Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 01-21-2013, 11:06 AM
Dan-39 Dan-39 is offline
Mein Auto: BMW E39 M5
Fault Codes
Apologies for this being my first post here, however I am in urgent need of some help with pinpointing the potential causes of these codes.. I've only just bought this and I'm already feeling foolish for doing so, as it all seemed fine when I went and looked at it, including starting from cold and taking for a run until it was warm. The misfire didn't start until I was 2/3rds of the way home.
It's been plugged in and came up with:
11 - Camshaft Position Sensor Outlet Bank 2
162 - Camshaft Position Bank 2; Synchronization Crankshaft
170 - Seconday Air System; Low Flow
79 - Exhaust Gas Temperature Sensor
114 - Vanos Outlet Camshaft Control Bank 2
145 - O2 Bank 2 Control Function
209 - Misfire Cylinder 5
210 - Misfire Cylinder 6
213 - Misfire Several Cylinders
12 - O2 Sensor 2 Before CAT
206 - Misfire Cylinder 2
212 - Misfire Cylinder 8
149 - Error Occured With Empty Fueltank
200 - Misfire Cylinder 5 With Cylinder Cutoff
203 - Misfire Cylinder 8 With Cylinder Cutoff
204 - Misfire Several Cylinders With Cutoff
196 - Misfire Cylinder 1 With Cylinder Cutoff
197 - Misfire Cylinder 2 With Cylinder Cutoff
198 - Misfire Cylinder 3 With Cylinder Cutoff
199 - Misfire Cylinder 4 With Cylinder Cutoff
201 - Misfire Cylinder 6 With Cylinder Cutoff
202 - Misfire Cylinder 7 With Cylinder Cutoff
These were then cleared and it was taken for a short drive, here's what returned:
I'll get it plugged in again after it's had a bit of a longer drive.
Any advice or ideas appreciated
Thanks, Dan.
Old 01-21-2013, 11:20 AM
Blaknificent Blaknificent is offline
Mein Auto: '05 Black Sapphire 645ci
Brake fluid
Old 01-21-2013, 12:24 PM
Helpful, thanks.
Old 01-21-2013, 01:55 PM
ard ard is online now
Resident Curmudgeon
The old codes, dont worry about.
But of course you go a PPI, right??? Pre Purchase Inspection???
Well, anyway...
You need to replace the EXHAUST camshaft position sensor, bank2. I kind of recommend replacing all 4 CPSs (two intake, two exhaust) as they tend to fail. The run about US$80 per, more or less. PITA to install. Lots of DIYs.
The crankshft error is most likely due to the CPS- once they loose track, you'll see crank errors.
A few things to consider: O2 sensors, MAFs, VANOS Orings, Fuel Filter.
But replace the CPS and go from there.
and by far the best online forum for M5s is M5Board dot com
A
Old 01-21-2013, 02:10 PM
Thanks for your help, will get some bits on order. Waiting for account activation on M5board already
Old 01-21-2013, 08:39 PM
Resident Curmudgeon
pm me your username if it seems to be lagging and I can do it
A
