remove the serpentine belt and check all pulleys and items operated by the belt.
EDIT: I missed it above that you found the problem to be the idler pulley
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-20-2013, 08:45 PM
Old School
Change the belt too....
Current:
E38 Parts Car
Previous:
Old 01-20-2013, 09:30 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
interesting, my M52 that i put in my E30 had a spring type setup.
E30 above Sold
Last updated 2nd January 2014
Old 01-20-2013, 11:24 PM
The hydraulic tensioner kit looks like the ideal set-up, but I'm not sure about availability and cost in Australia. If replacing the idler pulley with a new original, would the consensus be to replace the (spring) tensioner at the same time (as well as the belt) ?
Old 01-21-2013, 06:26 AM
Monsignor's Avatar
Mein Auto: Sig
silly kiwis
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
