Keyless ignition problem - Bimmerfest - BMW Forums
Old 01-16-2012, 03:46 PM
ozziegold ozziegold is offline
Mein Auto: 730SE LWB, X3
Hi all
Not sure if any one can help or has or heard of this problem. I have 09 730SE LD with keyless ignition with an intermittent problem. Occasionally when trying to start the car, the ignition seems to switch on, all the correct lights on the dashboard come on, my foot is on the brake, but nothing happens, engine doesn't turn over, no sounds as if something was malfunctioning, just nothing. Even placing key next to steering colum as per BMW instructions for faulty remote or flat battery does nothing! I get no warning sounds or messages. I have to power down the car and leave it for around 15 minutes before it will start, I'm a chauffeur and this has now happened twice when picking up paying passengers who are unable or unwilling to wait 15 minutes to see if the car starts. Has also happened in petrol station which is very embarrassing. Have been to 3 BMW dealers, and all say the same things. Unless fault happens when in workshop, they can't trace fault. The is no fault recorded in vehicle memory. One dealer has even been on to BMW in Germany and they have not heard of problem and have no answer!
There is no comman pattern. Sometimes it can be first thing in morning after being in garage overnight other times it can be during the day after car has been running during the day, hot or cold weather, dry or damp, seems to make no difference.
If anyone can help or has any ideas it would be gratefully appreciated
Of all the thinga I've lost, I miss my mind the most!
Old 01-16-2012, 04:25 PM
LIRacer LIRacer is offline
Mein Auto: 2012 Alpina B7 (ordered)
Sounds like problem with your starter motor itself. Is the car stored indoors, or outside?
Bruce
2012 Alpina B7 Silver
2010 Roush Mustang (627 RWHP)
1965 Vette (ZZ502)
2005 Ford Racing Mustang in SCCA T-2
SCCA National Driver
Old 01-16-2012, 07:32 PM
Mrkayem Mrkayem is offline
Mein Auto: 2016 M5
Happened to my 2011, would sometimes take 5-10 minutes to start car. Embarrassing to say the least. Dealer had to change the diversity antennae. I have no idea what that is, but I have not had the problem since. Hope this helps.
<img src=http://s1.bimmerfest.com/forums/images/smilies/laugh.gif border=0 alt= title=ROFL class=inlineimg />
2016 BMW M5
2015 RANGE ROVER SPORT SUPER CHARGED
2008 LEXUS RX 350
2001 FORD EXPLORER SPORTS TRAC
Old 01-17-2012, 03:32 AM
Car is stored in garage overnight. Would expect if starter motor to see lights dim as it drawss or attempts to draw power or clicking noise from starter/solenoid. Thanks anyway
Old 01-17-2012, 03:38 AM
Sounds hopeful. I'm about to ring my dealer and suggest it to them. Got to get something done as it happend again this morning at Heathrow Airport costing another client who having spent 18 hours or so flying from Singapore understandably didnt want to hang around in freezing conditions
Thanks for your help
Old 01-17-2012, 04:46 AM
Not always. I find that the guys who work on these cars aren't real mechanics, just a bunch of high tech parts replacers who sometimes miss obvious symptoms. I hope you can get this sorted out.
Bruce
1965 Vette (ZZ502)
Old 01-26-2012, 12:57 AM
Just to keep you updated. Have managed after a lot of arguments to get the dealer to change the diversity antennae. We are now waiting for the part to arrive from Germany!
Will let you know what happens
Thanks again for your help.
Old 01-30-2012, 06:11 PM
Mein Auto: 2016 M5
Good luck and I hope it works. Let me know when they get it in.
KM
2016 BMW M5
2008 LEXUS RX 350
Old 06-04-2012, 12:10 PM
GaryLH GaryLH is offline
Mein Auto: 2011 535i
update
did replacing the diversity antenna work! facing similar problem with 2011 535i.
Old 06-04-2012, 12:23 PM
Mein Auto: 2016 M5
Yes it worked. I no longer had the problem after having the diversity antennae replaced.
2016 BMW M5
2008 LEXUS RX 350
Old 06-04-2012, 05:03 PM
Thanks for the update!
Old 01-22-2013, 01:23 PM
SPYDER57 SPYDER57 is offline
Mein Auto: 1996 BMW 328i
Really???
I realize this thread is old, but does anyone actually know what a Diversity Antenna is? The antenna built into the back glass is a radio antenna and a defogger. When you turn on your defogger, The diversity antenna changes the rear glass antenna to a set located in the rear C-Pillars.
So, the radio antenna diversity control module does not have anything to do with your car starting. Now, The reprogramming that was done with replacement of the control module...... That might have helped you on some level.
I just wanted to put this out there because there are going to be people that look this up in the future and should know how silly the noted correction is on this thread.
Please refer to your local dealer with your issues and have a trained BMW technician work on your car.
Old 10-19-2015, 12:55 AM
lucjam lucjam is offline
Mein Auto: BMW 3 series
I have this problem too!!
Hi,
I have a 2012 BMW X3 and the description of your problem is exactly the same as mine, you could have written it for me! I have been told by my local garage that they have raised what they call a Puma which contacts all BMW garages worldwide to ascertain if there has been a similar problem. The result has been nil. Obviously your garage dealt with this problem for you and I would be really grateful if you could give me their details so that I can pass it on to my local BMW garage. Your information has been extremely helpful. Many thanks.
If anyone can help or has any ideas it would be gratefully appreciated[/QUOTE]
