Old 01-21-2013, 08:46 AM
esquasedhc esquasedhc is offline
Mein Auto: 2005 bmw 645ci
2005 BMW 645ci
Where do i start??? i am having BIG BIG problems with my baby
HELP!!!!
bought some bad gas "low grade" and ever since then my car has been rough / erratic idling. i called a friend of mine who used to be a bmw tech, he advised me to drop my tank, dump the gas, clean the injectors and put virgin fuel back into my tank.
i have since done that, how ever, my car is still backfiring. even without starting my car, when i turn the ignition to the 2nd position i hear a clacking sound coming from the throttle body. i have reason to believe that once i eliminate that sound my car will stop backfiring.
has anyone else had this problem? pls help!!!!
Old 01-21-2013, 08:48 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Post this to the appropriate 6-Series Forum for the best answer.
The road goes ever onward....
(R.I.P. Jever)
Old 01-21-2013, 01:03 PM
2005 bmw 645ci
HELP!!!!
Old 01-21-2013, 01:14 PM
2005 bmw 645ci issues
HELP!!!!
Old 01-21-2013, 01:16 PM
thank you
my first time on here
Old 01-21-2013, 01:22 PM
engine problem,not sure.2006 bmw 645ci
pls help
Old 01-21-2013, 01:26 PM
what should i look for?
HELP!!!!
Old 01-21-2013, 03:05 PM
bismarck bismarck is offline
Mein Auto: BMW 645ci
Sorry I can't really offer any practical advice not being too practical myself. But first thing I'd do is see if there were any error codes being thrown. Also why the triple post?
Old 01-21-2013, 05:11 PM
HerbP HerbP is offline
You might want to try changing the fuel filter to make sure it is not plugged. It is possible that your fuel pump is going bad. There is no need to make 3 post for this problem. We will help you ASAP!
Good Luck
Old 01-21-2013, 08:24 PM
Yorgi's Avatar
Yorgi Yorgi is offline
I second Herb's suggestions.
I would do the easy things first. Check the fuel pump and replace the fuel filter. Next I would send the injectors out for a proper cleaning and get them flow balanced while you are at it. There are injector cleaning and blueprinting specialists out there that will make the injectors perform better than new.
I don't think bad gas would cause any problems with the throttle body. You may have an issue with the throttle body but that would be a peculiar coincidence.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 01-21-2013, 10:56 PM
i am in a process of checking my fuel filter and fuel pump like some of you have suggested. how ever, this morning i noticed that there is some oil in my throttle body. i don't know where this oil leakage is coming from. that cant be normal, is it?
n/b as far as the 3 post..sorry, it was not intentional...it was an error on my part.
Old 01-22-2013, 12:00 AM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
Thats really weird that you would have back firing and no check engine lights! These cars are so sensitive that if you fart in the wrong position in your chair the check engine will light up.
Oil in the throttle body is very weird as well. Are you sure it's oil and if so how much? I think the best thing to do is have a friend put the ignition in the second position while you pay close attention to the engine and see where that clanking noise is coming from.
Sent Via iPhone using BimmerApp
Old 01-22-2013, 05:59 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Hi! It is very hard to buy truly bad gas in the UK, even the most obscure petrol sellers or at worst supermarkets don't sell petrol that would cause this kind of issue???? This includes the lowest level of octane available to buy as it all must conform to a set standard to be sold in the UK. If that bad go to trading standards and seek redress!!!!
However I would ask given some of the symptoms, did someone inadvertently put some diesel in ( you would be surprised how common this is), which would account for some oily deposits in the throttle body......If this is the case subject to how much was dumped in you may get away with a complete fuel system clean and a flush of the tank, if you have been running the car and it is well into the engine then !!!!!!!!!!
Old 01-22-2013, 05:18 PM
The only thing of that could make a clacking noise while the key is in the 2nd position would be the ValveTronic motor try to calibrate itself. There are 2 motors under the engine cover, one on each side. If the noise is coming from either one, you have valve train problems. This could cause the motor to backfire! You probably need to get the car to a proper mechanic, before any more damage is done.
Good Luck!
Old 01-22-2013, 11:36 PM
i live in the UK or from the UK but work between UK and the STATES.....but now with NIGERIA
the car was bought in the STATES where i drove it for a year....i brought my car to NIGERIA, AFRICa. its been here only 2months.....its in NIGERIA i got the fuel.
plus i had the car worked on before it was shipped to nigeria
Old 01-23-2013, 02:00 AM
645/333's Avatar
Michael
Hi! Now I understand about the quality of petrol!!!!! I think what others have mentioned give the fuel system a good flush, maybe consider as mentioned changing the fuel filter. If possible give the car a very long run as short runs will not get the engine, catalytic converters up to temperature were they burn off all of the impurities. Remember it takes a good 35-45 mins of driving for these temperatures to be reached!!!!!! You may want to check the air intake and MAF in case you have a dust issue?????
Have to say your very brave to take a 6 series to Nigeria, I think i would have left it somewhere garaged and used something else in country! But I suppose because it is left hand drive you wanted to get as much out of the car as possible!!!!!!
Old 02-03-2013, 12:56 AM
i am still having a very odd idle fluctuation problem.
when i start my car, it revs up and down by itself in a very inconsistent pattern.
when i run a diagnosis on it, it gives me 2 faults
1 - throttle body actuator and
2 - DME internal fault
can someone tell me what to do?
Old 02-03-2013, 06:18 AM
Davegsu Davegsu is offline
Mein Auto: 645 ci
I have similar symptoms. However I only use highest garage fuel. I notice the rough idle when the outdoor temperature is below 45'F. I especially see it at stop lights. The engine revs on its own and the check engine soon light is on.
Old 02-03-2013, 02:27 PM
You need to run the diagnostics on the DME module. It will show or test the fault, that is having the problem.
