3.5m not starting - Bimmerfest - BMW Forums
Old 01-16-2012, 05:49 PM
04prox2 04prox2 is offline
Mein Auto: x3
3.5m not starting
It has only happened twice. Car will crank over but not fire up. It happened after a short 8 mile drive. I shut off car, fuelled up would not fire up. Motor spins over great, it fires for one milli second then continues cranking. The first time I shook the power cables on the battery and it started. The second time that wouldn't do it. I ended up shaking the power wires under the hood and it started. Just wondering if anyone else has had same gitch
Old 01-16-2012, 06:17 PM
Mein Auto: 2011 X3 35i
Do you have a 2011-12? or was this meant to be posted in the previous generation X3 forum?
Old 01-17-2012, 12:19 PM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
He says a 3.5 M (whatever the M is for) so kind of makes me think it is a new one. However if it is, then he should take it back to the dealer quick time and get it fixed and not try to deal with it alone.
Old 01-19-2012, 08:04 PM
Mein Auto: x3
It's a 2011, Dealer thought it was fixed when faulty steering rack was replaced, it was causing all kinds of electrical issues. It only happens when it's -25c or colder. Dealer is over 3 hours away. Just wondering if anyone else has had simular issue.
Old 01-20-2012, 08:29 AM
You are going to have to take it in. Is that the nearest authorized dealer, or just the one you bought the car from? If there are other BMW stores closer then you can go there as any BMW service center can do warranty (and that is what this is) repairs. If you can "cure" the problem by "shaking" wires then it sounds like some sort of electric connectivity issue (i.e. short) to me and really needs to be resolved. This is a brand new car, it needs to work right -- you paid for it!
Old 01-20-2012, 02:47 PM
No12 No12 is offline
Mein Auto: 2016 340i xDrive MPerf EB
No, never, TAKE IT To The DEALER pronto, 3 hrs away or not.
You knew where the dealer was went you bought it.
2016 340i xDrive EB MPerf
Plus 18 other BMWs since 1971..
Old 01-30-2012, 07:14 PM
Mein Auto: x3
I had it a dealership for a medical and after extensive testing no codes or other symptoms showed as usual car runs fine. Dealer was great but it's hard to fix whats not broken.
Old 02-12-2012, 05:32 PM
Mein Auto: x3
Got the word the other I'm not the only one. No fix as of yet.
Old 02-13-2012, 07:23 AM
Just a random thought, but you have a 35i -- I wonder if it could be HPFP related? There was a series of problems with those in the recent past. Keep your eye on it and if it happens again you know where to take it!
Old 02-13-2012, 12:05 PM
Highmodulus's Avatar
Highmodulus Highmodulus is offline
MSport is Best Sport
Mein Auto: 2011 M3 Coupe, Comp, 6mt
Wrong engine: N54 versus the N55 (which isn't known for the HPFP issue).
2011 BMW M3 Coupe Alpine White/Black Novillo, Comp 6mt
2011 BMW M3 Sedan Melbourne Red over Grey- sold
2011 BMW X3 Xdrive 35(i)- sold
2005 BMW M3 Coupe Black/Black 6mt- sold
Old 02-13-2012, 12:42 PM
bren's Avatar
bren bren is offline
///Mpty pockets
Mein Auto: wankermatic
It might not be "known" for them, but that doesn't mean anything. There are plenty of people having issues with the n55 too.
Old 02-13-2012, 05:12 PM
Mein Auto: x3
I always knew where to take it! This problem will surface in every 35i, just depends on climate
Old 02-13-2012, 05:39 PM
I really doubt that.
Old 12-05-2012, 05:13 PM
Mein Auto: x3
14 Just in the Edmonton area alone. They think they got it, new power distribution box was recommended. First -20 day and problem reared up again.
Old 01-22-2013, 08:48 PM
Mein Auto: x3
problem finally solved PCM was changed out everything works fine only took a year to solve.
