Old 01-16-2013, 08:59 AM
Tee95E38 Tee95E38 is offline
Mein Auto: 1995 740i
Cel confusion
Will my cel go off if I need to add water to my radiator? Because it came on and I did a stomp test and nothin came up except check rear lights!
Old 01-20-2013, 06:11 PM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is offline
Mein Auto: 1989 E30; 2000 E38; GS350
You need to take the car to Autozone or any parts store and have the OBD-I system codes read. If your radiator coolant is low, its not rocket science...top it off. Just so you know, the cooling system on these cars is a known weak point.
Big Boyz with Bad Toyz.
Old 01-20-2013, 09:14 PM
BMWFatherFigure's Avatar
Old School
Would the car even 'remember' a low coolant situation once it is topped up? Topping Up Cooling Systems': night school 101.
Current:
E38 Parts Car
Previous:
Old 01-21-2013, 01:34 AM
Yeah I kinda felt stupid when I aske that and I know now that I don't have any cooling problems cause I ran my car at about 90 for like 250 miles the other day and not a hiccup! Plus even when I run the piss out of it (floor it from stop light to stop light). It gets more responsive and the needle of my temp gauge never goes pat the middle and I can always touch my valve covers when I turn it off and radiator hose an wont get burnt! I do have an oil leak at the moment though! And I think my speed sensor might be goin out also because my miles won't register sometimes and the speedo will go out.
Old 01-21-2013, 09:57 AM
Old School
The speed sensor for the speedometer is in the dif housing - looks a bit like a CPS. I think other speed related devices and systems get information from this unit too. Start checking there but check out wires etc carefully first - no point in buying a unit for a damaged wire.
Current:
E38 Parts Car
Previous:
Old 01-21-2013, 10:15 AM
Yeah I've seen friends waste a lot of money fixen what they they (think) the problem is!
Old 01-22-2013, 02:31 AM
Mein Auto: 1999 740i
CEL will not go off for low coolant. Your rear lights, check coolant level, and CEL are not related.
Old 01-22-2013, 12:19 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
CEL (check engine light) and/or SES (service engine soon) warning lights (OBD I & OBD II) are for your car's electronic emissions system. As others mentioned,exterior lights, coolant system, etc are not associated with emissions so there's no connection.
Q {BMW CCA Member #191509}
(SOLD)
HTML code is Off
