Old 12-26-2012, 02:06 PM
tjducet tjducet is offline
Mein Auto: 2006 BMW 750Li
Post Fluid loss in steering or suspension hydraulkic system.
Hello Bimmerfest;
I was wondering if any one knows how to manually check the level of the steering or hydraulic suspension system on a 06' 750Li (E66). I bought the car with this problem of receiving an error message of "fluid loss in steering or suspension hydraulic system" had it serviced after buying and it was not observed in their report. usually it only appears the first time I start the car and then disappears after stopping and starting again and does not reoccur. Lately, with cooler (0-5 C) temperatures it seems to be coming up more frequently and dissapating at a later stage of engine running. I am thinking it has to do with either the sensor, or a minimal amount of fluid even at max in the resevoir and with coller temperatures expansion and contraction of the fluid activating the sensor? Any help will be much appreciated. see pics. No observed degration in steering or suspension while driving. Many thanks.
ID:	354735   Click image for larger version
ID:	354736   Click image for larger version
Old 12-26-2012, 02:13 PM
johndade johndade is online now
Mein Auto: 2002 bmw 745li
Buy some hydrollic fluid at dealer and top it up in the hydrollic fluid / power steering resevour on drivers side . And see if it comes back may have a leak ir may just be below minimum capacity.
Old 12-26-2012, 02:19 PM
First_745Li's Avatar
First_745Li First_745Li is online now
Mein Auto: 2003 745Li
Recharge battery means weak battery.. when was the last time the battery was replaced?
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 12-26-2012, 02:27 PM
@johndade
thanks. yeah the battery part is no problem. @johdade is the resivoir for steering/hyd. fluid the one drivers side of the engine block highlighted in the picture? it is not identified in the owners manual. Thanks.
vsapra's Avatar
vsapra vsapra is offline
Send a message via Yahoo to vsapra Send a message via Skype™ to vsapra
Mein Auto: 2006 760Li
I had the same problem two days ago. I stopped at my local dealer and they topped up my steering fluid with Pentosin CHF11 fluid out of a green bottle.
They said that in colder climates, the fluid levels can contract a bit. Or i have a leak which i need to be on the lookout for.
Old 12-26-2012, 02:30 PM
@vspara
is yours vehicle the same year and model?
Old 12-26-2012, 03:01 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
Check the fluid level! If it's at the MAX line then it may be an issue with the sensor or the wires going to the car from the sensor (rat may have chewed on them). If the fluid is low at ALL, top it up to the MAX line.
Old 12-26-2012, 07:02 PM
Thanks to all. Pentosin CHF 11 S is the stuff. Yes from the green bottle for $30. I only needed about a cup or two worth's.
tjducet
Old 01-21-2013, 02:42 PM
crystalgalaz crystalgalaz is offline
24'S on my Beamer!!
Send a message via Yahoo to crystalgalaz
Mein Auto: 2002 BMW 745 Li
Smile error steering fluid loss
Hello i also have this problem and lots of other codes like 8 or 9 this is one of them where can i find out where to put the fluid in the car no owners manual help thanks
Old 01-21-2013, 06:04 PM
BMW7_CEO's Avatar
BMW7_CEO BMW7_CEO is offline
BMW7_CEO
Mein Auto: 2005 745LI
Have your sway bar checked out because that could be leaking that's what happen to me and I had the same error message on my Idrive to
