What is this Yellow Light about? - Bimmerfest - BMW Forums
Old 01-22-2013, 10:49 AM
amandeep18feb amandeep18feb is offline
BimmerBoy
Mein Auto: BMW 328i 2013 - Sports
Question What is this Yellow Light about?
Just picked up my car on Saturday morning and noticed this yellow light the next day.
Any idea what this is about?
Old 01-22-2013, 11:02 AM
boltjaM3s boltjaM3s is offline
Banned
Mein Auto: BMW M428i
Blurry, but looks like the check engine light.
If it comes on briefly at startup, no worries. If it remains on, get to your BMW dealer.
BJ
Old 01-22-2013, 11:04 AM
BimmerBoy
BJ
It is always on
Something serious?
Old 01-22-2013, 11:08 AM
Banned
Originally Posted by amandeep18feb View Post
It is always on
Something serious?
Do you have BMW Assist? If so, push the missile launch button above your head and ask them.
It hasn't happened to me, so I can't be of much use. The light indicates a myriad of things, I believe, only your dealer can see what code its throwing off.
BJ
Old 01-22-2013, 11:12 AM
BimmerBoy
BJ
Hmmm... Will go home and launch the missile
I never noticed it until my wife pointed that to me
Old 01-22-2013, 11:15 AM
johnofcross's Avatar
johnofcross johnofcross is offline
Mein Auto: F30 335i Superman M Sport
Kinda scary you don't notice a check engine light... Good luck.
8/31/2012 ED - ED Report
11/8/2012 PCD
2013 BMW 335i Sedan Estoril Blue II M Sport 2PF|6MT|ZDH|ZTP|Coral Red Leather|688|508
2007 Nissan Sentra SE-R
Old 01-22-2013, 11:17 AM
BimmerBoy
I have never owned a BMW, Didn't know what that light was about.
A
Old 01-22-2013, 11:25 AM
tturedraider's Avatar
Freedom isn't free!!
It is always on
Something serious?
The Check Engine/Service Engine Soon light always indicates some emissions related issue. It is virtually never a condition that will cause harm to the motor.
Is the gas cap on securely? A missing or loose gas cap is the most common cause of the Check Engine Light, because it causes the fuel system not to have the correct vacuum in the system. That adversely affects the performance of the emissions controls. Besides the loose gas cap there are a few dozen or hundred other reasons that can trigger the CEL.
The CEL will go out on its own after several engine running cycles and miles of driving if the condition clears itself. If the gas cap caused the light and the situation is corrected it will go off after 5 or 6 driving cycles of sufficient mileage.
I just made a 350 mile trip. It was really cold when I left and my transmission had a little hiccup with a delayed gear change right as I started driving. The CEL came on. I was almost certain the delayed gear change caused it and there were no other symptoms at all. The light stayed on most of the trip, but at my last stop along the way to get something to drink when I restarted the car the light did not come on. It has not come on again since.
www.bmwcca.org
AndDown's Avatar
AndDown AndDown is offline
just copacetic!!!
Mein Auto: '16 428i GC
I have never owned a BMW, Didn't know what that light was about?
A
Be sure to spend time reading the owner's manual - it will tell you pretty much all you need to know about what all the lights mean. You can also access the manual via the iDrive.
Dan
'03 325i OrBlu
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite
Old 01-22-2013, 11:28 AM
BimmerBoy
Is the gas cap on securely? A missing or loose gas cap is the most common cause of the Check Engine Light, because it causes the fuel system to not have the correct vacuum in the system. That adversely affects the performance of the emissions controls. Besides the loose gas cap there are a few dozen or hundred other reason that can trigger the CEL.
The CEL will go out on its on after several engine running cycles and miles of driving if the condition clears itself. If the gas cap caused the light and the situation is corrected it will go off after 5 or 6 driving cycles of sufficient mileage.
Thanks Buddy!
I checked the gas cap, it is perfectly fine. I think it is something else. I have given a call to my dealer and he said he will get back to me.
Old 01-22-2013, 11:38 AM
A
No, it's just that a CEL symbol is kinda universal, with a light shaped like an engine or 'Check Engine' words come on. I would have noticed that the light didn't turn off the first minute I'm driving the car, regardless of brand. Just sayin'
11/8/2012 PCD
Old 01-22-2013, 11:41 AM
Banned
Thanks Buddy!
I believe that the BMW Assist tech's can "see" the codes your car is throwing off from way up there in outer space. So push the rocket launcher and see what they say.
BJ
Old 01-22-2013, 12:31 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
op: does the light go out when you actually start the engine? in the pic, you have the ignition turned on, but the engine not running
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 01-22-2013, 12:34 PM
BimmerBoy
No, the light remains ON.
(What does OP stands for?)
Old 01-22-2013, 12:36 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
bring back to dealer have engine check out
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 01-22-2013, 12:37 PM
Banned
Original Poster (the one who started the thread).
BJ
Old 01-22-2013, 12:56 PM
BimmerBoy
Yes, I will do that.
BimmerBoy
BJ
Old 01-22-2013, 01:33 PM
Banned
Did you launch the missile into outer space and get feedback from mission control yet?
BJ
Old 01-22-2013, 03:01 PM
BimmerBoy
BJ
Not yet friend. I am in Office
I will go home at 6ish and then do that. But my dealer told me that he will pick up the car tomorrow and get it fixed.
Old 01-24-2013, 10:46 AM
bmwocean bmwocean is offline
Mein Auto: BMW335xi
This is an engine check light and will not go until you turn on the engine, from pic you have ignition ready but engine not running, if still stays on then as mention byBoltjaM3s contact your dealer, what did he say? i am sure you know by now as so many people have mentioned, it would be interesting to know why you have check light on new car?
Old 01-24-2013, 10:49 AM
BimmerBoy
You are correct.
I took it to my dealer and he did all the tests and then told me that since the engine is off the car is in "Accessory" mode, so you will see that light.
once I turn on the engine, the light goes off
Old 01-24-2013, 10:59 AM
SergioK's Avatar
SergioK SergioK is offline
Donkeybike?
Mein Auto: HP2Sport - R1200GS - F30
I think every car I've ever owned that was OBD1 or newer did that. What did you own before your F30?
Old 01-24-2013, 11:00 AM
BimmerBoy
Nothing
First Car
Old 01-24-2013, 11:23 AM
You are correct.
bmw 3 series, f30 3 series alpine white
