Old 01-18-2013, 05:51 PM
jjbaldas jjbaldas is offline
Mein Auto: 323Ci
VANOS seals and Valve Cover gasket
I had a leak from VCG and decided to do the VANOS seals on my 323Ci with 185K miles. I really was not having issues with VANOS (no cold start idle problems) but I thought while I had everything apart I would do it. I attached a few photos and am pleased with the condition of the engine with my mileage.
I was on the fence on whether to go with Beisan seals or a VANOS rebuild/core swap -- decided on Beisan and glad I did so. Saved alot of money and the repair was quite straight forward and did not add much time in my opinion.
I have 200 + miles on the new seals and the improvement I feel is more even power in the 2000-3000 rpm range; I now seem to get through the low gears more quickly now.
ID:	358270   Click image for larger version
ID:	358271   Click image for larger version
ID:	358272   Click image for larger version
Old 01-18-2013, 10:08 PM
Mein Auto: '04 330Ci 6-speed
Engine looks darn clean for that mileage.
Are you the original owner? Oil change intervals?
Old 01-18-2013, 11:09 PM
Mein Auto: 323Ci
Yes, I concur with the engine condition.
I am the second owner -- I got the car with 160K miles. I knew the original owner and have all service records; he followed BMW recommended oil change interval of every 15K miles.
Since I owned, I do every 7500 miles.
Old 01-19-2013, 05:21 AM
GCoop's Avatar
GCoop GCoop is offline
Mein Auto: 2004 325xi
Nice. What oil have you been using? Dealer oil or other?
Old 01-19-2013, 05:37 AM
Mein Auto: 323Ci
I have been using Mobil-1 0W-40 European Formula. I believe the previous owner used dealer oil until end of warranty (many years ago now) and then Mobil-1.
I like the results and will be sticking with Mobil-1.
Old 01-19-2013, 08:02 AM
Fast Bob's Avatar
Keeping it surreal
Good job !
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Old 01-21-2013, 07:54 PM
a572mike a572mike is offline
automatics suck
Send a message via Yahoo to a572mike
Mein Auto: e46 coupe, F-150
Wow! That is clean for the mileage...
2001 325Ci ZSP 5 speed
2005 F-150 Supercrew FX4
1958 Cessna 182 Skylane
Old 01-21-2013, 09:42 PM
iskoos's Avatar
iskoos iskoos is offline
Coupe OR Never
Mein Auto: '02 - 325ci
Congrats. I am getting ready to do this in a few weeks. My VCG leaks badly and I want to do the both (VCG and Vanos) at the same time. I am going to use Beisan seals as well.
After replacing the Vanos seals, have you experienced any hickups or weirdness during the first few hours/100 miles etc?
I heard that it would take a while for the seals to get broken in properly and make the car run smooth.
I even read one post where the owner was experiencing severe idle hesitation after the Vanos seal replacement. I wonder if this is typical.
Old 01-22-2013, 04:26 AM
Mein Auto: 323Ci
I did not experience any hiccups. I do think that the performance improved (better power at low rpm's) after 200 + miles were put on.
But no idle issues or any other weird problems after Vanos seal replacement.
It is not a difficult DIY -- my recommendation is you take your time and don't worry about finishing up quickly. Also, since is it fairly cold up here in PA now, I left plenty of time for the RTV to cure before running the engine.
Old 01-22-2013, 04:46 PM
iskoos's Avatar
Coupe OR Never
Thank you.
I already have the valve cover gasket set. I will be ordering the Beisan seals soon. I will have Red RTV as well. Do I need anything else for this job?
OEMbimmerparts listed this below item. It seems, it will be required to get this DIY done. And Beisan kit doesn't mention this.
Did you use this stuff?
http://www.oembimmerparts.com/produc...1433817e46.htm
Old 01-22-2013, 05:19 PM
G. P. Burdell's Avatar
G. P. Burdell G. P. Burdell is offline
Rambling Wreck
Mein Auto: E46
It's in the first photo in the Beisan how-to article. If you're going to remove the VANOS unit, you'll need to replace the metal profile gasket and the two crush washers for the oil hose.
Old 01-22-2013, 07:09 PM
Mein Auto: 323Ci
iskoos, yep I Concur with G.P. Burdell -- I purchased the exact item indicated in your oembimmerparts link.
Old 01-23-2013, 05:53 PM
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
Amazingly clean for initially using 15K oil changes! You are wise to now change it every 7.5K. The way that engine looks, you will probably make it to 300K!
Old 01-23-2013, 07:02 PM
Mein Auto: 323Ci
Thanks, that is my goal!
Old 01-23-2013, 07:40 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2004 ZHP Sedan
Probably selling these engines short. A buddy just sold his 2000 328i that had 340k miles on it and still ran strong.
Check out my BMWBLOG!
Old 01-23-2013, 09:34 PM
iskoos's Avatar
Coupe OR Never
Thanks. It's been a while since I looked at the Beisan instructions. I forgot that 1st picture.
I went through the pictures real quick. I will order a few more parts I wasn't planing to order. I will try to order those left-hand threaded bolts incase one of them breaks during removal.
I only have one vehicle and I need to make sure I have everything in my garage to finish the project over one weekend.
Old 01-24-2013, 06:32 AM
That's amazing! I wish the rest of the car would hold up as well. I really can't complain though, other than a battery, belts and CAB's I haven't had to do anything to my car, but I'm a maintenance fanatic.
Old 01-24-2013, 07:47 AM
jdauria jdauria is offline
Mein Auto: 323Ci & X3 3.0i M-Sport
Well done, I hope mine looks like this when I do the VCG and VANOS. Owned the vehicle since 2004 and have meticulously maintained the 323
#465420 National Capital Chapter
My Progress Thread
2000 323Ci | TiAg | Gray | ZSP | ZPP | AFE | UUC | Eisenmann | Koni | ACS Type III | Coby Wheel | 330 Brake Swap w/ BMW Performance Rotors
2006 X3 3.0i M-Sport | Silver Grey | Terracotta | Navigation | Premium Pkg | Cold Weather Pkg | AFE |
