Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners & Enthusiasts
Old 01-21-2013, 02:36 PM
cssnms cssnms is offline
Mein Auto: '11 335d
Question Fault code 474C???
Does anyone know what triggers this code?
I pulled along with some other fault codes using the BT cable. I able to erase all code except for this one. My low DEF triggered the "no start in 999" over the weekend, I wonder if it's related?
Old 01-21-2013, 05:14 PM
Flyingman's Avatar
Flyingman Flyingman is offline
hang up and drive!
Mein Auto: 335d
Appears to be related to the exhaust pressure sensing system???? Emission related.
P0474 Exhaust Pressure Sensor Intermittent
2010 Black 335D Sport/Premium, Michelin PSS 235/265 (100k Club)
2000 Silver Z3 3.0i (Ret)
1999 Silver R1200C (Ret)
1968 Black 1600 Coupe (Ret)
Old 01-21-2013, 05:16 PM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
I've had a low def temp sensor code for last 8,000 miles or so. Live in Florida so not too worried about it freezing!
I suspect one could defeat most of this emission crap that only causes alarms and SES lights.
Old 01-21-2013, 05:52 PM
Mein Auto: '11 335d
I don't know and I could be wrong, but that looks like a generic "P" code, not a BMW code. P codes then need to be translated into BMW specific fault codes.
The closest thing I found was 477C for an injector activation duration (control unit internal)
Found here.... http://www.endtuning.com/bmwcodes.html#DDE6
Old 01-22-2013, 03:41 AM
GreekboyD GreekboyD is offline
Mein Auto: 2009 BMW 335d
So this code did not throw a CEL right? I'd top of the urea and see if it appears again. Could be a one time occurence type of situation where the DDE still logs the event.
Old 01-28-2013, 06:05 AM
elester12 elester12 is offline
Mein Auto: F30 335
I had that code when the pressure sensor before the DPF went bad.
Old 01-28-2013, 03:14 PM
Mein Auto: '11 335d
Thanks for the reply. I don't have an ses light, but last I checked the fault code was still there.
What was involved with the repair?
Old 02-01-2013, 12:31 PM
Mein Auto: F30 335
Replaced the sensor. Had to drop exhaust.
