Old 08-28-2012, 06:20 PM
bondheli's Avatar
bondheli bondheli is offline
Mein Auto: das good ya?
Question How do I connect the fiber optic loop to bypass the L7 amp?
I purchased an additional loop and the "adapter", but neither are compatible with the connector that goes to the L7 amp.
Bump
Old 08-29-2012, 02:34 PM
JimmyW's Avatar
JimmyW JimmyW is offline
Mein Auto: 2007 BMW X5;2002 BMW 745i
There are two connectors on the L7; a larger rectangular sliding connector which is power and a smaller square connector which is what you need to bypass. The part actually going into the L7 is an adapter of sorts so you need to pull out the smaller two wire connector and fit it into your MOST bypasser.
Old 08-29-2012, 06:15 PM
bondheli's Avatar
Ah, that was it, thanks a lot.
Bump
Old 08-29-2012, 07:55 PM
deiontroy deiontroy is offline
Mein Auto: bmw 750li
Can you bypass the L7 and still have sound?
Old 08-30-2012, 11:46 AM
bondheli's Avatar
Yes but only in the front speakers. No sub either.
Bump
Old 08-30-2012, 01:42 PM
Ok Yeah I'm trying to get the subs to play
Old 01-22-2013, 05:18 PM
mo0107 mo0107 is offline
Mein Auto: 750i
Can you get you subs to play if you instal a most bus to stop the back doors from crackling and hissing
