Old 01-19-2013, 09:37 PM
Alan L. Alan L. is offline
Mein Auto: LCI 550i Msport
Start from the top. Pull out enough so you can catch the lip around the fog light lens. Just keep pulling working from top down. The plastic is actually pretty flexible and durable. I've pulled mine out half a dozen times without and issues.
Alan
Old 01-19-2013, 09:56 PM
DallasBimmer's Avatar
DallasBimmer DallasBimmer is offline
BIG D BIMMERS
Mein Auto: '13 535i MSPORT,'10 E93
Alan
Thank you, I'll try that.
Old 01-19-2013, 10:08 PM
Travel4Surf's Avatar
Travel4Surf Travel4Surf is offline
Mein Auto: Everglades 243
Use a coat hanger t help you pull it out...
http://www.bimmerfest.com/forums/sho...5&postcount=17
Minha patroa um BMW
Old 01-20-2013, 08:23 AM
Chuck W.'s Avatar
Chuck W. Chuck W. is offline
Mein Auto: 12 BMW 535I MS Alpine Wht
Heat is also your friend when removing. Do it after a good drive or put a heat gun on it for a minute.
I will bow my head in shame and admit I broke a few tabs removing mine. But, they snapped back in well and feel solid. Live and learn.
2016 BMW M2 - ED Pick Up on 07/12/2016; US Pick Up on 09/22/2016
2012 BMW 535I - ED Pick Up on 12/03/2011; US Pick Up on 01/27/1012
2001 Boxster S 29,000 Miles, Original Owner
2007 Mini Cooper S - Sold
1997 Porsche 993 Turbo Sold
1997 Porsche 993 Cab - Sold
Old 01-21-2013, 09:51 PM
BigDeep1's Avatar
BigDeep1 BigDeep1 is offline
Festaholic
Mein Auto: 2011 535i Sport
Here is an example of 5k vs 6k bulbs. This Saab has 5000k HIDs for headlight and 6000k for fogs. I was worried the 5k may be too blue; however, from THAT pic I think I may be ok the color.
http://www.saabcentral.com/forums/sh....php?p=2280352
I actually have a 55watt DDM kit on my DD (2004 Saab). It's on as daytime running lights the whole time my car is on (thanks to GM). I say this because after all those hours (probably over 300 hours) they still work great after 5 years.
I was debating if I should get the 4500k kit, 5000k kit or the more expensive, less bright but perfectly matched Cree LED bulbs:
http://www.bimmerfest.com/forums/sho...d.php?t=666582
Thanks for sharing your experience Chuck. Great job!
2011 535i Sport (Prem 1, 2)
Old 01-22-2013, 07:30 AM
I actually swap between the ddm tuning 35watt ballast and the 55watt Morimoto ones from TRS. Although one of my ddm tuning set already died on me the second set has been trouble free.
My morimoto ones have been having flickering issues since day 1 and i am about to swap out one last part that they suggested to see if it will fix the issue. One thing i do have to say is that the going from 35-55watt there is a HUGE difference. Its actually too bright and i get flashed by other drivers now. I'm running 5000K morimoto bulbs which matches the oem rings perfectly but i am going to switch the out and try out the 3000K yellows for two reasons. 1. it should be less blinding for others and 2. the yellow should provide more contrast on the road. I use these to mainly help me spot out those humungous potholes we have here in NY (BQE) and the super bright 5000k lights sorta just washes everything out in bright white light.
In my opinion so far....the DDM 35watt ballast paired with the morimoto 5000K bulbs looks the best. No need to go 55watt nor spend the extra dime on the morimoto ballast. The ddm's are cheap enough that you can have 2 sets as back up before it would cost the same as the morimotos.
Alan
Old 01-22-2013, 08:03 AM
BigDeep1's Avatar
Festaholic
Great info Alan. Thanks!
When I bought my DDM kit 4 years ago, they were $120. They are the slim kit; however, I wonder if they were resourced from a better vendor. If you look at the link I posed at the bottom of that Saab Central page, I used capacitors to alleviate the strobing light issue. I would not want to "rig" that type of set-up on my Bimmer.
I was thinking of mentioning your exact statement - that the 35 watt HID kit would be the brightest I would go in the fogs. I honestly don't like and don't want my fogs to over power my angel eyes and headlights. I would save that bright fog light look for Ram trucks.
Chuck and those with the 35 watt HID kit in the fogs, do you think that the fogs are brighter than the angel eye DRLs?
Old 01-22-2013, 08:11 AM
Not sure. I got the slim DDM kit for around 35 bucks direct from them and I am also using their error eliminator canbus harness on my car. They work perfect when its full ddm tuning stuff with my morimotor bulbs. No errors or any flickering.
The problem I am having is that i'm using the ddm canbus error eliminator harness with the 55watt morimotor kit. Supposidly the 55watt kit isn't getting enough power during warm up which is causing the light to flicker. I ordered the morimoto canbus harness now and waiting to try that. Basically i'll have one set of full ddm and one set of morimotor after this.
I'm skeptical about using the 55watt kit now because they are so damn bright. If the 3000k yellow bulbs are still too bright i may end up adding a light smoke tint over my fogs so it protects the lens from rocks and also tones down how crazy bright they are.
Alan
Old 01-22-2013, 08:18 AM
Chuck W.'s Avatar
Yes, they are. However, you have to be looking for the difference. They are not so much brighter that they stand out. If I were to order again I would go with the 4500s. The 5000s have a tab of blue in them. Again, you have to be looking for it.
When the headlights are on, the fogs look much better than when just running them with the DRLs.
Old 01-22-2013, 08:25 AM
Just to add the morimoto 5000K bulbs were much nicer than the 5000K ddm bulbs.
The DDM like you said has a slight blue look to them and is more like 6000k than 5000K imo.
Morimotos were pure white and a very close match with the halos. They some how also seem brighter too.
Alan
Old 01-22-2013, 09:50 AM
DieselNY's Avatar
DieselNY DieselNY is offline
Mr Real Estate
Mein Auto: 2013 BMW 535i Xdrive
So the ones you got are different than these:
Actual product page: http://www.amazon.com/Bulbs-Headligh...I3KI7J0NCXCTHQ
Because they do not seem to be blue at all. Would these be a safer bet to make sure there is no blue? I want to do the fog light mod but don't want any hint of blue.
Thanks.
2013 BMW 535i Xdrive, msport, Jet Black/Cinnamon Dakota leather (delivered 3/15/2013)
Current car: 2010 MB W212 Black/Black
Previous car: 2008 MB W211 Black/Black
Old 01-22-2013, 12:38 PM
BigDeep1's Avatar
Festaholic
Thanks.
Diesel, Chuck said that he has the DDM HID kit. The other link is for LED bulbs. Big difference. The catch is that those expensive LED bulbs have a great color but poor performance (does not shine light on the road well). The HID kit is bright and performs well; however, the color is a bit off (more blueish) and it may be a little overpowering if used with just DRLs (angel eyes).
Old 01-22-2013, 03:22 PM
DieselNY's Avatar
Mr Real Estate
Ok thanks, suffice to say the fog lights IMHO are more for show anyway. I have them on my Mercedes and only use them during the day and they are useless at night. So if I want to avoid any sort of blueish color I should just go with the LED bulbs? My goal is to get rid of the ugly 80's yellows light look and match the the headlights as close as possible. Unless of course someone can refer me to ones that are not blue at all are are HID.
Old 01-22-2013, 03:44 PM
Chuck W.'s Avatar
Mine are the DDM ones. I would just go down one notch to 4500. I may buy a pair and see how they look.
The prices have just dropped though the floor on these kids. Several years ago a bunch of us bought them for our 993 (911) Porsche. They were a steal at $250.
Old 01-22-2013, 10:40 PM
Kcustom Kcustom is offline
Mein Auto: 2013 550ix
The pics attached are the leds I installed. Patern is not as good as stock but color is spot on.....
ID:	358833   Click image for larger version
2014 335ix
Retired:
2013 550ix
2009 535i
2007 335i
Old 04-20-2013, 01:32 PM
D2nice D2nice is offline
D2NICE
Mein Auto: 2013 535i Xdrive M Sport
Hey Alan. If you can help me it would be greatly appreciated. I am replacing the stock fog light bulbs with a xenon bulb kit with the balasters. I removed the fog light grill, removed the 2 screws and the light won't come out and I can't find another screw. Do you know how to remove it? Thanks in advanced
Dan
Old 04-20-2013, 02:58 PM
Tab on top back of light assembly. Press and slide forward
2014 335ix
Retired:
2013 550ix
2009 535i
2007 335i
Old 04-20-2013, 08:00 PM
I didn't remove any screws or the light assembly when I did my fogs. There's plenty of room once the mesh grill is out.
Alan
Old 04-22-2013, 06:15 PM
bmwombat bmwombat is offline
Mein Auto: 2013 F10 535d M-Sport
Just order the 35watt kit plus the error eliminator cables. You don't need anything else. Should be $50 plus whatever shipping is.
The install is simple as can be for the Msport bumper. Not sure if this will work on the non Msport bumpers.
1) Remove the mesh grill around the fog lights simply by pulling it straight out. Try to get your finger around the lens and mesh grill then just pull.
2) Stack the ddm tuning kit ballast, ignitor and error canceller on top of each other. They are small boxes and you can use double sided tape to do this. You are doing this to make the install cleaner and take up less space by stacking them up together. Also prevents them from banging around each other during bumps.
3) add double sided tape on the bottom of the ballast. This will mount to the bottom shield behind the fog lights
4) connect the wires and swap in the hid bulb
5) peel off the backing of the double sided tape and place the electronics directly behind the fog light housing. There is just enough room and a flat surface for this to mount back there. Seems sturdy and its completely out of sight. Use the 3M grade (red backing) and it also helps if you wipe down the flat area behind the fog light before sticking it there.
6) reinstall the mesh just by pushing it back in.
Honestly this whole process took me less than 30mins both sides on my Msport bumper.
Alan
Excellent! What's the website address mate so I can go have a look?
DOH!!! What kind of dummy am I? Forget my silly question - it's pretty bloody obvious if I actually read the thread.
Driving: 2013 F10 535d M-Sport Carbon Black
Old 04-24-2013, 05:44 AM
332701 332701 is offline
Mein Auto: 535xd
Just use a Screwdriver or something similar to lift out the plastic gril. Its easy, the grill is flexible and cannot break.
535xd with 20'' Wheel style 434 M in Sophistogrey II Brillant Metallic
Old 05-20-2013, 03:09 PM
vaqua55 vaqua55 is offline
Mein Auto: 2013, 535I M Package
Are the instructions to install available as I just received E92 H8 LED (cree) and not sure how to install them
Many thanks to Alan L. for starting this post. I bought the same lights from DDM Tuning. Great results.
Driver's Side Mod.. Passenger's Side OEM
Both Done
Old 05-20-2013, 09:43 PM
BigDeep1's Avatar
Festaholic
I am glad you asked! I finally installed these a few weeks ago and took some pics. I just made notes on most of the pics to help with the install. I am sure the M-Sport bumper would have a similar install. I hope this helps
You can just keep hitting the right arrow to scroll through the pics:
https://picasaweb.google.com/PHARMDP...48995367223442
album link
Old 05-20-2013, 10:02 PM
HID Fog lights from DDMTuning.com works on the F10
Perfect thanks I will install and follow your steps with slight adjustment to M kit.
Old 01-30-2014, 10:09 PM
rauan's Avatar
rauan rauan is offline
Mein Auto: BMW F15, xDrive35i
Installed DDM kit tonight and when I checked with ignition on and engine off everything was ok. Then I decided to drive around and see how the visibility will change and it gave me error Fog Light Malfunction. I drove back home and turned off and back on ignition and this time I didn't get any errors. Did anyone experienced it? Is it bad? Any suggestions?
- F15 2014 xDrive35i
- F10 2011 535i
- E60 2004 530i
Old 01-31-2014, 09:30 AM
Chuck W.'s Avatar
If you didn't use the Error Code Eliminator module add one. If you did, recheck your wiring. Lastly, if you use the eliminator, one of them may be bad. You'll have to troubleshoot it by removing one and putting the OEM setup back in then the other and see if you get the same warning. PITA.... sorry, keep us posted.
