#26
Thanks guys, you are too kind
![]() I figured instead of getting new sensors that are at least $70 a piece and will fail the same exact way, just rebuild my original ones. The insulation I used is silicon coated fiberglass rated up to 200C so should be plenty. It seems it doesn't actually take long for the original BOSCH insulation to fail. I replaced my intake camshaft position sensor a year ago and now noticed that the cable became very stiff already... |
#27
There's a quest for a method of testing the BMW E39 knock sensors over here today:
- > E39 (1997 - 2003) > knock sensor ohms
#28
Cross referencing to this knock sensor thread today:
-> E39 (1997 - 2003) > missing knock sensor
#29
For reference, here's a thread that shows pictures of the knock sensor in situ:
> E39 (1997 - 2003) > kNOCK SENSOR 1 EDIT: Since this thread is the canonical one in the bestlinks, here's a set of related E39 knock sensor threads:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 01-24-2013 at 05:04 AM. |
