Old 01-21-2013, 12:29 PM
al_macaroni al_macaroni is offline
Mein Auto: BMW X5
LCI X3 Headlight Washer Sprayer Leaking Fluid
I have a 2008 X3 with the cold weather package (headlight washers) and I have a washer fluid leak. I've noticed a small wet spot under the front right corner of my X3 for the past 2 days.
I've checked all around the washer fluid container and the various pumps and lines at the tank. I cannot find a leak at the tank or at the pumps.
Next, I pulled off the right front fog light trim ring and I can see fluid on the sprayer nozzle mechanism. So, it looks like this sprayer nozzle is the culprit.
See part number 3 in this diagram.
http://www.realoem.com/bmw/showparts...51&hg=61&fg=45
Has anyone replaced the headlight washer nozzles on their X3? Does the front bumper skin need to come off for the repair, does the headlight need to come out or can I reach it if I remove the right inner fender?
I've searched Bimmerfest and Google and I can only find how to plug the line to stop the leak rather than how to replace the spray nozzle on X3s.
I did see a post for an e90 where the person made the repair by removing the inner fender.
Any input on the best way to approach this repair would be appreciated.
2016 X5 35d | Mineral White | Terra
2013 535i - ED, Oct 2012 | Cashmere Silver | Oyster/Black Nappa Anthracite | ZCW | Sirius | Air Blue 80
retired - 2008 X3 | Monaco | Sand/Black Light Poplar | ZAP | ZPP | ZCW | Xenon | Rear Fog
1988 Grand Wagoneer | Burgundy | Ghost Flames | 360 ci | Holley carb
BMW CCA #422951
Old 01-21-2013, 12:31 PM
Mein Auto: BMW X5
Sent from my DROID X2 using Bimmer App
BMW CCA #422951
Old 01-21-2013, 06:54 PM
John320 John320 is offline
Mein Auto: 2017 X1
Hope this will help, but as you can see - a little old, so may not be what you need,but some info none the less
Old 01-21-2013, 07:22 PM
Mein Auto: BMW X5
Thanks for the information. The bumper info looks great. From what I can see of the LCI sprayers, I think the '06 information regarding the connections will come in handy.
BMW CCA #422951
