Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW.
Sponsored by The Tirerack. Moderated by Rudy@Tirerack.com
Old 01-21-2013, 11:31 AM
troymi troymi is offline
Mein Auto: '14 650i X Coupe
TPMS Rebuild Kit Required?
When replacing the TPMS sensors/valves in the wheels, is a rebuild kit required all the time?
Old 01-22-2013, 08:51 AM
Rudy@Tirerack's Avatar
Rudy@Tirerack Rudy@Tirerack is offline
Moderator
Mein Auto: 1-800-428-8355 X4664
If you've bought new sensors and valve stems and are simply installing the new sensors and stems, all the parts you need will be there. If you're not replacing your old ones and are transferring the old ones to a different wheel, you'll want the rebuild kits.
Refer to 'Rudy/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by CLICKING HERE.
Rudy@Tirerack.com
Old 01-22-2013, 09:17 AM
Thanks Gary. So moving sensors to wheels with existing valves (sensors removed) requires the kit? X5 oem wheels and sensors, what does the kit cost per wheel?
