Any diy brake booster change threads out there? - Bimmerfest - BMW Forums
Old 01-22-2013, 05:05 AM
2002beamer 2002beamer is offline
Mein Auto: 2002 325i
Can't seem to find any. Looking for a good step by step thread on how to change a brake booster on my 02 325ci. Thanks!!
Old 01-22-2013, 08:48 AM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Here's some... CLICK ME!
Jeff R.
Old 01-22-2013, 11:54 AM
Thanks much!! Just as I has figured it was gonna be...nightmare!!!
Old 01-22-2013, 02:20 PM
JKRIT JKRIT is offline
Mein Auto: '03 525i
Just curious: What are the symptoms that you diagnosed as needing a new booster?
I bought a new booster for our 2002 325it because it wouldn't hold vacuum with engine off, even after replacing the check valve (twice; just hoping). But after almost a year, but before I ginned up my nerve to tackle the job (disconnect all brake lines from the master cylinder and re-bleed, etc.), it started behaving normally again.
Old 01-22-2013, 05:32 PM
It has a loud hissing noise coming from behind the cluster and down in the booster area when hood is open. Also the noise goes away when brake is pressed all the way. Also getting a rough idle and car wants to stall out. Someone mentioned its the member inside the booster that's bad.
