Old 01-17-2013, 07:21 PM
Arthurghost Arthurghost is offline
Mein Auto: 1998 BMW 528i
Exclamation 1998 528i light Knocking noise on right passenger side
just recently got a tune up, oil change, and fuel pump replaced. there has been this strange knocking sound when car is in motion. don't know if it can be the axle but the sound is on the right side. some type of metal banging against another. any similiar situations??
Old 01-19-2013, 08:17 PM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
Did this noise started occurring after the tune up?
Who did the tune up?
Maybe someone left some tools under the back seat when the fuel pump was done?
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 01-20-2013, 12:33 AM
No it was before the tune up and oil change. I thought it was the oil but thats not the case. Its sounds like it is around the right front side of the car and this siynd comes and goes.
Sent from my SPH-L710 using Bimmer App
Old 01-20-2013, 05:42 AM
dtadrian dtadrian is offline
Mein Auto: 1999 BMW 528i T Wagon
A little more info would be nice. Such as are you getting this noise when car is moving? At low speeds? Over bumps? Or at idle?
Edit. I re-read your original post. If your getting a metal to metal noise in motion at low speeds you may need to look at your struts,mounts and possibly your control arms and check the bushings
Old 01-20-2013, 08:05 AM
Yes when the car is moving at low speeds but picks up when I speed up as well. Thanks for that info though.
Old 01-21-2013, 12:35 PM
dumblucky dumblucky is offline
Mein Auto: 99 528i
make sure the knuckleheads didn't leave the motor covers loose or forgot a bolt
that 6mm on the back of the fuel rail likes to come loose on mine
Old 01-22-2013, 07:49 AM
johnstern's Avatar
johnstern johnstern is offline
Mein Auto: 2000 BMW 528iT/5, S/C
Right front sway bar link worn put and loose. Just a guess.
Get under the car and give it a good shake.
