Old 01-21-2013, 01:33 PM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
Originally Posted by cmpcpro View Post
There is no wax motor just a rod and as the wax heats and expands it pushes against the rod and opens
That what it's called wax motor.The same technic is used for many temperature switch activation.The wax is in a bag in the bottom of the piston.And SFbay that's what I said if you read my post.I meant it as more of a statement.The spring is there so the pump will not overcome the valve flap.There are many links to how a tstat works just google.Also BMW doesn't have the only heated tstat ,I have found a few on other makes.No I wouldn't laugh at changing oil every 3k.Some very knowledgable people on other forums have discussed this in detail.Many believe its the oil breakdown from the heat in combination with BMWs 15k oil changes.Did any of you buy your car new and do 3 or 4k oil changes.I would like a seal report from this car.
Old 01-21-2013, 05:21 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Just bought my car so I can't tell you.. I too looked up the tstats but didn't know they called it a motor.. don't know why they do, but it's not important.. obviously SF just isn't going to give us this information, so I am done beating on a dead horse.. now we will have to make our own, so if you say they make some that have heating elements in them maybe we should start there.. I was hoping maybe the Alpina's would run cooler tstats but I guess not.. Someone told me the early N62's ran 85c tstats, or 95c, and thats what Paper thinks he has in his car.. the problem is now they are all changed to the new ones when you go to buy one, so we would have to obtain an original one..
The small cooling circuit on this system is surprisingly efficient, I am curious if there would be a way to upgrade that some how.. I think another fan on the condenser would help for stop and go, but nowhere near dropping it more than a couple degrees, so obviously that won't cut it.. Our best bet is to just find a similar thermostat and I will have my machine shop make it work.. I am extremely busy with work and unable to work on this very much, but if you can find one that is a close fit, I'll get it finished, and get them ready to bolt on our cars.
Old 01-21-2013, 05:37 PM
dolfan13's Avatar
Mein Auto: 545i
i found an earlier part number that was replaced by current number but.....105c also.
Old 01-21-2013, 10:37 PM
Mein Auto: Nothing
Haven't had time to check but have you found other thermostats that are similar to ours? Meaning they have the rod, etc? If so our heating element should at least fit so it doesn't throw off the DME.
Old 01-22-2013, 01:20 AM
Piers1989 Piers1989 is offline
Mein Auto: E65 745i
I don't know if it is useful information for you, but I have a September 2002 745i and when driving through town (about 25 mins stop start) I have never seen anything higher than 98 and only saw that once.
Also my car is UK spec.
Just though the information may be of some use if you are hypothesizing that the euro DME may open it sooner or something.
Old 01-22-2013, 05:33 AM
745iguy's Avatar
745iguy 745iguy is online now
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
Why havent you considered the tstat in the link paper provided to somehow get the rod out n put it in place of ours
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround
.. more updates to come
PREVIOUS 2002 745i
Old 01-22-2013, 05:34 AM
745iguy's Avatar
Or get a few Mazda tstats and find which one sf used if you really dont mind
PREVIOUS 2002 745i
Old 01-22-2013, 09:36 AM
SFbay SFbay is offline
Mein Auto: BMW 745i
Uk specs have different DME software. Us specs has higher temps bc of prob higher emissions standards or better mpg offered.
Old 01-22-2013, 09:51 AM
rideme2's Avatar
rideme2 rideme2 is offline
rideme2
Mein Auto: 2006li bmw
Ok so I'm DONE..... I just installed new stact new cooling from BMW (blue).... Check engine light gone!!! I'm not F...king with this any more:-( wast a lot of time and money..... No leak also so no more messing with car, till somebody comes up with a cooler stact that won't set off the check engine and keep the car @95... And my guy that worked in autozone??? GOT FIRER FOR F..ing some girl in the office:-))))
2006 750li K&N Filters Giovanna Kilis on 265/30/22 305/25/22 HID fogs 6000k Mtec angel eyes all lights 6000k ACS front lip,ACS rear wing,ACS rear window wing.dual exhaust working qual tips, rear camera, upgrade DVD to front watch jl13.5t sub with jl500/1v2 amp power cap.PassPort 9500ci,CrossDrilled&Slotted Rotors with EBC Brake Pads.Rear comfort seats, Fully loaded from dealer. Next mod iPhone hookup, .
Old 01-22-2013, 10:46 AM
Mein Auto: BMW 745i
So where was the leak???
Old 01-22-2013, 10:56 AM
rideme2's Avatar
rideme2
I'm hoping it was over flow????:-(( cause two days passed and no leak??? Now I just finished all this work and didn't find any trace of a leak???
Old 01-22-2013, 11:09 AM
Mein Auto: BMW 745i
Update:
They asking me for 5500$+600$ shipping check....
I guess I need some kind of agreement.
Old 01-22-2013, 11:16 AM
Mein Auto: BMW 745i
What work??
Did you do your valley pan at least????
Old 01-22-2013, 11:28 AM
rideme2's Avatar
rideme2
Originally Posted by SFbay View Post
What work??
I've change the pan, cooling pipe all gaskets engine and tranny stact. And all new cooling BMW blue cooling. New water pump.new Hoses....
Old 01-22-2013, 11:35 AM
rideme2's Avatar
rideme2
O and I have a new filter to installed this WKEND.
Old 01-22-2013, 11:53 AM
Mein Auto: BMW 745i
Nice!!! Only rear cover left and heater core
So how's the temp now while idling?? 105-aux fan-103?
Old 01-22-2013, 12:03 PM
dolfan13's Avatar
Mein Auto: 545i
I'm going to do a 550i oil cooler retrofit.
Old 01-22-2013, 12:08 PM
rideme2's Avatar
rideme2
I drop lower on HWAY driving. City 103-105. And I hope I don't need to change the REARCOVER OR THE HEATER CORE:-(((
Old 01-22-2013, 12:22 PM
Mein Auto: BMW 745i
Was it going higher than 105 before?? I mean what was the reason ?
Can you check lower hose temp??
Well if aux fan kicks in it usually means lower hose is at 65C which is good.
Old 01-22-2013, 12:37 PM
rideme2's Avatar
rideme2
Never went over 105, just saw the valley pan leaking so I installed the bimmer pipe kit it comes with everything. Don't know the temp on the lower hose?? But I can hold it not too hot? Fan kicks in @105. Strong fan I can hear it if shut off the radio.
Old 01-22-2013, 12:38 PM
Mein Auto: BMW 745i
Ok, so what do you guys think:
95C or 90C tstat????
I got original invoice already!!! Everything looks good!!
2 months left I nope
Old 01-22-2013, 12:44 PM
Mein Auto: BMW 745i
Was it complicated to install that front seal?? I had issues with URO parts one, spent 4 hrs until it got there!!!!
Old 01-22-2013, 12:49 PM
rideme2's Avatar
rideme2
No very easy. Bimmer pipe has two nuts you Turn one to expand the pipe and the second one the lock them. I just had to go back and open everything up again cause there a notch on the back of the pipe that has to stay pointing up??? Y I don't know. But very easy work. 2hours for everything open and closed.
Old 01-22-2013, 12:56 PM
Mein Auto: BMW 745i
So you cut old pipe, removed the seal and installed new one that easy?? Did you clean that seal passage well?
I guess your problem was valley pan only, but new pipe is always nice to have!
Old 01-22-2013, 01:02 PM
rideme2's Avatar
rideme2
Yea I cut the pipe out , clean everything... My pipe was still good but I just change everything since I was there.
